Question about Frigidaire ATF6000ES Front Load Washer
How to clean out your frontload kemore washer basket that is inside the pump
How do i clean out the pump on my kenmore frontload washing machine
    President:
  • Frigidaire Master
  • 2,651 Answers
You ll need to remove the lower acess panel you find the pmp there, remove the hoses and clean out all the debris.UNPLUG UNIT LIVE WIRES TO PUMP AT ALL TIMES!!!!!
Posted on Oct 31, 2008
I have a Kenmore top load Elite model # 110.28062800,and was wondering if the wash basket (part # w10118182)is to have water inside of it. I took the basket out to clean the machine and there's liquied...
Tony,
You can expect some light accumulation of liquid in parts of the basket. Keep in mind, this part is housed within the washer outer tub which contain the water as the basket does the crazy things wash baskets do.
Don't know why you feel you need to disassemble a washer to clean it so meticulously. Was it wobbling or not draining or did you just get bored?
Feb 11, 2015 | Kenmore Washing Machines
Kenmore HE2 washer stopped in teh middle of the washing, no power and can not open the door. Please help me in opening and fix it?
All frontload HE washers have a rip cord you can use to manually open the door but try to clean out your pump filter first. Your tech sheet is also there behind the service panel. Simply going by the diagnostics and cleaning out the filter could save you a bunch od money. Here is a nice video which shows how. H.E. PUMP FILTER CLEANUP
Dec 13, 2010 | Kenmore HE2 Plus Front Load Washer
Leaking and F51 error code on my Kemore Elite Oasis Washer
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit.
This can be caused by several different problems.
Make sure that you are not overloading the washer.
Overloading can cause this problem. A toy or foreign object could be under the washer that is interfering with motor rotation. With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily.
If not, you could an item caught between the spin basket and the tub. You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board.
A failed RPS sensor or a failed control board could also cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 05, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
F21 on the Kenmore HE2 Plus Frontload Washer
there is a removable access panel on the front of the machine under the door. Remove one screw from each side. There you will find the pump that has a strainer basket on it. Remove that and clean the blockage out of there. You will also find attached to the panel, another manual that explains the codes better
Dec 27, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE3t Frontloader Fills Up With Water After Cycle
inlet valves have possibly gotten dirt in them and need replaced . quick fix , is turn the water valves off behind the machine
Nov 07, 2017 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Broken Washing Machine
frontload or top load frontload,,remove debris from inside pump,, top load , coupler problebly broken,
Oct 11, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Front Load Washer Problem
Pump may be plugged.Take off back Locate pump remove hoses. Check pump spins freely, remove debis. Mine had a hole in the basket gasket sealt hat let debis get in the pump. Good luck
Oct 27, 2007 | Kenmore 44102 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
123 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
