Question about Acer Aspire 4720 Notebook
Acer Travelmate 2200 keyboard removal
How do I remove the keyboard to access the second RAM slot
  • jgnou Oct 31, 2008
    Thanks a lot for the steps. Worked perfectly and took less than 5 minutes. My computer now seems to re-start from stand by mode by itself though. Any theories on that??
  • 71 Answers
Open the small horizontal panel above your keyboard with a small screwdriver (you should do it gently) > open the screw below that panel > open your keyboard (be careful not to pull your keyboard too hard because there is cables underneath your keyboard) > from there, your memory slot should accessible.
Posted on Oct 31, 2008
Install ram in acer travelmate 5360
Yes, the large panel from the Base Enclosure.
This is a view of the Base Enclosure,
http://www.amazon.com/Acer-Extensa-TravelMate-Lower-Bottom/dp/B004PYZY7Q
The Base Panel is the large L-shaped Panel. (Not in photo, just Base Enclosure)
Regards,
joecoolvette
Sep 03, 2012 | Acer Computers & Internet
How do i get access to the RAM slots on an Acer Travelmate 420???
The memory is located under a small cover plate on the bottom of the unit. Remove the battery, and then take out the two screws of this cover plate, you will find your Ram located under this plate. Here is the user manual for your model notebook:
http://support.acer.com/acerpanam/manuals/acer/0000/userguides/tm420ug.pdf
Sep 16, 2009 | Acer TravelMate 4200 Notebook
Acer Travelmate 270 Memory Upgrade
Acer TravelMate 270 upgrades:
The official upgrade slot is located on the bottom of the laptop and is easy to find. Just unscrew the small cover and there it is.
The other slot requires you to unscrew the two screen bracket screws. Once you have done this, between ESC and F1, F4 and F5 and F12 and PrtSc there are small plastic rings. Put a biro nib into these and pull down. They will pop down. You can now remove the plastic cover.
Unscrew the two screws marked "L9" on the bottom of the laptop which are located at the top of the memory cover. Now you can remove the keyboard. Underneath the keyboard is the second RAM slot. The SiS 650 chipset supports a max of 1GB per memory slot and since this laptop has two slots that means 2GB of RAM. I've used Kingston DDR400 PC 3200 SODIMMS.
You can also upgrade the CPU - the fastest CPU available is the Pentium-M 2.6GHz. Nothing faster will work - trust me on this. It must be a Pentium 4 Northwood architecture CPU with a 400MHz FSB. Standard P4 Northwood CPUs with the metal shim won't fit - unless you know a way of removing the shim without destroying the CPU. Best to stick with a Pentium mobile (Pentium 4 M) chip. Look on Ebay for these.
Of course the hard disk can also be upgraded - a 200GB 7200RPM 2.5" drive works a treat. Non SATA of course.
You can add wireless and USB 2.0 using PCMCIA carbus cards. I use a StarTech 54mbps wireless card with the RAlink chipset and a NEC USB 2.0 card with 4 USB ports. Both cards fit in at the same time.
The laptop absolutely flies with these upgrades.
Mar 20, 2009 | Acer TravelMate 273XV PC Notebook
How do I remove the keyboard from an Acer Travelmate 2200 LW80
http://www.crunchgear.com/2008/08/28/how-to-add-ram-to-the-acer-aspire-one-netbook/
This link will show how to remove the keyboard but i must stress I DO NOT RECOMMEND this inless you are experienced. There is a lot of stuff that can go wrong. So please be careful. And no more soda around the computer huh :}
Jan 06, 2009 | Acer Aspire 4720 Notebook
Need to replace ram memory under the keyboard on acer travelmate 2200
this is how you do it...
ftp://ftp.work.acer-euro.com/notebook/travelmate_2200/manual/tm22_27-uk.pdf
read up first and find out what memory you need. remember that once you buy memory you can't return it if it turns out to be wrong one...
Sep 25, 2008 | Acer Computers & Internet
Acer travelmate 2003lc will not boot with new ram
512MB (FT64MSD64V3F)
200 Pin Dimm - SDRAM - 2.5V - DDR - PC2700 (PC-333) - Non-ECC
is the correct type of RAM for your laptop.
Have you tried booting with all combinations.
512 in slot 1 --- Boots
move same dimm to slot 2 (on it's own) and try booting.
boot with 256mb in slot 1 and known to be good 512 in number 2
This laptop should allow up to 2GB RAM. So I don't belive it is an issue with the mother board not seeing the amout of RAM. I think it could either be flaky dimm or your slot 2 is damaged
Aug 23, 2008 | Acer TravelMate 2300 Notebook
Installing extra RAM on my Acer Travelmate 803LCi
No, the plastic strip should snap out. I generally lift up from the right side. Once I get the side up, I work the rest of it up and out.
Jul 11, 2008 | Computers & Internet
Mar 22, 2008 | Acer TravelMate 2702WLMi Notebook
Removing Acer TM272XC Keyboard
The memory module is on the base of the laptop. It is the centre with the hard disk to its left and should be marked RAM at the side of it.
If you use the link below you will get a picture of where its:
http://www.acerpanam.com/synapse/data/7117/documents/TM2420_ENG_OLM.pdf
Mar 17, 2008 | Acer TravelMate 272XC Notebook
RAM upgrade
that way it won't work you have to first remove your RAM and insert the new one and start it
Feb 17, 2008 | Acer TravelMate 2300 Notebook
Acer Aspire 4720 Notebook Logo
549 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
