Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Sony full definition lcd model 1080
My picture is black. T'v turns on runs....then a red light above the word "lamp" flashes....does this mean the lamp needs to be replaced
Tv is only 3 yrs old
Thanks
  • 320 Answers
Yes you have a bad lamp. Unfortunately, I have noted that many dealers either "forget" to tell the customer that the lamp will require replacement, or they overstate the expected life of the lamp. The usual life of a lamp, as stated by Sony is 4000 to 8000 hours. There are 3 factors that effect lamp life:
1) the number of times the TV is turned on and off. Every turn on works the lamp very hard, so to make the lamp last longer, limit the number of turn on/turn off cycles. My rule of thumb is this: If you will be back to the TV within 30 minutes, leave it on.
2) Proper ventilation. In general the TV should have at least 6 inches of space on all sides to properly cool.
3) Power loss. If you have frequent power outages, buy a small UPS for the TV. The TV requires a "cool-down" cycle where the fans run to properly cool the set. If the cooling cycle is interrupted, it can effect lamp life.
Replace the lamp with and original Sony lamp and vacuum any openings you can see that are dusty and you should be good to go. Be sure to rate this solution. Thanks!
Posted on Oct 30, 2008
  • Any Guy
    Any Guy Oct 30, 2008
    Thanks for the rating. It is appreciated!
How to get a picture on sony FULL HD 1080
Hi. Not shore of this model but could be a bulb replacement is needed, Or one of the filter covers may not be making contact.
The red light is indicative of error rather than working ( green ) or standby ( orange ).
I hope you get it sorted.
Sep 12, 2014 | Sony XL5200 LAMP - TV KDS-50A2000,...
Sony LCD Model KF-60WE610 lamp was replaced and then it shortly after stopped turning on. Blinks Green 6 times then Red 6 times Please help!
For Sony Model KF-60WE610, KF-50WE610, and KF-42WE610, the Diagnostic Code of power light indicator flashing 6 times green, then flashing 6 times red (6 red etc), means you need to replace part number A-1302-272A G1 BOARD, COMPLETE. See Sony Service Manual, 4. Chasis-1 at part Ref no. 103. The Power Board sits vertically in two slots on the left side of the electronics board. 4 wire connectors to remove when replacing. This component fits all 3 KF models listed above.
Jun 22, 2011 | Sony Grand WEGA KF60WE610 60" Rear...
First the red bulb light was flashing and there was no picture. So i replaced the burnt bulb. Now when i go to turn the tv on were the red light means off and the green light mean on (that light blinks 3...
Check Lamp Fan if it stops running when Lamp trys to Light ,Then Lamp will not Power up,or Ballast Board itis what powers Lamp on.
Encompass Parts Distribution 1-800-638-3328
Oct 06, 2010 | Sony Grand WEGA KF60WE610 60" Rear...
TURNS ON THEN FLASHES GREEN FOR ABOUT A MINUTE THEN KEEPS FLASHING RED .WHATS WRONG?
Probable lamp failure, lamp won't turn on leading to red light to come on. How many times does it flash? 3 means safety switch bad, 5 flashes means lamp or lamp ballast failing.
Sep 30, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
Picture will come on and then go off after a couple minutes
This usually means the Lamp is failing. Replacing the Lamp usually fixes it. I would only use a Sony Replacement.
You can order one from Sony at 1800-222-SONY or you may be able to pick one up from a local Sony Retailer.
Skyassoc
Nov 25, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
The LCD light (green) flashes for like 6 times and then the pictu
even though the lamp light is not flashing I would think it is the lamp getting weak for some reason the Sony's do that.
Aug 19, 2009 | Televison & Video
The television will not turn on. Initially, when the remote (or button on tv) was used you would hear it turn on and hear some volume and then it would turn itself off. A red light would flash, stop...
You did not specify the brand and model of your tv but based on experience the red light indicator flashing means a projection lamp problem. Check the lamp and lamp doors if properly secured. If symptom persist you need to replace the lamp.
Aug 10, 2009 | Televison & Video
Red power light and buzzing sound with red lamp light.
My Sony lost its picture and had a flashing light. Unplugging for 36 hours solved the problem.
Mar 29, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
PICTURE ON LCD TV GOING IN AND OUT
it works!! First i took off the front panel. Just check your manual for instructions, very easy to do. If you do not have a manual just down load one from google.. The instruction are easy to follow. The screw they have you loosen with a alan wrench is attached to the plastic, so you do not have to worry about dropping it inside the tv. Removing the lamp was simple. once out you will notice on either side are two small mesh screens. One of mine was 80% blocked with dust, the other side was only 30-40% covered. I used a vacuum to remove the blockage, i did not want the dust and dirt to go inside the bulb. i then cleaned all around the lamp. Reinstalled, and we are go to go. The kids are happy and i am happier since my wife not be buying a new TV.
total cost of repair $.00
time required to fix, less than 15 minutes.
Also when my TV was loosing sound and picture and then return. I did turn off my TV, then turned on. I nothiced a red blinking light. Mine flashed 5 times. After some reserch, 5 times is video related, bulb or video board. google red flashing light with the model you have and you will find what all the codes mean.
So if yours is flashing 5 times try the above, it might work for you and it is well worth the time before you call a tech and drops hundreds of dollars.
hope this helps.
when your tv blanks out, turn off the tv and then it back on. below the power button usually flashes green light. does yours flash red? if so you need to count how many flashes. the number of flashes will help in resolving your problem. then google red flashing light sony and you will find what the red flashing lights mean.
Oct 04, 2008 | Sony KDF-E55A20 55 in. LCD Television
Sony bravia
what model of Sony is it? On many of the Sony projectors, a 3 flash error code indicates the lamp is not properly seated/installed or the lamp door is not closed properly
May 15, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
129 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
