Question about Arris SURFboard SBG900 Wireless Router (DHSBG900)
Wireless Doesn't Work - No light.
Purchased this modem and every light is doing what it's suppose to do but the wireless. It has never lit up, yellow or green. I tried to connect my cell phone (tmobile shadow), but it cannot pick it up. Is there anyway to fix it? or I get a dud.
    Scholar:
  • 87 Answers
If someone else setup the router for you they may have turned off the wireless. If you can connect via ethernet use the web based configuration utility to turn it back on.
The intial setup is as follows in the manual:
To provide an initial wireless connection to your network and the Internet:
1 Connect the SBG900 to the cable TV system as described in Section A.
2 On each wireless client computer, install the wireless adapter hardware and
driver software according to the manufacturer's instructions.
3 On each wireless client computer, set up a wireless adapter profile to
“connect” the client to the SBG900. The procedure depends on your
wireless adapter and computer operating system.
In your initial profile, use the SBG900 default wireless Network Name
(ESSID) motorola (case-sensitive).
Your computers are connected but not secure.
The default SBG900 settings provide no wireless security. After
your wireless LAN is operational, be sure to enable security as
described in “Setting Up the Wireless LAN” in the SBG900
User Guide
Posted on Oct 30, 2008
My D-Link dap-1160 is not working
For routers not just the power light that should be lit. Are you using a modem/router? If so, there should be a DSL,INTERNET,WIRELESS light indicator as well. If the DSL light is OFF,steady red, OFF there might be trouble with your line connection. Call your Internet provider. Also, check cables (yellow cord, gray cord, telephone cord) that should be connected tightly to where it supposed to be connected.
Feb 26, 2013 | D-Link DAP-1160 802.11g Wireless G Open...
I purchased a SBG901 and have connected 2 MAC pc's wireless - 1 HP printer and 1 Compag laptop, I have one more pc which is running Vista on a HP Pavilion dv5 and visited the HP website to update
It might not be anything your doing wrong, the wireless portion of the card may have just gone bad. you could check this out by reconnecting your old router back up to verify it works or doesn't. If it doesn't work your wireless in your laptop went bad presuming that the wireless was not deactivated on the laptop. if it does work the Vista Driver may be incompatible with the new router, you may be able to hook up both routers at the same time which would allow you to keep using your HP system.
Feb 28, 2012 | Arris SURFboard SBG901 Wireless Cable...
How to plug a WNR1000 Wireless Router into a Hughes net HN7000S modem
It should connect with an Ethernet cable. Looks like a phone cable but is twice as wide with 8 pins instead of 4. Plug one end into the modem's Ethernet output port and plug the other end into the router's single WAN/Internet input port.
Nov 09, 2017 | NetGear Computers & Internet
How many lights should be on my westell model327w?
The Westell has several lights on the front that have various meanings
Power = When lit, this light indicates there's power to the router. It should be solid green.
Ethernet = When lit, this light indicates that the modem is communicating with your computer. This will be on only if you're using the Ethernet cable to connect the modem to your computer
Wireless = When lit, this light indicates that the wireless function of the Actiontec is working. This will only be lit if you're using the wireless function.
DSL = When lit, this light indicates the modem is speaking to the central office (phone company). When working, the light should be solid green.
Internet = When blinking, this light indicates that you're receiving information i.e., you're able to browse from site to site. This light will be blinking as you're receiving information.
Sep 16, 2010 | Computers & Internet
N Wireless Modem-Router F5D8633au4A: every light on my belkin N wireless router is on e...
WIRELESS LIGHT WILL LIT UP IF YOU CONNECT ANY ANY WIRELESS DEVICE TO THE ROUTER.. FOR EX: YOU CAN SEE WIRED LIGHT LITTED UP BECAUSE YOU CONNECTED A COMPUTER WITH HELP OF ETHERNET CABLE.. IN THE SAME IT WILL WORK...
May 17, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
I just bought a Belkin Router Model # F5D8236-4. I have everything wired correctly, but the wireless light does not come on. I can't get the internet to come on to the computer I want to connect to? What...
Wireless light will lit up only if any wireless computer is connected to Belkin's wireless network.
First, connect to Belkin's wireless network that you can scan.
After you connect, try to go online
It ll work...
Jan 21, 2010 | Belkin (F5D8231-4) Wireless Router...
Siemens SpeedStream 6520 Wireless problems! please help
um not sure, but if you have the disk that came with your router run it and fill in the wireless wizard. Also, on my 6520 the "wireless" led doesnt light up unless i have a device connected that is wireless. Your laptop may be incorrectly setup
Jun 25, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
I want the wireless light to be on. its the only light thats off
if all the lights on the modem are Green then it means there's no prob with the hardware. just make sure that you're going to use the right WEP key or wireless password. the network name is 2wirexxx, the X is the the last 3 numbers of the SN which can be found on the bottom of your 2wire modem.make sure that your wireless switch is also turned on of course. the wireless light on the modem will lit if it is connected
May 09, 2008 | 2wire (1000-000057-000) Modem
2701HGB modem - dsl light flashes red
if all the lights on the modem are Green then it means there's no prob with the hardware. just make sure that you're going to use the right WEP key or wireless password. the network name is 2wirexxx, the X is the the last 3 numbers of the SN which can be found on the bottom of your 2wire 2701HG-B.make sure that your wireless switch is also turned on of course. the wireless light on the modem will lit if it is connected
May 07, 2008 | 2wire (1000-000057-000) Modem
Arris SURFboard SBG900 Wireless Router (DHSBG900) Logo
399 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
jimmy Leo
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
