Question about Philips Televison & Video
I have a 32in lg tv with one HD input. Also i have a sky hd box. also there is an lg hard drive dvd player/ recorder and also a philips 6510 home cinema player with speakers. what is the best way of connecting all this together as each manual gives different options.
  • 417 Answers
I would use the Sky box manuals recommendations for connection as this usually gives the best performance especially if you wish to record from Sky to the DVD recorder.
Posted on Oct 30, 2008
I have a lg smart tv and when I switch on the sky hd box the remote work very slowly and then dies when it warms up
Check you remote battery and the connection. You may have to bend the tabs back a bit to ensure a good contact.
Not sure if you are describing the TV or the Sky HD Box remote.
Mar 16, 2015 | LG Televison & Video
How to besto connect this unit to record from Sky plus box
SCART from Sky box to SCART input on Pana. SCART out from Pana to TV to monitor results. The Pana SCARTs should be marked, one for external source such as Sky box, one for TV
Oct 26, 2013 | Panasonic DMR-E65 DVD Recorder
Can I use a HD receiver as input for the Toshiba XS35? Will it record HD signals? Will it record anything if the receiver is HD? I want upgrade my exisitng Bell Canada TV receiver box to HD - can I...
Yes you can record any TV show HD or SD, however it depends on what connections you use and what the recorder does with the input signals. You can record HD shows but not in HD resolution if you connect using composite video (yellow RCA cable) you just get a down-converted resolution, probably 480. You must use a HDMI or a component video connection for HD BUT if the recorder cannot record HD video, it should just record it in SD resolution but it should record the input signal. DVD is not HD, you would have to go to Blu-ray for HD and there are not many Blu-ray recorders around. The hard drive has the potential to record in HD but the recorder would have to process HD signals and you would have to connect with HDMI or component video. I would say your Toshiba will record an HD show but in SD resolution. I don't think the recorder has an HDMI input or a component video input. Just composite and S-video inputs. To actually record in HD you should look at another recorder.
Mar 19, 2011 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
I have a sky+ hd box connected to an lg 42LH300 tv through hdmi and an LG HT805SH home cinema through optical cable. Whenever i turn sky over i lose sound and have to turn cinema on/off to sound returns ...
One of the way to connect the whole system is using only HDMI cable version 1.3a. There is audio return channel built into the cable.So you do not have to connect the optic cable.
Sky box to TV using HDMI
LG HT805 to TV using HDMI. Even the Sky box audio will come back to the LG-HT through the audio return path.
Mar 08, 2011 | LG Televison & Video
I have surroundsound. I have dish network with hd dvr. I have a sony bravia hd tv. I have a dvd player, and cd player. I have a magnavox dvd recorder. I want to record from my dvr to my dvd recorder. ...
To get the functionality you're looking for you'll need to to take the cable running from your DVR output and connect it to the input on your DVD recorder. Next you want to connect a cable from your DVD recorder output and connect it to your TV. If this is an HD set up you want to use HD Cables for all of the connections.
Daniel Busa
DISH Network Customer Service
Jan 03, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Wharfedale DVD recorder, no sound. Scart lead connected to Sky Box & scart connection to TV. Picture OK & can play DVD's or record to HD but no sound.
HI if you mean scart connectors on rear of DVD recorder, try swapping scart inputs on DVD recorder and if no joys then on set top box. (some units have 1 input designated for TV and the other for Set top box input)
Mar 16, 2010 | Televison & Video
I need a wiring diagram to connect a samsung tv, sky+HD, DVD recorder, Wii and Playstation 3...thnx
all you have to remember is out of one into the other IF got Ariela on house that goes into sky then out of sky in to DVD recorder and out of that and into tv
on back of sky hd if you are going to use HDMI cable put cable into sky box and other end into tv ( you will have ot put tv on HDMI input/source)
or use scart lead in stead
THIS DEPENDS ON HOW YOU WANT TO CONNECT PLAYSTATION
everything else is colour coded
Nov 08, 2009 | Samsung 37" 720p Flat-Panel LCD HDTV
With the new HD transfer. We just have atenna...we just bought a HD TV. Is there a way of connecting the DVD Recorder so I can watch one channel and tape another with this new system
A lot of your question depends on your DVD recorder, but there IS a way to connect them so you can watch one channel and record another one.
First - if you have an HD compatible DVD recorder (one that will allow you to select channel 8, 8.1, 8.2, etc) then you could simply split your antenna signal BEFORE the TV or DVD recorder. Then you can select one channel to watch on your TV while selecting and recording a different channel on the DVD recorder. If your DVD recorder is connected to your TV's Video Input, you should be able to monitor DVD recorder's activity by selecting the "Video Input" on your TV.
If you DON'T have an HD DVD recorder, then you will need to get a converter box to put between the Antenna signal and the DVD recorder. You can then set the converter box to the channel you want and the DVD recorder can be set to record it.
Jul 08, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Cant record sky
connect it to the box with a SCART lead, select A1 or A2 with the channel up / down buttons and away you go
(select A3 if you use the phono connectors under the front panel)
Mar 01, 2009 | Panasonic DMRES20D DVD Recorder
Colors out of Whack on HD input 4 only
May need higher quality component HD cables? Tried switching Blue on Red? Just some thoughts.
May 02, 2007 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
286 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
