Question about Porter Cable 371K Electric Sanders & Polishers
Broken drive belt
How do I replace the drive belt? I have the belt but I don't see a tensioner.
  • Anonymous Dec 18, 2008
    no solution
  • jouge Jan 13, 2009
    broken drive belt and tore a new one trying to put it on.
After talking to Porter Cable there is a tool to put the belt on or you can take it to a service center to have it put on. Tool cost is $213.00 . Best advice is buy something else.
Posted on Mar 05, 2009
I have a self propelled lawn mower and the the belt that propells the wheels is loose, do I need to replace it or is there a way to tighten the tension.
Cathy, there is a way to adjust belt tension on some models whether it is by the cable or a slotted bracket where the idler wheel is mounted, depends on make and model. If you have your manual check in it for belt adjustment. Could be stretched belt, stretched cable, worn/oil on pulley, seized tensioner, stretched/broken spring on tensioner,etc.
How to replace drive belt on Craftsman 22 Front wheel drive mower
How To Repair Troubleshoot Self Propelled Part Of Lawnmower HD
Fix Self Propelled Craftsman Push Mower
How to adjust drive belt on 6 75 Horsepower self propelled lawn mower...
May 23, 2016 | Garden
Battery Light comes on while driving, It seems to come on and then go off, but it comes on with accelleration. I have replaced the battery and cables. Don't know what to do? Help please
CHECK ALTERNATOR DRIVE BELT TENSION IF BELT LOOK LOOSE ADJUST DRIVE BELT TENSION.IF YOU HAVE AUTOMATIC BELT TENSIONER CHECK FOR FOR BROKEN BELT TENSIONER. IF DRIVE BELT LOOK OKAY.CHECK ALTERNATOR VOLTAGE OUT PUT AT BATTERY WHILE ENGINE IDLING.BATTERY VOLTAGE SHOULD BE 13.5 - 14.5 VOLTS. IF NOT ALTERNATOR FAULTY.FIRST CHECK ALTERNATOR FUSE AND CHECK ALTERNATOR POWER FEED WIRE AND VOLTAGE REGULATOR WIRES FOR DAMAGE OR LOOSE CONNECTIONS. FIRST TURN OFF RADIO BEFORE REMOVING NEGATIVE BATTERY CABLE TO KEEP FROM LOCKING OUT RADIO.
Sep 02, 2011 | 2000 Mazda MPV
Gonna replace my broken drive belt but don't have a belt tensioner tool.Any poor boy solutions to this?
If you're talking about the little tool that you test the belt tension with, just use your finger to test the deflection of the belt. It should move up about a half inch or so when you push up with your finger with about 10 pounds of pressure. If it feels like you would adjust a chain final drive, it's a bit too loose.
Good Luck
Steve
Jul 30, 2011 | 2000 Harley Davidson XL 1200 C Sportster...
I am trying to get the serpentine belt back on but it sems that the tentioner is not in line with the rest of the belt track. I think this is why i can not get the belt back on.
IF YOUR DRIVE BELT HAS BROKEN AND YOU ARE REPLACING IT AND THE BELT TENSIONER NOT LINED UP WITH BELT.EITHER TENSIONER BOLT LOOSEN OR TENSIONER IS BROKEN AND NEED REPLACING.
May 17, 2011 | Chevrolet Cavalier Cars & Trucks
I have a broken timing belt. Can this damage the valves ?
NOT IF YOU WERE NOT GOING FAST WHE IT BROKE .MY BROKE JUMP OFF CAUSE THE IDLE PULLEY WENT OUT.
Nov 11, 2010 | 1987 Volvo 240
Have to replace broken belt on a whirlpool awz 7813 tumble dryer and wondered what way the belt runs around tensioners
Double the belt and slide it between the two arms of the tension pulley. Then slip the belt over the drive motor pulley. The belt will be pushing against the tension pulley from underneath.
Sep 30, 2010 | Whirlpool Dryers
Battery light turned on. Lost power steering and AC.
You broke your serpatine belt. Needs replacing. It's a $50ish part and easy to do if you have a diagram under the hood of how the belt fits. But if it was "rattling" for a couple of weeks take it in for crying out loud. Let the mechanic look it over to make sure your lack of vechile care didn't destroy anything under the hood.....
Jun 12, 2010 | 1998 Saturn SC
My belt tensioner pulley broke at the bolt that bolts to the bracket. I bought a new one and I was wondering if there was an easier way to replace the tensioner pulley other than removing both the upper...
You should only remove the drive belt shield if you raise the car. Below are step-by-step instructions per the repair manual. Drive Belt Tensioner
Removal & Installation To Remove:
  1. Disconnect the negative battery cable.
  2. Raise and safely support the vehicle.
  3. Remove the drive belt shield at the right wheel well.
  4. Remove the drive belt.
  5. Remove the drive belt tensioner mounting bolt.
  6. Remove the drive belt tensioner.
To Install:
  1. Install the belt tensioner. Torque the mounting bolt to 21 ft. lbs. (28 Nm).
  2. Install the drive belt.
  3. Install the drive belt shield.
  4. Lower the vehicle.
  5. Connect the negative battery cable.
Oct 30, 2009 | 1999 Plymouth Grand Voyager
1999 kia sportage timing marks
dfd3ea1.gif Crankshaft match marks
Align marks on timing belt pulley and pump body.
Camshaft pulley alignment marks
  1. Align marks on camshaft pulleys with alignment marks on seal plate.
  2. Install timing belt. NOTE: No looseness should exist on the tension side and at the camshaft pulleys.
  3. Loosen tensioner lock bolt.
  4. Turn crankshaft 2 revolutions in direction of rotation and check that timing marks are still in alignment.
  5. Tighten timing belt tension lock bolt to 27-38 ft lb (32-52 Nm).
  6. Apply a force of 22 lbs to timing belt between camshaft sprockets.
  7. Belt deflection should measure 0.30-0.33 in (7.5-8.5 mm)
  8. NOTE: Replace tensioner spring if timing belt deflection is excessive.
Timing Belt Installation
  1. Install lower timing belt cover.
  2. Install upper timing belt cover.
  3. Install power steering drive belt and adjust belt tension.
  4. Install fan pulley.
  5. Install generator drive belt and adjust belt tension.
  6. Install A/C drive belt and adjust belt tension.
  7. Install splash guard.
  8. Install fan and fan shroud.
  9. Install 4 fan bolts. Tighten to 24 ft lb (33 Nm).
  10. Install fan shroud mounting bolts.
  11. Install fresh air duct.
  12. Connect hose to resonance chamber.
  13. Connect battery negative cable.
Jul 26, 2009 | 1999 Kia Sportage
Tension pully is loose making the belt rattle
It sounds like you have a broken serpentine belt tensioner. The tensioner should always be tight, it is spring loaded and you would have had to release the tension on it to have put the new belt on.Depending on what engine that is in yours, this could be an easy fix or a hard fix. The tensioner on a 2.2L is made into a large plate bracket that is attached to the front on the engine and several other items have to come off to replace it.The tensioner on the 3.1L v6 is smaller and has one bolt that holds it on.Either one is available at the local auto parts store.
Hope this helps
Apr 20, 2009 | 1997 Chevrolet Cavalier
Porter Cable 371K Electric Sanders & Polishers Logo
264 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
Jim Parker
Jim Parker
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
