The cable that is used in the headphones is actually very low quality and very weak so easily broken, You may be able to remove the wiring from another pair of headphones and use it.
Unfortunately Skullcandy are not a high end brand so no spare parts are really available as they are made in china as you can see on the following link.
Link:
SOURCE: how do you fold lowrider headphones?
It's easy,
Step1: rotate the earpeices so that either the cushions face up or down
Step2: fold one side inwards by bending the rotating elboe inwards, this elboe is located one inch above the top of the cushion
Step3: now do the same for the other side
Step4: as you fold/rotate the second earpeice, do so in a way that this earpeice lies underneath or ontop of the first folded earpeice
Note: as you do step 4, you will notice that the middle of the top band starts to bend to accomodate the motion of this folding process
Add. Note: the mic may be sticking out at an odd angle by now, rotate it towards the rest of the mass that is now your folded headphones...... now they are ready for your pocket
SOURCE: Jack plug broken off
Buy a $4.00 1/8" jack replacement from Radio Shack - part # 274-0869, which has small screw connectors that don't need soldering.
Strip about 1" of the braided insulation at the old jack end, which will expose 4 very small wires: Blue, Green, Red, Copper.
Attach the Green & Copper wires to the tallest pin on the replacement jack.
Attach the Red to the shortest pin, and the Blue to the medium pin.
Remember to slide the jack cover onto the headphone cord before attaching any wires!
This works great, I just did it.
SOURCE: How do I set up my Skullcandy Lowrider head set
if you go on there site you have got to change some settings on x box live. here is the link. http://www.skullcandy.com/manuals-and-drivers.html it is the x box settings for lowriders.
SOURCE: My skullcandy lowrider left headphone won't work on my iPod touch
Try messing with the plug a little. Otherwise the wires somewhere might be messed up. That happened to a pair of my earphones, some of the wires at the plug broke so I wasn't getting sound out of the left side.
SOURCE: Skullcandy lowrider xbox 360 headset microphone
Either it's not plugged in all the way or there is a short in the line somewhere. I would pop the ear cover off to look at the wiring, it could have come unsoldered.
