Question about Hobart D300-6036 Mixer
Timmer assembly I have a d300 mixer.. The timer only give power to mixer for 2 minuts...then it shuts off. I have to keep on turning on the know to give it more time. Where can I buy the timmer assembly..or is the a way to buypass the timmer. Can I connect the power directly to the start button.. thanks
  • 21 Answers
This a 115 volt single phase timer you can buy the timer at hobart.com or jump the timer by jumping the red and brown wires but the timer will not work if you want the phone # of hobart tell fixYa to email me and i will leave the number they are located in jackson hieghts N.Y
Posted on Nov 19, 2008
Mixer is dead
If this is being used in a commercial setting (I presume it is as it's a D300) the first things I would check is
1 outlet / breaker box /main electric panel
2 Cable from outlet to mixer if the outlet is hot
3 Timer Start Stop switch
4 Motor capacitor
5 Motor (this is ugly as it has a number of electric parts that could have gone bad)
That's the best I can do without further clarification. How did you find it was dead? Did it die while it was in use? Did it make any strange noises? Did it smoke? Do you get any response at all when you turn it on? My first reaction if the cord and outlet are good then I would be looking to the On/Off Timer control switch. It is the most logical if the mixer has not had any other instances of smoking lagging struggling with mixes or advance warning of a problem. It is the most likely answer that a contact is not working. Press all switches and buttons to see if any feel stuck in place. It may be that you only need to open the switch panel and clean out the flour and other gunk. I hope this helps, if so let us know we love hearing from you about a good solution.
Sep 18, 2012 | Hobart D300 Stand Mixer
Hobart D300 gear wheels assembling layout
Hello Rohan,
The best thing I can point you to is HobartCorp. website you will have to become a new member it is free. Once you have become a new member you will want to log into spec sheets, type the model number D300, at the bottom of the page that pops up it will show parts catalog this will give you a blowup of all the gears and how they go together. Putting one of these together is not easy you may need to find some one to help you.
I hope that this helps you in your venture and thank you for using FixYa.
Here is the link to become a new user:
https://feg.hobartcorp.com/CookieAuth.dll?GetLogon?curl=Z2FsalesZ2Fredirect.aspx&reason=2&formdir=2
Feb 18, 2011 | Hobart D300 Stand Mixer
I HAVE A HOBART MIXER D300 ML#11627 I NEED TO KNOW WHAT KIND OF GREASE TO USE FOR TRANSMISSION,AND WHERE CAN I GET IT
Goto hobartcorp.com,create a username and then you will be able to find out what your looking for.I know that these mixers used oil when they where new but now changed to grease.Any ? let me know as im a hobart tech a repair these often.
Nov 19, 2009 | Hobart D300 Stand Mixer
HOBART HL 600 NOT WORKING.SPEED & TIMMER ALL LIGHTS WORKING BUT NO MOTOR FUNCTIONS.
What'd ya do to that poor little workhorse? You need a Hobart service guy. The power is not getting from the switch to the motor. Could be a disconnected wire (on the simple side), could be the start capacitor. Did you turn the timer on? If you don't the mixer won't run! That is a 220V, don't stick your hands in there when it is plugged in.
Sep 01, 2009 | Hobart H600 Stand Mixer
How to remove key from D300 Mixer to replace stripped gear
Keys are removed using a small punch and a hammer. The punch of choice is called a ***** punch
Jul 10, 2009 | Hobart D300 Stand Mixer
Problem with the 3rd gear on Hobart D300
Hobart won't give up service manuals The slide for your shift fork may be froze or corroded at top. The gear setups are fairly simple. The mainshaft nut comes off counterclockwise. The top gear has one way rollers with shims under the large washer. This gear assy must go back in the right way or you will break gears as soon as you start it.These mixers corode a lot at the top gearbox when they sit idle from moisture. Also check for broken gear teeth that may be jaming up he works. If you want to sell it let us know.
Dave at machinerysurplus@yahoo.com
Dec 11, 2008 | Hobart D300 Stand Mixer
D300
See if all the gears are dead. This will indicate which key may be broke. If all the gears are gone, look to the small shaft with the brass gear. It engages the motor worm gear.
http://www.hobartlink.com/extranet/extranetmanualsandcatalogs.nsf/08082CF4BE829A3C852568E1006A9A00/$File/F-19118%20(07-94).pdf
Apr 23, 2008 | Hobart D300 Stand Mixer
Hobart D300-6036 Mixer Logo
107 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
