Question about Emerson Black Microwave Oven
No power when plugged in there is no power.
  • 2 more comments
  • dbontrag Nov 11, 2008
    no power to the microwave when plugged in. The fuse on top of the microwave is good
  • barbrl Nov 13, 2008
    hydro went out and went to plug in microwave and no power
  • Anonymous Dec 12, 2008
    I don't know how to start my microwave EM-S 35535 as I brought my microwave on trade me.
    Does it ave a kiddy lock and if so what do I do?
  • William Miller
    William Miller May 11, 2010
    Please reply back with your brand and model number so we can help you.
  • Emerson Master
  • 9,098 Answers
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
At our site, we have a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
The TCOs you need to be concerned usually with have all black or white wires only. Please reply with photos of your interior if you have questions.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
In some brands, there is a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you'd want to scan and e-mail or copy and fax the mini-manual (or at least the "schematic diagram page) to me, I'd be happy to make more precise suggestions.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Nov 08, 2008
My over the stove microwave starts continues for a few econds the f-7 appears and it stops
F7 means power to magnetron is interrupted.
I don't recommend that someone without experience and an understanding of the safety procedures undertake troubleshooting this.
You can find manuals and helpful exploded view diagrams for your model here and my favorite parts supplier is here. There is a technical sheet hidden behind the controls that has helpful technical and troubleshooting information. It will say something like this:
F7 Power to magnetron interrupted
1. Unplug microwave oven or disconnect power.
2. After 40 seconds, check to see whether this solves the problem.
3. Unplug microwave oven or disconnect power.
4. Check cooling fan operation
5. Check the magnetron.
6. Check P65 connection on the relay control board.
7. Check the P56/P66 connection between relay board and relay control board.
8. Check wiring to the 1200W inverter and control system. See "Checking Inverters."
9. Check operation of all interlock switches.
10. Replace all parts and panels before operating.
11. Plug in microwave oven or reconnect power.
12. Check voltage at 4903-1 on relay board. If it is 120, unplug microwave oven or disconnect power.
13. Replace inverter.
14. Replace all parts and panels before operating.
15. Plug in microwave oven or reconnect power.
16. If problem persists, unplug microwave oven or disconnect power.
17. Replace relay control board.
18. Replace all parts and panels before operating.
19. Plug in microwave oven or reconnect power.
20. If problem persists, unplug microwave oven or disconnect power.
21. Check for reversed plug connection on controls or loose wiring.
22. Replace all parts and panels before operating.
23. Plug in microwave oven or reconnect power.
William E. Miller, AS-EET
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Oct 05, 2016 | Kenmore Microwave Ovens
Will not turn on . Appears as though there's no power.
I'd try to unplug for a while. Could be a bad power cord for the microwave itself. I recently had a toaster problem. Bad wire right at the departure from the plug.
May 12, 2015 | Sharp R-930AK Convection/Microwave Oven
The control panel of microwave dead. No lights on the panel. There is power to the outlet
If it worked after unplugging and reinserting, it is possible that there is a wiring problem with the plug and wiggling the wires "re-made" a connection. Try plugging in to another outlet to eliminate a dodgy outlet problem.
Mar 26, 2015 | GE Microwave Ovens
EMERSON MWG9115SL-D WILL NOT POWER UP
Hello, welcome to Fixya!
The unit not powering up is an indication that it has a power fault.
First, remove the unit's power cord from the wall, wait for about 30mins, then plug it back in. It may cool by then and might power on. If it doesn't power on, plug it into another outlet, to make sure there electricity entering into the unit.
If plugging into another power outlet doesn't power it on then the unit is most likely having a power problem.
When electric current comes from the power outlet into the cooker, it goes straight into the power supply board which then circulates the current into the unit. So if the cooker doesn't power on, the first thing is to make sure there is power entering into the machine.
So check the power cord, if it is a 3-pin plug, it must have a fuse in it. check the fuse if it is not blown. if fuse is intact, then power supply board should be checked.
If any machine or electronics device doesn't power on, it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter and continuity tester in order to read the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.
Nov 22, 2011 | Microwave Ovens
No power to microwave
Hello
Check the Power Cord
Verify that the power cord is properly connected the outlet; the plug might have been removed to make way for another appliance. Do not connect the microwave to an outlet via an extension cord or plug adapter; the oven must be directly connected to an outlet.
Switch the Outlet on
Turn the outlet on, if possible, using the switch on the wall behind the counter or on the plug itself. Some microwaves have a separate power switch that must be in the correct position before you can begin cooking.
Reset the Oven
Unplug the oven, wait a few seconds and reconnect the power. A power surge could have temporarily rendered the oven inoperable. The oven should start up as normal when you connect the plug to the outlet.
Check the Fuses and Breakers
See that the fuse or breaker protecting the oven's circuit is still active. Replace the fuse if it has blown, or reset the breaker to restore power to the oven. Stop using the microwave if it repeatedly blows fuses or trips breakers.
Oct 04, 2011 | Microwave Ovens
Microwave has no power when plunged in
1) Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
2) Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
3) Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
4) Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Apr 04, 2011 | Maytag Microwave Ovens
Whirlpool Microwave error F3H
F3H Humidity sensor failure 1. Unplug microwave oven or disconnect power.
2. Connect a new sensor to the board (at P5).
4. If no failure code appears when starting sensor function:
 Replace old sensor.
5. If failure code appears when starting sensor function:
 Replace power supply board.
6. Plug in microwave oven or reconnect power.
Aug 04, 2010 | Whirlpool GH5184XPQ Microwave Oven
F7 code on Whirlpool Microwave model GH9185XLT - 1
Power to magnetron
interrupted
12. Replace inverter.
13. Replace all parts and panels before operating.
14. Plug in microwave oven or reconnect power.
15. If problem persists, unplug microwave oven or disconnect power.
16. Replace electronic control.
17. Replace all parts and panels before operating.
18. Plug in microwave oven or reconnect power.
19. If problem persists, unplug microwave oven or disconnect power.
20. Check for reversed plug connection on controls or loose wiring.
21. Replace all parts and panels before operating.
22. Plug in microwave oven or reconnect power.
May 23, 2017 | Whirlpool GH9185XL Microwave Oven
Microwave F-7 Code
F7 is q Power to magnetron
interrupted
5. Check resistance of the magnetron thermostat.
6. Check the magnetron.
7. Check P2, P4 and P27 connections.
8. Check wiring to the 1100W inverters and control system. See
“Checking Inverters.”
10. Replace inverter, if defective.
11. Replace all parts and panels before operating.
12. Plug in microwave oven or reconnect power.
13. If problem persists, unplug microwave oven or disconnect power.
14. Replace electronic control.
15. Replace all parts and panels before operating.
16. Plug in microwave oven or reconnect power.
17. If problem persists, unplug microwave oven or disconnect power.
18. Check for reversed plug connection on controls or loose wiring.
19. Replace all parts and panels before operating.
20. Plug in microwave oven or reconnect power.
Aug 08, 2008 | Whirlpool GH6177XP Microwave Oven
Emerson Black Microwave Oven Logo
76 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
