Question about Frigidaire ATF6000ES Front Load Washer
Cycle won't sart
The cyle won't start unless you push and hold door in place firmly
    Sergeant:
    Champion:
  • 324 Answers
Check the door striker, Part # 131763310 it is on the door itself, or the door switch
Posted on Nov 03, 2008
My Dishwasher won't start unless I push firmly on the door.
Change the handle there is a switch on the handle that activates when the door is closed the switch is broken you have to buy the whole handle not just the switch
Apr 11, 2013 | GE Dishwashers
Dryer won't start
If you look closely, there are 3 separate pins that must latch. One is a simple push-button style which latches no problem.
The others are little prongs at the top and bottom of door. The bottom prong latches cleanly, but the top one will not latch because the door is a bit too flexible.
Close the door normally, then firmly press on the top edge of the door. You will hear the final latch grab, then you press and hold the start button. The dryer starts normally.
Oct 21, 2012 | Whirlpool GEW9250 Electric Dryer
Brand New Whirlpool Dishwasher won't start, can't change program eiether
Make sure the dishwasher door is firmly closed, press and hold the start pause button for about 5 seconds, this will clear the cycle, The try selecting a wash cycle and push start.
See if this helps.
Mar 04, 2012 | Whirlpool Dishwashers
The door on my whirlpool duet washer won't lock
Sounds like door switch is bad. Look at inside front panel of door, get model number, search on internet for "error codes" with that model number. It should show "DL" door lock defective, not secured, failure. One sure way (in most cases) is to push in on door and hold it firmly closed,it is works,bad door switch. To replace, order new switch, take the whole front panel (front assembly including door) off, switch on back side of panel. DO NOT TAKE DOOR HINGE LOOSE. Replace switch. By the way, before taking apart, UNPLUG FROM WALL.
Sep 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How do you change battery in Toyota Prius keyless remote
ok take the remote push the the key release on the top remove the valet key or door key then hold it firmly in your hand and with one finger push the key release slide all the way over again as if you were removing the key take your other hand and firmly place your thumb on the toyota symbal on the back and push it firmly upward towards the key release the back cover will slide up revealing a small door held on by four very small screws youll need a jewelers or eyeglass philips screwdriver to remove them un do them and out pops the battery its a cr21 just in case you didnt know
Jul 17, 2009 | 2007 Nissan Maxima 3.5 Sl Sedan
My Walmart Computer Care Plan CD is to small/My Dell XPS M1530 CD drive won"t '****' in the CD disk
The tray has a force open button, its a pinhole you need to find a paper clip and stick it in the hole the door will open on its own power and you should be able to get it out.
Apr 22, 2009 | Computers & Internet
Replacing ink cartridges
Replacing your cartridge:
  1. Make sure the printer is switched on.
  2. Pull the operator panel forward and open the cartridge access door. (Note: The cartridge carrier moves to the loading position, unless the printer is busy).
  3. Pull the old cartridge forward and then lift it out.
  4. If the cartridge is new, remove only the sticker or transparent tape on the bottom of the Cartridge.
  5. Insert the cartridges into the carrier and push back firmly until they snap securely into place.
  6. Close the cartridge access door and the operator panel.
  7. From the operator panel, press Options to select the cartridges that were changed.
  8. Press Start (Start/Yes), Options to select the cartridge type installed.
  9. Press Start (Start/Yes).
Sep 16, 2008 | Office Equipment & Supplies
CL Error Dacor Dishwashwer
I had this problem and it was driving me crazy! I finally figured out what it was, in my case. I thought that the door switch would be the problem, so I took the door cover off and jumpered out the switch. No luck. While I had it apart, I noticed that each time I bumped the main control board, I heard a short, and heard a relay close. I found that the main control board wasn't snapped all the way into its mount on the left side. Apparently, there is a contact on the back side of the board that only makes when the board is fully seated. Snapping the board firmly into place has fixed my problem.
Mar 30, 2008 | Dacor Dishwashers
Washing machine stops mid cylcle
try pushing the door closed again, i have a problem with my machine that when i put a load on it starts then stops the light starts flashing then i firmly push the door (at the handle side) and it starts to work again, it might help!
May 10, 2007 | Whirlpool AWM6120 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
