Question about Jenn-Air JMC7000 Microwave Oven
Replacing a Jenn-Air Microwave Oven
I'm trying to find a replacement for a Jenn-Air microwave model M170B. It is a built-in "microwave over wall oven" unit. I called Jenn-Air and they told me I had to replace the whole unit. the oven is fine but the microwave has gotten old. Has anyone tried to replace this model microwave and what model did you use?
  • 3 more comments
  • Anonymous Nov 01, 2008
    I have the same problem!
  • Barb21 Jan 05, 2009
    I have the same problem. We went to Lowe's where they gave us the number for Whirlpool: 1-800-442-1111. Evidently Whirlpool now owns Jenn Air?. I plan to call them. Lowes said the price for the entire micro wave oven and oven unit is $1800!! We can buy a microwave oven for $100
  • kate george Jan 12, 2009
    I have the same unit. My $3 broken button is turning into a very expensive dilema. Since the model is discontinued, so are the parts. Were you able to find something the exact size to fit in the cut out? Otherwise, the trim kit won't work and it sounds like it's neccessary to replace our perfectly fine oven below as well.
  • Anonymous Jan 17, 2009
    I have the same problem and apparently there is no replacement for this model.
  • kseshadr Apr 18, 2009
    I called Whirlpool - they couldn't find a replacement. The dimensions to fit in the trim are 22" (width) by 14 1/4 height
    That is pretty sad that they now expect you to buy a new mw/oven combination!
5 Suggested Answers
  • 9098 Answers
SOURCE: Jenn-Air JMC7000 Microwave Stopped working
So it's dead? (No display, no inside lights, no beeps?)
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open. When it cools, it closes the circuit and allows power through again.
If it's random, it may be a bad connection, usually on the control board or fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya:
You can find helpful exploded view diagrams and order parts by entering your full model number here:
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Posted on Nov 18, 2007
  • 9098 Answers
SOURCE: Removing a built in Jenn-Air Microwave from it cabinet...
First of all, what are the symptoms? Please reply back and I'll be happy to share my thoughts.
Many parts can be accessed without removing the oven from the wall by just removing the control panel.
You need to be sure the cord is unplugged, then you remove the vent grille that runs across the top.
Then you'll see a screw holding the control panel in place. Once that screw is out, you can lift out and out carefully to separate the control panel form the chassis.
If you pull any wires off the control panel, mark and/or photograph them first to be sure you get them ALL back in the right place.
There may also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
Before you start, we have *critical* safety & disassembly info at our site. You'll find a link to our site in our listing here on FixYa:
While they don't have their installation instructions online, the owner's manual is online here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 31, 2008
  • 100 Answers
SOURCE: home warranty company saying JennAir M166 built in microwave isn't a true built in
Bottom line is... Home warranty companies will do anything possible to wriggle out of paying for something. (Especially if it's American Home Shield).
I'd suggest offering to fax / email photos and the front cover of your owners manual. Your model is 100% considered a built in unit and they are lying to you and trying to cheat you if they say otherwise.
Posted on Aug 24, 2008
  • 4088 Answers
Look for a reset button on the back--push to reset. If trips again, unit has probable short.
Posted on Jul 12, 2009
Jenn air wall oven
Your microwave oven probably has been living on borrowed time since 2010. Consider replacing it.
Oct 05, 2016 | In Microwave Ovens
I have a old jenn air wall oven and a old jenn air microwave mounted on top. it was a countertop model. when i removed it it was plugged into the top of the oven. would that be a 110 appliance outlet?
The Jenn Air microwave that is mounted above the oven in your unit is 110v 60Hz. The socket in the upper rear right corner of the oven is a 110v 6Hz socket and is where the microwave would be plugged in. If you are going to replace the microwave, you can plug it into that socket. If you would rather not use that socket, you will have to drill a hole in the side of the cabinet holding the over/microwave to get the power cord out.
Sep 29, 2014 | Jenn-Air Microwave Ovens
Jennair combo micro wall oven 30" replace microwave?
When a microwave is dead, the most common causes are a blown fuse, or a blown thermostat / thermal cutout / TCO on the magnetron or on top of the oven cavity.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Accessing the oven cavity thermostat for testing and possible replacement will require you to remove the oven from the wall and take off the outer cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Jenn-Air (Whirlpool) owner's manuals and installation instructions here.
Dec 25, 2012 | Jenn-Air JMC8130DD Microwave Oven
My JENN-AIR Microwave Oven stop working, no light is coming in front pennel, I checked power exist in wall outlet, I suspect some kind of fuse blown into microwave oven, my microwave oven make & model...
Hi, my name is Audrey and I am a Jenn-Air employee. I would appreciate the opportunity to assist you with your microwave. Please send me an email through our customer service address,
and type 'Attention: Audrey' in the subject line. Please include your full name, phone number, and model/serial number, and I will look into the issue for you.
Oct 26, 2010 | Jenn-Air JMV8208A Microwave Oven
Micro wave not working jen air
The Transformer is part number 56001221. I have run a search for the part and I am coming up with the same results, the pat is discontinued and no longer available.
Apr 24, 2010 | Jenn-Air JMC7000 Microwave Oven
Jul 11, 2009 | Jenn-Air JMV8208A Microwave Oven
Jenn Air JMC7000ADW
I would consider the
JMC9158BAW this is a 1.5 cubic ft, yours is 1.6, yours is about 24 inches and this one 24 inch, this model is a built in/countertop
the closet model you are going to find
Kitchenaid has the KBMS1454SSS 24inches comes with 27 and 30 inch trim kit
and KBMS1454S same specs just different model
May 01, 2008 | Microwave Ovens
Jenn-air microwave JMC 7000 ADB has no power
I have a different Jenn-Air built in microwave & oven combination but I'm sure my solution will work for you as well.
My microwave was plugged into an outlet located on the top of the oven. This outlet has a "circuit breaker" that tripped while we were using the self cleaning feature on the oven. You just need to reset the breaker button right next to the wall oven outlet. Why it tripped is a mystery since the microwave was not in use at the time. Bad design.
Of course, getting to the reset button is your only challenge. You need to pull the microwave and oven out of the wall/cabinetry in order to get to it. The unit is heavy so you will need help. Or, call a certified repairman and they should be able to do this for you in 30 minutes or less so the service call should not run you more than @$85 if it is no longer under warranty.
I would also suggest you contact Jenn-Air to complain about this issue and seek reimbursement from them if necessary.
Dec 17, 2007 | Jenn-Air JMC7000 Microwave Oven
Jenn-Air JMC7000 Microwave Oven Logo
1,456 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
