Question about Samsung SyncMaster 172N 17" LCD Monitor
Samsung 172N 17" LCD monitor blacks out seconds at a time with increasing frequency and eventually displays scrambled graphics until system restart.
I know this is not an isolated problem as my friend has the same monitor and it has the exact same problem. In both cases it only manifested after the monitors were about two years old. I have also noticed by internet search that other people have had the same problem with the same model monitor. I have tried latest drivers and even removed Samsung drivers so that the monitor runs on winXP drivers with the same result. Any input would be appreciated.
  • Anonymous Oct 31, 2008
    Yes I have the same problem with two identical monitors
  • Anonymous Dec 16, 2008
    well, i dont know, but a problem could be the wiring, as my monitor
    sometimes flickered for some weird reason, but its completly fine now
    and i didn't really do anything. i had my monitor for SEVERAL years now
    im its working up to speed. who knows, could have been a spot of bad
    luck. good luck =P
The problem I have is that when we connect the screen it wiorks fine then blacks out after 5-40min
It then flickers on and off iregularly and every now and then shows distortion and eventually just blacks out
I have two 172N monitors and both now show the same symptoms
We have used different VGA cables and different computers in different locations all with the same result
There is no external influence that we know
Posted on Oct 31, 2008
Samsung syncmaster 172n inverter
http://www.radioradar.net/en/service_manuals/monitors_circuits/mstar_semiconductor_samsung_en.html
Jun 21, 2014 | Samsung SyncMaster 172N 17" LCD Monitor
I have a Samsung SyncMaster 172n monitor and the screen stays black when I turn the power on. The power light starts flashing about 3 seconds after I turn it on. All the power cords are plugged in, the...
When the monitor starts up you should be able to see the Samsung screen logo, if not it does point to the monitor. But lets be sure! hook a spare monitor to the computer, if it is okay! the Samsung Monitor is the problem and is not cost effective to repair, cheaper to replace. Now if both screens show the same problem, this indicates the Video Graphics Card in the computer is the culprit.
Jan 19, 2011 | Samsung SyncMaster 172N 17" LCD Monitor
Screen doesn't light up ! Green led is on for a few seconds and then gone ... ? Thanks for help .
When you turning on your computer and when you heard a 1 beep that means your computer is functioning, but 1 beep with no display that means you need to check you monitor or try to transfer your lcd monitor to other computer to check if your monitor is working.
Nov 12, 2010 | Samsung SyncMaster 172N 17" LCD Monitor
Samsung LCD monitor (SyncMaster 710v) displaying white stripe.
hi,
your lcd micron tube in the panel had already worn out.
got to replace the panel
Jan 21, 2010 | Samsung SyncMaster 172N 17" LCD Monitor
My monitor flickers then goes black
It could be the capacitors on your monitor's Power Supply. Open up the lcd and check the power supply board see if you see any "BULGED UP" capacitors. If thats the case you most likely just need to replace the bad capacitors. Go to radio shack or electronics supply store buy the same capacitors with the same mF and volts. If you can't find the same ones then always go with higher voltage. Replace the bad ones with new ones following this video. Make sure you note the negative terminals on the CAPS before you remove them. The shorter side on the new CAP is always negative.
Feb 19, 2009 | Proview PL913B 19" Flat Panel LCD Monitor
SAMSUNG SYNCMASTER 172N
Try to unplug the monitor on your pc then you if you see no signal there is no problem with your monitor maybe the problem is the graphics card or the driver installed
Jun 02, 2008 | Samsung SyncMaster 172N 17" LCD Monitor
Very Dim display
If you have tried all the usual adjustments (brightness etc), then the inverter board or the backlight itself is bad.
It's pretty hard to tell which one it could be, given as they are both related (the inverter board powers the backlight)
I had that happen to a few 192N's, and it was a bad inverter board in both cases.
Feb 08, 2008 | Samsung SyncMaster 172N 17" LCD Monitor
Monitor
is your monitor connected to any system? beside the power supply? Try to check the connections.. you may need to explain further of the system that you are using....
Aug 20, 2007 | Samsung SyncMaster 172N 17" LCD Monitor
Samsung SyncMaster 172N 17" LCD Monitor Logo
582 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
