Question about Philips CDR770 CD Recorder
Philphs cdr770 I am having problems with the Philips cdr-770, it is playing discs absolutely fine but on recording it records for approx 15/20 minutes, shows display OPC then freezes up, to get it working again i need to switch it off then back on again...What do you think the problem is???
  • 112 Answers
A chip on the PCB under the drive is overheating.
Posted on Dec 07, 2007
  • 1 more comment
  • Leon Manveli Sep 29, 2013
    Thanks But, how can I find A chip on the PCB under the drive
    and how can I solve problem with chip overheating?
  • Leon Manveli Feb 09, 2014
    I can't find overheated chip (with laser thermometer) but I found solution. thin silence cooling fun over laser. that's all ;)
    New Friend:
Posted on Feb 09, 2014
Broken disc tray
Hello,i have a problem with my Philips CDR 770 CD. .. I purchased lately on the internet 10 CD digital audio VERBATIM,but will not read them ... only reads the Philips digital audio,writable and rewritable,the repurchase ... I hope you can solve my problem ... THANKS
Mar 22, 2014 | Philips CDR770 CD Recorder
My problem is my phillips cdr 770 wont accept the cds that i bought they are maxell 80 min normal cd r but the recorder saying wrong disc use audio cd so what cds do i use ????? am stumped it should use...
THE PHILLIPS CDR 770 WILL ONLY RECORD ON "MUSIC" CD'S.I USE A MEMOREX MUSIC CD FROM WAL-MART, IT'S A 40X700MB 80 MIN, IT WORKS FINE, HOPE THIS HELPS, GOD BLESS, PAUL
Sep 29, 2009 | Philips CDR770 CD Recorder
Im trying to records mix cd but isnt changing
• To switch off the Auto Track function you have to enter
Menu mode.
If you wish to increase track numbers manually, press
TRACK INCR(ement) on the remote control. For further
instructions see Menu mode.
ON (AUTO): The track increments are automatically taken over
from the digital source material or after 2.7
seconds silence during analog recording.
OFF (MANUAL): While recording track numbers can be
incremented manually by pressing TRACK
(Minimum track length is 4 sec.) (This can
also be done in Auto track ON mode.)
May 01, 2009 | Philips CDR770 CD Recorder
Disc indicates "disc full" after only a couple minutes of recordi
Brand of disk or bad laser alignment can cause this. if you have changed brands of disks go back to the others and if you have not then laser alignment is the most likely cause and can be fixed by a certified technician in this field.
Dec 26, 2008 | Philips CDR770 CD Recorder
Hi from greece,i have proplem with the philips cdr 770 i think i have to change the laser ( opu24.24) can we find it?
This has to be done by a certified technician as it is very tricky to get the laser aligned and requires special equipment.
Dec 20, 2008 | Philips CDR770 CD Recorder
CDR is not working
have a look on ebay for a cheap working donor recorder as spares are very expensive and very hard to get hold of.
i'm guessing your recorder either doesn't read discs, or it won't eject? which is very common and means either the servo board is faulty or the laser.
The following recorders i know off hand for a donor mechanism are:
MARANTZ DR-6050
PHILIPS CDR-775
PHILIPS CDR-770
if it proves to be just a faulty laser, all 3 of the above have the same laser unit.
if it proves to be a faulty servo board, all 3 have the same servo boards except if you fit one out of a philips model it will show 'PHILIPS CD RECORDER' on the display at power up but will still work nontheless.
obviously if a marantz is found it will show 'MARANTZ CD RECORDER' as normal.
hope this helps.
Aug 27, 2008 | Marantz CDR500 2-Disc CD Recorder
No Disc
you have to change the lazer!that problem i have too
Jul 08, 2008 | Philips CDR770 CD Recorder
Wrong disc
Some audio cd's work better than others. I have experienced some problems with the Maxell brand so I switched brands. It can be quirky. Sometimes you get a bad lot of discs. I have had no problems since that bad lot of discs.
Mar 05, 2008 | Philips CDR770 CD Recorder
Philips CDR770 CD Recorder Logo
373 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
