Question about Samsung ML 2010 Laser Printer
Printer Page Prints out but Blank
Just changed the printer cartridge. When one prints a page out it keeps coming out blank. It was fine before. Changed the print cartridge and then started with this problem for no reason. The installed the old:previous cartridge and it still gives the same problem. Need the format disc (have lost the original). I will then uninstall and then re-install the printer etc...
    Top Expert:
  • Samsung Master
  • 1,575 Answers
Hi
Re-check the cartridge installations.
Try disconnecting the printer from power and then connecting it again.
Solved?
Try cleaning the 'printhead'.
Posted on Mar 03, 2012
3 Suggested Answers
SOURCE:
flopez
  • 161 Answers
SOURCE: Printing Blank Pages
If the cartridges are original, your unit needs qualified service.
Posted on Nov 02, 2007
ginko
  • 19396 Answers
SOURCE: Only prints part of a page then stops.If I turn it
Hi.
Ensure that you have done the following:
  1. Reinstall printer software. Here the download link: ML-1640 Support. Open page and click on driver tab.
  2. Replace toner cartridge. Defective or empty cartridge will result in printing only top part of the document.
  3. Clean printer inside. toner on top of fuser unit will result in insufficient heat. Not enough toner gets melt and the final part of the page does not print. See Clean laser printer
  4. Upgrade firmware. Download available from ML-1640 Support (firmware tab).
If all that does not help, there are different faults that can result in half page only being printed (defective fuser, defective temperature sensor, high voltage unit, laser unit). The machine must be tested and repaired by a technician. If you have done all the above and the printer still prints half page, call Samsung support number to get a quote on repair.
Regards.
Ginko
Posted on May 08, 2011
Printer prints blank pages
This is almost certainly an issue with the toner cartridge. I would recommend running off 30 or so prints and contacting whoever the cartridge was purchased from if the toner doesn't pull through.
Nov 18, 2012 | Brother HL 2140 Laser Printer
Is this a brand new printer? What is the make and model of your printer? Are the ink cartridges brand new? Sometimes when the printer driver becomes corrupted it will print out blank page (page after page) I would reinstall the printer driver that goes to your printer and then restart your computer and try to print a new page.
http://en.allexperts.com/q/Printer-mechanical-problems-1024/HP-Printer-prints-blank.htm
http://techrepublic.com.com/5208-6230-0.html?forumID=101&threadID=207297&start=0
Feb 13, 2010 | Lexmark Office Equipment & Supplies
Prints blank pages
hi jcruisedirec
Test print shows that there is no problem with he printer.
Do this:
Type just one or two words in a new document and try to print. Before printing, look at the print setup and make sure you have the correct printer name selected.
Also when you go to print, there are few options like:
  • Print All
  • Current page
  • Pages
  • Selection
If you attempt to print "selection" without actually selecting a certain portion of the document, you get blank page.
So first check that the correct name of the printer is selected.
Then test printing one page
Hope this will help you. Good luck.
If you find this helpful, please give a rating
luciana44
Oct 04, 2009 | Canon MX300 Office All-In-One Printer
Page blank when printed
remove the ink cartridges and use a qtip dipped in rubbing alcohol and GENTLY clean the printhead on the cartridge. Reinsert and try printing again. If it prints anything at all, keep going till it becomes normal. If still nothing, replace the ink cartridges.
Jun 23, 2009 | Dell Inkjet 720 Printer
When I click "Print" paper feeds through the printer, but nothing prints
try to reload your catridge on the carrier or cartridge holder..
and clean your printer tab circuit and also the cartridge tab circuit and run maintenance page on it..
go to your printer panel and select maintenance ..browse clean printhead..and print maintenance page..to clean the cartridge..
May 18, 2009 | HP Office Equipment & Supplies
P3150 printer runs but doesn't print
Are you saying that the printer prints in B&W but not in color, or only that it will print a test page with B&W? It might be that the color ink cartridge is dry.
Apr 20, 2009 | Lexmark P3150 All-In-One InkJet Printer
I keep getting cartridge error or it prints a blank page. There is no tape on the cartridge and they are installed properly. It prints sometimes but not all the time Printer keeps saying cartridge error
This has been just happening with me aswell - I just changed the colour cartridge with the black cartridge ran out but i kept it in as it told me to place one in. Trying to print out but black ink wont come - just blank pages - surely the colour cartridge can make black? However, if you have the colour cartridge and are on microsoft word or similar, change the colour of the writing to dark navy and it will print out documents.
Aug 26, 2008 | Lexmark P6250 All-In-One InkJet Photo...
Printer prints only blank pages
Have you try to change your cartridge. Some times when you refill your cartridge, the flow of ink do not work properly. Try to change your both cartridge and then try
Sep 19, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Canon ip4200
Hi You can buy canon refile "InkTec Canon BCI-5/BCI-6 color" and fill Remove the empty and try to print,or you can buy canon refile "InkTec Canon BCI-5/BCI-6 color" and full it,it`s cheap instead to buy everytime a new cartidges. Good Luck
Aug 19, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Samsung ML 2010 Laser Printer Logo
248 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
jasbo
jasbo
Steve Allison
Steve Allison
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
