MY Panasonic CF25 came up with some sort of message on Windows which was too fast for me to read. Since then when I switch on I get to the Windows test card fine, and then the screen goes black. I can still hear Windows loading and the Windows' jingle when it's finished loading.
Is there any way to fix it?
Marie
Comment by Marie1, posted on Sep 14, 2006
Thank you again,
Marie
4 Other Users Have The Same Problem
Comment by valbrwil, posted on Apr 23, 2008
Well at first my computer screen will get a lot of colored pixels all over and then if I just let it sit there, the screen will go blank, but the computer is still runnig. I dont know if this has somethin to do with my computer getting to hot or is it just the monitor.
Comment by thirdmeyers, posted on Jan 08, 2008
i have the same problem but when i go to uninstall the display adapters there is no where to uninstall it at
Comment by mhdm, posted on Nov 03, 2007
My lcd screen went blank, however, there is a very faint image of the desktop in the darkness. I tried the function//f3 key & the function/brightness key -- to no avail. My graphics card appears to be ok because I can and am now using an external monitor. Could this be a driver problem? My gateway notebook 450sx4 lcd display is an active matrix 15" XGA.
Comment by mike98gt, posted on Nov 02, 2007
I cant see my screen very well, I had to change out my lcd and now I cant see it that well. I have tryed the brightness but nothing still looks the same, I can see the different colors, but its as if there is a black screen over it. Pls help.
1) Boot the laptop into safe mode. Boot into safe mode with networking support if possible. This can be done by tapping the F8 key as the computer first turns on.
2) Once you are at the Desktop, right click on My Computer and select Manage.
3) In the window that appears, select Device Manager from the menu on the left.
4) Find Display Adapters on the right and click the plus sign. This will list the video adapter that you have.
NOTE: WRITE this down EXACTLY. You may need to go and get drivers for this. Seeing this is an older model, I doubt you'll need it, but better to be safe then sorry.
5) Go to your manufacturers support web site and download these drivers. You may not need them, but better to be safe then sorry.
http://tcc.toughbook.com/
NOTE: Skip step 5 if you did not boot with network support or cannot get to the Internet. This can be done from normal mode.
6) Right click on the display adpater and choose un-install. Hit OK on the window that appears and reboot the machine when the process is done.
7) The machine will take longer than usual to boot, as Windows XP is re-discovering the video adapter and resetting everything to the defaults. When it is done booting, the screen may look weird since the settings are now the defaults. You can the set them to what you want by right clicking on the desktop and selecting properties. Then go to the settings tab.
8) IF it did not re-discover the video adapter (this can be confirmed through the device manager), then go ahead and install the drivers. Windows Update will most likely also have the drivers.
NOTE: This process should work with Windows 2000 as well, although I was not able to test it. The only issue I can think of is that it may not auto-discover the video adapter, and you would have to manually download and install the drivers.
Was this solution helpful? Show your Appreciation by rating it:
My question is has anyone got the first aid disk for the CF 25, I have lloked on the said site after regisering but to no avail. If you have that or anything else that might help with the CF 25 please contact me on horus9339athotmail.com. Thank you for your time.
Post a New problem for Panasonic CF-25 - Intel Pentium
Email this problem
