How do you open the flashdrive? - Computers & Internet
    President:
  • 1,901 Answers
When you plug it in you should get a window that asks what you want to do.
Easiest thing is to select:
"Open folder to view files with Windows Explorer"
If you don't get a window, click Start>All Programs>Accessories>Windows Explorer
On the left frame click on the + sign next to My Computer.
It will show up as a Removable Disk, or on some as a brand name. Click on it.
Posted on Oct 30, 2008
Can't open my pny flashdrive
put it computer and install flash driver software.
Mar 24, 2013 | PNY Electronics - Others
Can't open the flashdrive.
put it computer and install flashdriver.
How to download on verbatim flashdrive
Hi, if you want to download to the flashdrive, or external memory device you are able to "Browse" the location you would like to usually before downloading, like something from the internet. If you are trying to save pictures from your computer onto your USB flashdrive you can right click your picture, select copy then goto your start menu and select & open your USB drive, then right click and paste into the window or a folder that you have created. To create a folder on your USB, just right click into a blank space in your USB window when opened, and select NEW, then Folder =) Hope that helped
Feb 17, 2013 | Verbatim Electronics - Others
How to get the pc games to the removable disc(J) sandisk.Can not Move them to Flashdrive disc.
It is not completely clear if you mean large PC games or if you mean small PC games.
By small PC games I mean games similar to the games that come with Windows and that appear in the 'All Programs -> Games' folder. Such as 'Free Cell', 'Hearts' or 'Solitaire'.
By large games I mean games like 'World of Warcraft' or 'Mortal Combat'.
Also, do you want to install the games on your Flashdrive or store them there?
If you want to store a large game on your flash drive. Place the CD/DVD with the game on it in your CD/DVD drive and insert your Flashdrive in a USB port.
Open 'WIndows Explorer' or 'My Computer'. Locate the CD/DVD drive that you inserted the game disk in (most likely your D: drive).
In the 'Edit' menu select 'Select All' and then in the 'Edit' menu select 'Copy'.
Then locate the Flashdrive in 'WIndows Explorer' or 'My Computer'. And in the 'Edit' menu select 'Paste'.
While this will copy the files from your game's CD/DVD disk to your Flashdrive you may or may not be able to install the game from your Flashdrive.
You can use this same procedure to copy small games to your Flashdrive from your Hard Drive.
You will need to know where on your hard drive they are located. And they may or may not run from your Flashdrive.
Also you may be able to install and run games from your Flashdrive, When you run the Setup program from you game disk you will usually be given the option to select a alternative location to install the game.
Select your Flashdrive at that point and it may install correctly to your Flashdrive. If it does you should be careful to always use the same USB port or the game won't run.
Hope that helps.
Jul 04, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Where do I see "My
On PC Dell Laptop press a key combination WinKey+E (WinKey is a key with Windows symbol on it) and the "My Computer" window will open - if you see your flashdrive in it - Right mouse click on it and choose "Explore".
Mar 07, 2011 | Computers & Internet
How do I download pictures from my computer onto a usb-16gbtr, there are no instructions with the flash drive
Just plug the Flashdrive into the USB port of any Computer and the Operating system ie: Windows should just pick it up with Auto play after a few seconds. Open the FLashdrive under My Computer?Computer(depends on the version on windows you are using) Open the Mass Storage device or the drive that shows the Flashdrives details and then just copy your pictures from the folder which you saved them and then Paste them into the Flash drive.
If you want a more detailed description, just let me know what Windows or Operating sytem is on your Computer or the device you want to download from and also the make and model of the Flashdrive.
Hope this helps
"Even your Computer needs a rest"
www.thecomputerspa.co.nz
Jan 31, 2011 | Computers & Internet
I have a flashdrive that will not open. It says
This is a problem with these flashdrives. Unless you use the correct procedure to remove them from the computer, there are all the chances that it will get corrupted and have to be thrown away, should that happen. What you do is that you use it on a different computer. A third or a fourth computer. Wherever it works copy the data and format it. If you fell that you have had enough, then throw it away. But, it should work on a different computer, so the time to throw it away should not come, hopefully.
Nov 17, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I can not copy enything onto the 8gb flashdrive and if copied it cant be deleted again
Do you have a write protect switch on the pen? If so switch it to the open position.
Sep 10, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How do you install and use a USB Flashdrive
just try this one. try to insert your flashdrive to a usb port where it is compatible then a message will appear saying open folders to view files then you can now copy and paste a pictures or songs on the pc or on ur flashdrve.
Feb 25, 2008 | Electronics - Others
Computers & Internet Logo
David Payne
David Payne
