Question about Dell A215 Computer Speakers
My pair comuter speakers work, and there pluged in right, but don't pay anything out of them.
The two side/subwofer works, but no sound comes out.
I just bought them.
their plugged in corret.
Their on!
the settings are on the two speakers and the subwofer!
Why does nothing come out?
    Novelist:
  • 159 Answers
I assume you have told Windows about you new speakers ???
(Start, Settings, Control Panel, Sounds and Audio Devices = Volume tab, Speaker Settings box, Advanced button ...)
Posted on Mar 17, 2009
Cable for phillips subwofer computer system not working. Is there a replacement i can buy
switch on the speaker system remove the jack connected to your pc.give full volume / off volume,
just touch the jack pin from your finger.check the sound is coming.
if sounds well your speaker is ok.problem with pc.
if not in woffer ic has to be replaced.
Nov 07, 2013 | Philips MMS171 Computer Speakers
NSM Digital Thunder CD Jukebox speakers on right side do not have sound
make sure speaker wires are all pluged in. if that dont wort check the speaker wire it my be broke in between speaker and player, try new wire
Jul 16, 2012 | Audio Players & Recorders
My speakers are pluged in but there not working.. my computers saying that threres no device pluged in.
Troubleshoot the issue by plugging in a different set of speakers or head phones into your computer.
If the new pair of speakers/headphones works, then your other speakers are broken.
If the new pair of speakers/headphones do not work, then the problem is with your computer audio, and I would recommend updating the drivers.
May 21, 2011 | Computers & Internet
Speaker wires are pluged in on my dell inspiron 530 but not working help
    • 1 Make sure that your computer and speakers are plugged in, have power and are turned on. If the speakers are plugged in but don't appear to have any power, plug them into a different outlet. Some speakers are self powered and use a USB cable to supply power. Make sure that the USB cable of your speakers is connected securely to the USB port of your computer.
    • 2 Retest the sound. If you still don't have any sound, make sure the cable connecting the speakers to the computer (known as a 1/8-inch TRS cable) is plugged into the green audio output jack on the PC.
    • 3 If you're using self-powered USB speakers, remove the USB cable and plug it into a different USB port. If you're using outlet-powered speakers and have a working set handy, replace the suspected non-working speakers with the working pair to test.
    • 4 Navigate to the Microsoft Fix It troubleshooter (windows.Microsoft.com/en-US/windows/help/no-sound-in-windows) to automatically detect and fix sound playback or hardware problems. If that doesn't work, proceed with the next step.
    • 5 If you have an add-on sound card and none of the hardware or software fixes helps, you may have to replace the sound card. If you use on-board sound, it will probably pay to purchase an inexpensive sound card rather than a new motherboard. Check the system BIOS to determine whether you have inadvertently disabled your on-board sound.
    • 6 Navigate to the "Start" menu and select the "Control Panel" and "Sounds and Audio Devices." Then click the "Volume" tab. If everything is grayed out, proceed to Step 7. If the "Mute" box is checked, uncheck it. In "Device Volume," make sure that your volume level is set to a comfortable volume level for your speakers.
    • 7 Click the "Sounds" tab. Under "Sound Scheme," determine whether "No Sounds" is selected. If it is, click "Sound Schemes." A drop-down list will appear. Select "Windows Default" as the scheme. To test your sound now, click on a sound listed below the "Program Events" window. The sounds will be indicated by a small "Speaker" icon located next to them. Left-click the sound once, then click the "Play" button. If you still don't hear sound, proceed with the next step.
    • 8 Click the "Audio" tab. Under the "Sound Playback" option, make sure your sound card is selected as the default playback device. Usually, only one device appears here, unless you have multiple playback devices installed.
    • 9 If everything is grayed out, you either do not have a playback device installed or your drivers are corrupted and need to be replaced. Drivers help hardware and software function together. Fix this by reinstalling the appropriate drivers. Do this by navigating to the "Start" menu and right-clicking "Computer." Then select "Properties" from the drop-down menu. Click the "Hardware" tab and then click the "Device Manager" button. The Device Manager will open.
    • 10 Look for either a red X or a yellow question mark listed under "Sound, Video, and Game Controllers." If a red X appears, right-click the device with the X and select "Enable" from the pop-up menu. Test your sound at this point. If a yellow question mark appears, right-click the device, click "Properties" from the pop-up menu, and then click the "Driver" tab on the window that appears. Next, click the "Roll Back Driver" button to roll back to the previous drivers that were functioning correctly. Restart your computer when prompted.
    • 11 As a last resort, you can uninstall and reinstall the device. To do this, right-click the device and select "Uninstall" from the pop-up menu. Restart your computer. Windows will automatically detect and install your audio device upon boot-up. If you still don't hear any sound from your computer speakers, contact a qualified computer technician.
Nov 14, 2010 | Dell Inspiron 530s Desktop Computer
At subwofer some speakers are not working
Hey bud, are u sure you have a 5.1 channel sound card . if not that is what is not allowing ur speakers to all work ,,, if u do , , then try the speakers on a different PC and if they do the same , it could be faulty..
Hope u come right bud
Feb 01, 2010 | Creative Labs Gigaworks S750 Computer...
New speakers do not work. Lime green cable
Re-starting the PC won't do anything for the speakers. The PC can't see them! What it can see is the sound device, card or on-board chip. If you had a previous pair of speakers working on the same connection, it seems unlikely that your sound device is to blame. Try slowly removing and re-inserting the plug a few times whilst some music is playing to see if the sound suddenly comes on. Some of these plugs are not too good at making connection! If this is unsuccessful get back and I will take you thro' proceedure to check your sound device. Ian. P.S. Take it the power light is on the speakers?
Sep 20, 2009 | Cyber Acoustics CA-2012 Computer Speakers
Blown subwofer?
I believe what you have now is known as a subwoefer. Toss it.
Mar 26, 2009 | Eltax Alpha 5.1 System
JVC TH-M505
There are very few uses for the subwoofer. Try it on FM if you get audio the woofer is working.
Apr 22, 2008 | JVC TH-M505 System
Subwoofer not working...!
Hello Lujo
There is a lot problems, arise from this particular hardware, you can RMS your product, Subwofer for a change for other if has warranty, or buy another sub, from any Radio Shack or other store. may be the insider split sound board if bad, or fried.
try any other brand like Sound Blaster Speakers. for 2.1 speakers.
Nov 29, 2007 | Logitech R-20 Computer Speakers
Dell A215 Computer Speakers Logo
83 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
