I have new LCD TV 32LG5000 I want to setup picture mode from vivid to standard, cinema, sport etc mode but after while the tv reseting the picture mode back to vivid mode. I tried setup everything what is possible but unfortunately the tv still reseting the mode to vivid. Can you please help me?
  • 48 Answers
SOURCE: Sony KF-50WE610 LCD projection TV. no picture but flashing green
Replace the lamp as they dont last for long
Posted on Feb 01, 2008
Astrobyte
  • 110 Answers
SOURCE: Picture gone from TV Model LE46M51B
I suspect that your backlight has gone out. If you shine a light on the screen can you see remnants of the picture that should be displaying? If so, it's definitely the backlight, and most likely the power inverter for the backlight. You can probably find a replacement inverter, but you may need a repair manual to install it. I'd recommend checking the warranty status first and sending it in for repair if you can.
Posted on Feb 17, 2008
SOURCE: Samsung ws28v53n
Just found out from Samsung UK that my boards have blown and will be expensive to replace. He also made me aware that the new LCD TV's have a life span of 3700 viewing hours which is only 4 half years, not made to last like the old tv's.
Posted on Feb 29, 2008
madmitch08
  • 10 Answers
SOURCE: can't find best picture setting with the default options
try and see if u can find a bak light...switch it on should be better once u find it...in the menu...
Posted on Dec 17, 2008
SOURCE: setting up 42lg3000 with sky
i have same tv, this i was i did on mine. on the sky+ remote push tv and then press select + red button at the same time, the red light blinks twice, then push 1174 then power button.
Posted on Jan 07, 2009
I can't get the color right. What are the perfect setting?
Hello!
Have you tried preset picture modes off TV's "picture" menu or "picture" on remote control unit. Most modern sets have "preset" modes: normal, vivid, natural, movie, sports, user, etc. Try to toggle between those modes. may be the one of those will look right for you. Make sure: "user" mode is for custo adjustments. You must choose desired settings: "picture(contrast)", "brightness", "color", "tint", "sharpness", "color temperature". May also have: DNR(dynamic noise reduction", "black level expansion", etc. I'd try presets, first and make notice of those settings. If that is, still not right to you, you may be able to tweak "user" mode the way you like it, based on info from other modes. If that won't help, you may have an issue with your TV.
good luck,
thanks,
Alex.
Sep 13, 2011 | Toshiba 19SLV411U 19 in. LCD TV/DVD Combo
I have sony 50E200A,there is problem with colour combination/mixing....green colour is too bright.please tell me how to resolve this problem.thanks
You need to calibrate the colors
The first step in calibrating your television lies in paying attention to your surroundings. Sit in the same spot you'd normally sit in to watch your TV. Then, make sure the lighting is at the same level you'll be using to watch movies: setting your TV to overcompensate for a brightly-lit room may give you distorted results. Watching in complete darkness may cause undue eyestrain, but a dim, diffuse light behind or to the side of your LCD TV is best. Just make sure to avoid any glare or reflection on the screen.
Next, be sure your display has "warmed up" for at least a half hour before attempting any calibration; this is to ensure that all the components of the display are at normal operating temperature and best approximate normal viewing conditions. You can take this time to familiarize yourself with the various display controls on your particular TV--get the manual out if you have to. The better you know which controls are available on your LCD TV, the better your end results will be. Though different manufacturers give different names to the controls, these are the levels you'll be adjusting:
  1. Black Level, normally found on the Brightness control
  2. White Level, usually called Contrast or Picture
  3. Sharpness, or sometimes Detail
  4. Color Saturation, usually labeled Color, or maybe Chroma
  5. Color Tint, also known as Hue
Beyond these basic settings, many modern TVs come packed with so-called "picture enhancements" which in reality do nothing but spoil an otherwise accurate, lifelike picture. Take a moment to dig through your TVs menus and disable any of these "features." What you're looking for is anything labeled edge enhancement or detail enhancement, flesh tone or color "correction," etc. This is a broad generalization, but basically anything not listed in the five controls above can be safely turned off. Another thing to check for is often called a "Picture Mode," or something similar: in reviews, we often find best results from a Movie or Cinema mode, which usually gives the most accurate picture with the least "enhancement." A Normal mode is a safe bet when this isn't available, but definitely avoid anything called Vivid, Dynamic, or Sports mode.Sports mode may make the grass look nice and green, but unless you're watching The Masters, it's probably not that green in real life; Sports mode is just ruining the color.
On a similar note, have a look at the options available for your LCD TV's backlight settings. Like many of the settings, the backlight is probably set to its highest brightness, which is probably too bright for comfortable extended viewing, and shortens the lifespan of your LCD TV as well. Drop this setting down at least to it's "normal" value, or even try out the Low Power or Power Saver option if it's available (in dimly lit rooms).Finally, a word about Color Temperature. Without getting into the rather complicated science behind it all, Color Temperature basically refers to the peak wavelength of a light source, which affects the color tint given to images which should be "pure" white. Suffice it to say that while most video is produced to what's called a "6500K Standard," (6500 degrees Kelvin), not every TV comes out of the box set to display that standard properly. In fact, factory settings are very rarely are set close to 6500K.
Dec 12, 2010 | Sony Televison & Video
Adjusting color/ user mode??
The TV will not let you set brightness, contrast, color or tint in the preset modes like Vivid, Movie, Standard etc. Look for a mode that says custom, user etc..
Nov 11, 2009 | Olevia LT42HVi 42 in. LCD Television
Att uverse receiver hooked up to sharp aquos tv, remote quits
first try new batteries and be sure you have pressed the AT&T mode button at the top left of the remote - if you still have issues then on the sharp tv menu - turn off any energy saver mode, Optical Picture Control, taking the picture mode from dynamic or vivid to standard, and if that doesn't work - try changing the backlight settings if your tv has one.
Aug 23, 2009 | Denon AVR-1908
Picture setting reverts to Vivid
LG replied to my enquiry abd apparently the TV was in store mode. Just required a factory reset,...seems to have done the trick !
Jun 03, 2009 | LG 42PG20 42 in. Plasma HDTV
TV PICTURE SETTINGS REVERT BACK TO DEFAULT LG 32PG6000
hi it sounds like when tunned in tv it was tunned in shop mode.
do a factory reset and choose home when installing
Feb 25, 2009 | LG 32LG30 32 in. LCD HDTV
RCA D52W20 Too Dark :(
you may need the tubes cleaned and setup
Jan 29, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Can't find best picture setting with the default options
Dec 17, 2008 | LG 37LG30 37 in. LCD HDTV
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
