Mac-Compatible Impact Printer???
I need to print from a mac-based Filemaker file to a 4-part NCR tractor-fed form to a dot-matrix (AKA impact printer. I can only find Windows & UNIX-compatible .
  • Cuffur Oct 30, 2008
    I do not have a printer yet. I am looking to buy a dot matrix printer to print a 4-part NCR continuous feed form with the tractor feed capability.
    The finished form size is 8.5 wide by 5.5 tall, with the fan-fold tractor perfs on the sides, the form is 9.5 wide.
    Many dot-matrix printers are available to do this but none I have found are compatible with a Mac OS.
    Okidata has a workaround using a networkable printer running on IP/TCP protocol thru a browser (FIREFOX?)
    Being a Mac person, I don't go much deeper (computer-wise) than plug and play.
    Thus...
    Help.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Do you what the model number is on the printer?
    Is this printer using the round apple serial interface cable?
  • 2,794 Answers
Okidata works pretty good for 4 part forms. I've worked on dot matrix printers in the past and found that a lot of them jam with that big of a form and eventually burn the motor out a lot faster. Not a problem to handle on an Okidata.
I have yet to find a USB interface for one so that might be a challenge. Apple used to use a round serial interface. You might be able to find a workaround for that using a USB hub. I have a Belkin one at home that carries an Apple serial interface.
Another idea that could work is to use a parallel based print server with a eternet port on it. Then you can run it on a TCP/IP. The only time you need to use a browser is for administration setup on the print server by typing in the TCP/IP address into the browser.
Safari can work in place of Firefox. Make sure the printer server has Mac drivers for it.
Posted on Oct 31, 2008
The dot matrix will print out two invoice sheets before printing out ink on the third one
Replace your ribbon and make sure it's moving. Usually with an impact printer the reason this happens is because the ribbon has stopped spinning.
Aug 17, 2015 | Epson LX-300+ II Matrix Printer
Gerror 913 en lso archivos201 segenera por tener archivos desatualizado
Obten los controladores de Windows o MAc y actualiza tu printer.Si continua el problema escribeme.
Windows Operating Systems spacer.gif [+] Generic 9-Pin Printer Driver v1.0bEs
Windows 98, Windows 95, Windows NT 4.0, Windows NT 3.51
epson10753.exe - 559KB - posted on 05/29/03
[-] Generic 9-Pin Printer Driver v1.0bEs
This self-extracting file contains the Generic 9-Pin Printer Driver for Windows 95, 98, NT 3.51 and NT 4.0 (Printer Driver v1.0bEs, Core Driver Disk v1.0). This file is for use with all Epson 9-Pin Dot Matrix Printers.
Note: Please have your Microsoft Windows CD-ROM available as the printer driver may require some OS files from the CD-ROM to complete the installation.
downloads_icon.gif Download Now
Windows 3.1
ep10759.exe - 527.2KB - posted on 05/29/03
Windows 3.1
This self-extracting file contains the Generic 9-Pin Printer Driver for Windows 3.1 (Printer Driver v1.0bEs, Core Driver Disk v1.0). This file is for use with all Epson 9-Pin Dot Matrix Printers.
Note: Please have your Windows 3.1 installation disks available as the printer driver requires the "unidrv.dll" file to complete the installation.
Macintosh Operating Systems spacer.gif [+] Network Printer Driver v2.0A
Mac System 7
EPRINT2N.SEA.hqx - 779.1KB - posted on 06/12/96
[-] Network Printer Driver v2.0A
Mac System 7
This self-extracting file contains the EPSON Print! 2 Network Printer Driver files for the 9-pin ESC P2, 24-pin ESC P2, and the DFX printers.
[+] Printer Driver (Serial) v2.0A
Mac System 7
EPRINT2S.SEA.hqx - 610.1KB - posted on 06/12/96
[-] Printer Driver (Serial) v2.0A
Mac System 7
This self-extracting file contains the Epson Print! 2 Printer Driver for serial connections with 9-pin ESC/P2, 24-pin ESC/P2, and the DFX printers.
Dec 17, 2010 | Epson FX 1170 Matrix Printer
6-part NCr paper form being used. Pages 1 and 2
This is a problem with your paper. Using multi-part forms on an impact printer will get lighter print on each layer working from the top form to the bottom. The "carbon" paper has to impact the paper hard enough to make the marks. If your top and bottom copies look good but some in the middle are light it is a problem with the "carbon" paper and not the printer.
Now IF the top page is light and each copy under that is getting lighter then you need to close your platen gap (the lever on the right side of the machine mark A B C) go one click at a time (darkening) until the print quality looks good (or you go too far and it pinches the paper and jams *not good*)
Feb 16, 2010 | IBM Infoprint 6500 Matrix Printer
How do I get the macaddress of the Epson LQ-300+II?
If the dot matrix printer does not have a built-in network card then it will not have a MAC address. Dot matrix printers are very old printers and I have not come accros any with built-in network card or print servers.
The dot matrix can be connected to a network print server and this will have a MAC address and a configurable IP address.
Oct 22, 2009 | Epson Dot Matrix LQ-300+II Printer
Difference between dot matrix printer and laser printer
1. Dot matrix as the name suggests prints in small dots. The print out u get in railway tickets. 2. Laser printers are very speedy and have clear and sharp printing. There is no comparison b/w a laser printer and dot matrix. If dot matrix is 1st GEnaration than laser is atleast 10 generations ahead
Aug 20, 2009 | Absolute Software ComputraceComplete for...
Layout/Printing issues
FileMaker 5.5 is a long time ago for me, but I think I will try to answer your question (although it is likely you have a solution or no longer need one.) While in layout mode, while working on the layout, go to printer setup and choose the printer and page size you will be printing to. This will cause FileMaker to have a dashed line where the printer pages are on the layout. Anything that extends over these lines will require additional pages to print. Simply bring everything back in before these lines to limit to 1 page (including the blank space at the bottom of the page. There is a tab you will need to drag above the page break line to prevent a second page from printing. Additionally, if you cannot work it out, while printing from FileMaker if you choose the page range of 1 to 1, only 1 page will print, however, doing this prevents you from printing additional records without writing a script to do it. However, if you are able to redesign the layout to only print 1 page then you will notice there is an option on the print dialog box that indicates something to the effect of "Print current record" and "Print records currently being browsed" (Don't remember the exact wording in FileMaker 5.5); Choosing the records currently being browsed option will print all records in your current found set.
I hope I've done a good job answering your question. I am a FileMaker expert for version after 7 and have used Filemaker since version 4; if you have any additional questions I will do my best to answer them. If my answer was helpful for you I'd appreciate a 5 thumbs up rating, or a click on the yes this was helpful button. Thank you!
Apr 06, 2009 | FileMaker Server 5.5 (540100U) for Mac, PC
Tvse nova 130 printer drivers needed --cannot print from vista
TYPE IN ADDRESS BAR
MANUFATURES NAME, MAKE, MOLDEL, DRIVERS
ROD
Feb 09, 2009 | Office Equipment & Supplies
No external drivers are required for this. select from your windows driver list epson lsp 100 will match exactly with it.
Feb 09, 2009 | 2005 TVS Star
Dot matrix printer. very light print on last page of form
Hi and welcome to FixYa,
Based on your description, the printer is working, it is not a form issue, the printer head is good, an adjustment might be needed and it works, there is no reason to replace the Lexmark 2381plus printer even if it is 7 years old (not unless you would want to).
To the faint printing on the last of the 3 pages:
  • the take-up spool/wheel drawing the ribbon is not working (most likely). The ribbon is not moving hence the printer head is not striking fresh ribbon area. Check the ribbon cartridge, it may be stuck or the driving spindle where the ribbon's take-up spool/wheel locks into. It may need a bit of cleaning and/or lubrication;
  • the printer head is slightly adjusted away from the paper. Normally, there is a mechanical lever/adjustment that sets how many paper & duplicates are fed. Adjust for 1 only.
Good luck and thank you for using FixYa.
Jan 30, 2009 | Lexmark 2381 Plus Matrix Printer
695 people viewed this question
k24674
jasbo
jasbo
