Question about Westinghouse Dishwashers
Not hot washing or drying
Will run through full cycle, but not washing properly . it is connected to cold water only. its about 5 year old.
  • tangles1 Oct 31, 2008
    yes its has only been conected to cold, as its is not steaming after opening ,it apears to me as its not heating the water or drying at all. could it be the heating element or is there something els it could be. Thanks
You can check for continuitry through the heater assy, possible its bad after working overtime for 5 yrs trying to heat cold water
Posted on Oct 31, 2008
    President:
  • Westinghouse Master
  • 2,651 Answers
Has it always been connected to cold water??? cant see how that would getanything clean designe dfor how water.
My machine is a few years old, I don't use it very often now, how do I make sure it's clean and not harboring bacteria?
I would keep the washer lid open and the agitator and drum dry. However, you will have to, from time to time clean the machine.
Run a full cycle (tub empty of garments) with hot water and Clorox or other liquid disinfectant. Then air or towel dry the inside components. Read the manufacturer's cleaning instructions that came with your owner's / user's manual.
Feb 24, 2017 | Washing Machines
How can you get a washer smelling good?
First of all this mainly happens when you use cold water washing, the plastic bowl(s) become slightly porous over time & the dirt from clothes adhere to the area between the inner & outer bowls.
To clean & remove smell.
1. Put washer on hot wash, high level & let it fill with HOT water.
2. Stop washer, put in an old towel.
3. Add a bucket of hot water (This allows the water level to be above the scum mark inside machine.
4. Add washing soda to the bowl (double the amount it says on the packet).
5. Start washer & allow to run to the end of the first wash cycle.
6. Stop washer & allow to sit for a few hours.
7. After the few hours, start washer & allow it to run the rest of the full cycle.
you can do the same procedure with Vinegar.
you may have to repeat procedure a few times.
TO PREVENT THIS FROM HAPPENING AGAIN YOU NEED TO DO THIS PROCEDURE ONCE EVERY 3 MONTHS.
The worst case scenario, you will have get a technician to remove the inner bowl & manually clean these areas.
Apr 27, 2014 | Haier HLP21E Top Load Washer
No cold rinse, only hot
Either the wires have come loose on the water valve or you have a defective water valve.Open the lid and look at the water valve. Are all wires connected?
If yes, replace the water valve.
Jun 24, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Check hose error on electrolux wave touch washing machine
I'm sure nojallo1 has already fixed his but I just ran into the same problem and didn't find anything in my searches for a solution. The problem I had was the test cycle wasn't long enough to get hot water through my water lines so it could verify the hot and cold hoses were in the proper places. Solution: Turn the hot water on in all the sinks in your house until they have hot water running through them. This will prime your hot water line so it is full of hot water instead of cold water. Then run the install cycle again and it should be fine.
May 17, 2009 | Electrolux EW1000i Front Load Washer
DISWASHER hdw100wht
You could if you wanted a hot wash. You cannot dry without cold water. The dryer cycle requires cold water to draw moisture out of the clothes.
You can create a custom program that has no dry cycle. I usually do the laundry this way and hang dry, however I only have cold water hooked up.
You could get cold from the cold tap by installing a few outdoor hose quick connect parts to the tap if your faucet ends in a screw fitting. You may also need screw on expander for this to work. Go to you local hardware store and tell them you want to get the outdoor hose quick connect parts and an expander to fit on your household tap. Buy metal parts NOT cheapo plastic.
Mar 23, 2009 | Haier HWD1000
Is fading and shrinking my clothes
low temperature and low rpm of motor,must try this.
Feb 16, 2009 | Frigidaire FTF2140F Front Load Washer
Hot water goes into cold water washes
It is normal for the machine to cycle between hot and cold water when filling even if selecting a cold cycle. The reason for this is because even a cold cycle requires the water temperature to be 78F for the soap to break up efficiently.
During the cold months the water in your pipes is probably less than 78F so the machine will need to add some hot water to bring it up to this temperature. Basically, it is adding cold and then hot water to maintain a temperature in the tub of 78F for cold water cycles.
Hope this helps, please rate my solution.
Jan 12, 2009 | LG WM-1832C Front Load Washer
Dishwasher
2 things will lead to soap not dissolving, first is cold water, so make sure you have hot enough water. second and more likely is the dispenser is not opening at the proper time , instead fully opens at end of cycle during the dry cycle never even getting wet, and washing dishes with no soap, id replace the dispenser or make sure your not stacking items in front of dispenser hindering the opening. also powder is best, tabs and gelpack put undo stress on the dispenser door not always allowing full operation...
Nov 06, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Forgot how to use
Doing a Load of Wash for Portable/ Kitchen Faucet
1) Make sure machine is set to Cold/Cold and never use Hot/Cold button (Hot/Cold is only for permanent hook-ups). Connect water hose to kitchen faucet. Turn on water to temperature of choice.
2) Load machine half to three-fourths full of clothes. (only half full is recommended if you intend to use the dry cycle right after the wash cycle. For half loads, push in the half-load button. )
3) Add detergent and fabric softener:
a. Liquid detergent into 2nd slot: only 1 tablespoon, 2 tablespoons maximum
b. Fabric softener into 3rd slot. this really helps in preventing wrinkles
(****NOTE: THE MOST COMMON AND MOST DAMAGING ERROR IN THE USE OF FRONT-LOADING MACHINES IS OVERSOAPING. oversoaping causes - pump failure, drain failure, etc. - none of
which are covered by the warranty. The only reason top
loaders use so much soap is because they use so much water and this dilutes the soap. Also, always use detergents that have an HE -- High Efficiency -- rating.)
4) Select Wash Cycle
Permanent Press is likely to be fine (32 minutes) as the USA has softer water than in Europe for which machine was originally designed. Hard water, as in Europe, means it requires more detergent and more washing motion than in the USA. Prewash and/or Superwash (53 minutes) might be preferred for dirtier clothes.
5) Select Spin Cycle
600 should be fine. A higher cycle means dryer clothes, perhaps more wrinkles, and certainly more noise. (Malber USA suggests 800-900 as the norm).
6) Make sure Spin cycle has cold water.
Faucet should be changed to cold water AFTER the initial fill even if you are not drying - all rinses should be in cold water for more complete removal of soap residue
If you use Dry Cycle
7) Select time for desired dry cycle. Make sure to change the faucet to cold water. If you do not want to use Dry cycle, select 0 minutes. Otherwise, use 120 minutes the first time until you can gauge what types of loads require how much drying time. Here's how the Dryer works: A heating element inside the washer heats up the load. During the dry cycle, as the cold water from the faucet circulates into the machine (in tubes, not mixed in with the load), it cools the steam and condenses it into liquid water which is pumped out.
After Wash & Dry
8) It takes approximately 90 seconds after the cycles are completely done before it allows you to open the door. Malber USA says it is due to safety requirement of UL. Who knows what UL security feature is for. Perhaps extra time to finish draining.
9) door slightly ajar to let the machine dry out. I have read postings that say the machine becomes smelly with mildew if you do not. Malber USA says this is true for all horizontal axis (front-loading) washers.
Most common complaints
1) Using too much detergent.
Front loader machines do not need so much water, and thus not so much detergent. Also USA water is softer than European water, for which the machine was originally designed, and that may explain why the detergent compartment is so big to hold more detergent. Soft water is easier to get suds. Damage is caused by suds. Suds migrate up the hot air duct during wash cycle and come to rest on the heating element. After repeated occurrences, suds (which are corrosive) will cause rusting and eventual failure of the heating element.
2) Dryer does not work, for several main reasons:
(thanks to Malber USA for points a and b)
a) the system may have overheated, tripping the safety thermal switch. This switch is located under the top of the machine and can be easily fixed by the consumer.
b) broken working thermostat. It is a relatively inexpensive repair to remove and replace this part and takes only about 10 minutes. It can be done by the consumer but it
is recommended that a qualified tech do the job.
c) Machine is too full and/or fabrics are too heavy.
Even though you can wash a maximum load of 11 lbs. of clothes, the manual suggests to dry no more than 7 lbs. of cotton clothes and 5 lbs. of heavy or extra large fabrics. Thats because the dryer works by heating up the clothes and then condensing the steam from the circulating air into liquid water which is pumped out. If the machine is filled too much or if the fabrics are too dense (e.g., jeans), the system cannot condense enough water and the clothes remain humid. Perhaps a second 2 hour dry cycle could work, but who wants to dry clothes for 4 hours.
d) Broken heating element
Seems that the heating element breaks after 2-3 years and needs to be replaced. And why is that? Most common reason for heating element failure is oversoaping. Suds migrate up the hot air duct during wash cycle and come to rest on the heating element. After repeated occurrences, suds (which are corrosive) will cause rusting and eventual failure of the heating element. But many people simply choose to not use the dryer rather than have it fixed.
Hope this works. Please be sure to rate me. thanks
Apr 17, 2008 | Malber WD1000 Front Load Washer/Dryer
Dishwashers Logo
190 people viewed this question
Top Westinghouse Dishwashers Experts
JonSnell Electronic
JonSnell Electronic
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
