Question about Linksys Wireless-G WRT54G Router
Help please i have a liksys router i put dd wrt on it and i have a comcast cable modem and i can't get a ip address
  • daisyjane_ha Oct 30, 2008
    i tryed that didn't work..... the router is a WRT54GS sorry ..... i am going crazy\!!!!!!
  • daisyjane_ha Nov 05, 2008
    tried all that and no luck. I brought it over to my moms house and connected it to her cable modem which is also a dhg535-2 and works great but not on mine. I called comcast tehy told me to call linksys. called linksys they told me to call comcast. any ideasd would be greatly appreciated.
Plug your ethernet from your computer into different port on back of router. This happened to me today and I kept troubleshooting. I thought my ethernet cable was bad. So I had extra port and tried it and it worked. Seems one of the ports went bad on us.
Posted on Nov 01, 2008
  • Linksys Master
  • 6,487 Answers
With Comcast make sure the you clone the MAC address because they use it as a authentication for your internet connection, MAC clone is done on the router setup page eventhough you're using now a DDWRT firmware and after cloning the MAC address on the router page power cycle modem and router for a minute then power on modem first next the router....
Don't forget to rate the solution FIXYA thank you....
Posted on Oct 30, 2008
Linksys router not recognize internet
Make sure your router's WAN port is set to dynamic IP. If the light on the front doesn't glow/blink for the WAN port, try a different cable. If a different cable doesn't work it's probably toast. :( This problem appears to be directly linked to the relationship between the WAN port and the modem. Given that the devices can connect to the router, but not internet, it has to be the WAN. Sometimes if the modem goes out it will send too much voltage through to the router and fry the WAN. Had that happen to my parents router. If the above doesn't "fix ya" then try a different router.
Worst case, you might have to put a wireless card in your PC and bridge the modem (wired connection) to the wireless card and broadcast for your wireless devices. At least until you get a new router.
Aug 02, 2013 | Dell Computers & Internet
I cannot go on the internet througt my router i have try to resset it, after reseting it it cant give my pc aan ip adres the type of router is dlink dir 600
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards in all the laptops/computers needs to be configured withthese router's wireless settings. Then the laptops/desktop computers cancommunicate with your wireless router and access the Internet via the DSL or cable modem.
May 26, 2011 | Computers & Internet
How can I my up my comcast netgear modems wireless to work? when I try my PS3 it detects a sginal but wont obtain an IP address. The same with my lap top.
You have to change the ipddress on the router different then the modem. For example 192.168.9.1 and leave the modems ip alone. Plug the cable into the Lan port of the router. Go to the setup screen on the router and tell give your username and password that
Comcast gives you. You will need comcast gateway address and dns numbers. There will be a connect button on the router and tell it connect it to the modem. You are trying to let the router receive that only ip address.
Nov 09, 2009 | NetGear CG814M Wireless Cable Modem...
How do I hook up a G wireless router to my h/p computer
The usual setup is to connect your internet cable or dsl model to the WAN port on your wireless router. any devices that were formerly connected to your cable/dsl modem then get connected to the LAN ports on your router. You will need to connect to the wireless router via etehrnet cable the first time in order to setup your wireless connection, it's usually a simple setup following the prompts.
Sep 29, 2009 | Belkin (F5D8231-4) Wireless Router...
Reseting "Bridge mode" in RCA DCM 305R cabel modem
you can't set teh modem to bridge mode, however, you can set the router to bridge.
The linksys should have bridge mode configuration in the uer guide.
connected the 2 router together
configure the IP address of the liksys to be inthe same subnet as the moem, but out of the range of the DHCP of the modem. ie. DHCP address 192.168.0.2 through 192.169.0.100, the linksys should have the IP address as 192.168.0.200
disable the DHCP on the linksys
setup the wirless just the way you would if ti was the modem.
connect from the modem LAN port to the LAN port on thelinksys. leave the WAN port open.
Dec 30, 2008 | RCA Thomson Digital Cable Modem (DCM305R)
Wrt150n dd-wrt firmware slow loading pages
First off thanks for using fixya.com
Second, I too am a dd-wrt user and found a similar problem when using dd-wrt with my IPCOP. You may want to go into the "Security" section of your dd-wrt and disable any fire walling or access-restrictions. Since you are already running zonealarm. Or remove zonealarm if you plan to use dd-wrt as your firewall.
Running multiple firewalls will slow down your network/Internet traffic.
Hope this helps you out.
Jei
Dec 15, 2008 | Linksys Wireless-N WRT150N Router
Firmware will not update
Next time install http://www.dd-wrt.com/dd-wrtv3/index.php
Jul 04, 2008 | Linksys Wireless-G WRT54GS Router...
WRT54GS DEVICE-NO INTERNET CONNECTIVITY
You didn't specify if you're using DSL or cable internet.
With DSL, keep in mind the software1.gif on the PC is what "dials out" to the ISP with your name / password, and you MUST set the name and password in the router. Otherwise, ONLY the computer that has the software installed (verizon, etc) will be able to connect.
Also, make sure that ONLY the LAN is connected from the router to the modem, and not both the USB and LAN.
If you're using a cable connection, you don't have to do this, however, most newer Linksys routers come with a 'setup' disk, which MUST be used regardless of connection type.
Oct 09, 2007 | Linksys Wireless-G WRT54G Router
ROUTER CONNECTIVITY
Ok, do a troubleshooting session.
Unplug the router from the internet modem.
Try at first to connect using a Network cable from you PC to one of the LAN sockets.
Can you access http://192.168.1.1  with your web browser?  (the configuration page)
     If yes it is possible that the router has the same address as your adsl modem.
    change the router address to something 192.168.0.1 instead of 192.168.1.1
     Save your changes. Plug your WRT to the adsl modem and try again.
     Does the internet work now with a wired connection ?
If the above does not work can you "ping" the machine ?
      ping 192.168.1.1
if none of that works try doing a hard reset... heres a little guide (off the DD-WRT wiki)
http://www.dd-wrt.com/wiki/index.php/Reset_And_Reboot
Linksys Wireless-G WRT54G Router Logo
214 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
