My Denon AVR 1803 turns itself back to standbye with a red blinking light within seconds of powering-up Is this fixable, or would it be too costly?? Thankyou
  • andy-t007 Feb 25, 2009
    Hi I have the same problem, but didn't understand what xtors are?
    I have checked internal fuses and all is ok, how can I discover what circuit is dead and does this unit require all speakers connected to be able to work ?
    THanks
    Andy T
    Sergeant:
    Champion:
  • 227 Answers
Hello runj69 your receiver is going to standby because you have a problem in the output ckt, the first thing is to check the connections to make sure no speaker are touching and if not you need to repair the output ckt, most of the time are the xtors.
caypianan@yahoo.com
Posted on Oct 31, 2008
When I power my Denon AVR-3311ci on, it only comes on for a second then shuts off completely. No blinking red light and nothing on the display. I can hear a relay on the power board clicking. Any ideas?...
There's an electrical problem! The unit shuts off to protect itself. the relay sound is normal and is part of the power supply - good quality amps have them. I suggest taking it to your local repair shop.
Feb 17, 2015 | Denon AVR-3313CI
How can I connect my I pod Touch to my Denon AVR 1803 reveiver?
Connect the 3.5mm cable to the iPod headphone output and the two RCA plugs into any unused analogue audio input on the Denon AVR 1803. Then choose the appropriate input on the Denon, press play and enjoy the music. Be careful about volume. Start with the volume on the iPad low and adjust to suit.
Cheers, Don.
Aug 07, 2014 | Denon AVR-1803 Receiver
Does not turn on
If there is no reaction at all on standby button, the receiver most likely has a problem with standby power supply or mcu. If you get flashing red standby light, there is a problem with one of the channels or main power supply. Either case you need to bring it to a reoair facility.
Dec 10, 2011 | Denon AVR-1803 Receiver
My denon avr 1803/883 shut off while playing a cd that had only been in for 5 minutes. there have been no changes to the inputs or additions to speakers. atthis time when i turn it on it is on for about 10...
CHECK IC101 AND IC102 THESE ARE THE + AND - 15VOLT REGULATORS. iF THEY ARE OFF BY MORE THEN 3 VOLTS IT WILL SHUT THE UNIT DOWN/IC101 IS THE +15V AND IC102 IS THE -15V IF THESE VOLTAGES ARE GOOD THEN THE UNIT IS GOING IN TO THE PROTECT MODE AND YOU WILL HAVE SHORTED OUTPUT TRANSISTORS. I HOPE THIS HELPS YOU.
Mar 27, 2010 | Denon AVR-883 Receiver
Shuts off then red light indicator flashes, disconnected all speakers but still wont work
Hi, this is a power board issue. remove the cover and make sure that this unit doesn't have blow fuse. if the fuse is fine, you will then need to replace the integrated power/ main board.
May 21, 2009 | Denon AVR-1803 Receiver
Denon AVR-1803 keeps shutting down
check your speaker wires make sure none are touching each other this will cause a short and shut the reciever down
Mar 17, 2009 | Denon AVR-1803 Receiver
My denon AVR 1803 WON'T TURN ON
First make sure you you have the power plug plugged into the unit and a hot 110 outlet, press the on/standby button on the front of the unit and if no power return to store
Feb 23, 2009 | Denon AVR-1803 Receiver
Denon Avr-1803- multiple room audio difficulties!
it is true pre amp check your cables and confirm in (avr-1100)that you select the right input.
May 27, 2008 | Denon AVR-1803 Receiver
Blinking red power light
I think Denon designed in a "bug" as mine just "went east" today
May 25, 2008 | Denon AVR-1906 Receiver
298 people viewed this question
 Grubhead
Grubhead
