I have a p4s800 asus motherboard in my computer and I would like to turn of the onboard sound as i am having a conflict with my audigy sound card, the computer re boots
  • zoratto Oct 31, 2008
    Thanks for your help, but I still cannot find the audio anywhere in the Bios to disable the on board sound, My Motherboard is an Asus P4S800
  • 41 Answers
You want to hit the delete button at start-up or what ever key-combo that you see at start-up to enter the bios setup..the bios will open after a sec.. just hold the key or keys to enter. Don't change anything you don't know about, just look for were it says integrated peripherals and turn off the audio.
You should see audio and video in there, don't turn off your video unless you have an external video card your installing to... Just look to find audio that says enabled and disable it if you can't find the integrated peripherals. That will turn off the audio on the motherboard so your sound card has no conflicts anymore and should work without a hitch...If after that you have problems you should reinstall the drivers for your sound card as WINDOWS probably messed up your drivers... :) :)
Please say if this helped your problem....
Posted on Oct 30, 2008
  • Paul Oct 31, 2008
    PCI Configuration... Motherboard Manual page 2-21....
    Have A Nice Day.....
  • Paul Oct 31, 2008
    PCI Config.. Motherboard Manual page 2-21....
What is the bios setting if ever i will NOT use the onboard audio and instead install a sound card in an asus p5kpl-am/ps motherboard
You may need to go into the BIOS to turn off the on-board audio card so it does not conflict with the new audio card.
Sep 05, 2011 | ASUS P5KPL-AM SE Motherboard
I have a sound blaster audigy 24 bit 7.1 sound card . it worked fine on windows xp but when i inserted the card in the slot for my new computer on windows 7 it says that no card was found :/ when i install...
Move the card to a different pci slot on the motherboard. It may have a conflict with another device. Make sure there is no power to the pc when you do this. If you still have the problem after trying all the slots then i suggest you empty all of them and just try the audio card on its own. If it works then fit the card/s you removed into other slots. good luck.
Apr 27, 2011 | Creative Labs Sound Blaster Live 7.1...
Asus p4s800 beep codes. I get one long beep. I
The one long beep, this has something to do with the video card.
Can't really tell without the BIOS you are using !
Anyway, try removing the card and replace it. ( with anything, just to check. )
This is a good board, I have a ASUS P4C800 and you can't beet it.
P.S. Make sure all your memory is the same freq. and clock speed.
Good luck.
Oct 23, 2009 | ASUS P4S800-MX Motherboard
How to set up my 4.1 creative 4400 inspire speakers in asus P5QL-CM motherboard with windows xp. is it possible to tirn off the built in souncard and install a PCI soundcard? thanks in advance
Sure,install the creative sound blaster audigy 4 or whatever you got,plug in your speakers,& turn it on. Follow the instructions to install the drivers from the cd for the card.The onboard audio will be by-passed automatically when you install the card. If you need more help,write back.
Jul 10, 2009 | ASUS Computers & Internet
Ok I've bought a HD2400 PRO and am tring to install but it wont see drivers for card or install
ok I found the problem was that someone ie the person that threw this unit away really did not know enough as they had used some of the ram to support the onboard video and it wasnt until i looked at the setups that i discovered this so set all back to default settings and was then able to turn off the onboard video and turn on the agp card hope this helps someone sometime apparently this was done to overclock the onboard video silly bloke just threw away a good computer ha ha ha
Jun 06, 2009 | ASUS P4S800-MX Motherboard
I have no audio
did you do the drivers? does the sound blaster have the drivers?if the onboard failed the add on should work, if it's not broken. make sure you have the right driver. you can download them on creative labs website, or asus website for that board, but disable the onboard if you use the add in sound blaster. this should work, if you had sound before, also make sure no conflicts with sound devices. hope thi helps happy new year..
Jan 01, 2009 | ASUS K8V-SE Deluxe Motherboard
Motherboard connections asus p4s800 mx se
Here is a direct link to the manual...
P4S800 MX SE Manual
Here is a link, if you need device drivers
Answer the Pop Down Boxes...
Product: Motherboard
Series: Socket 478
Model: P4S800-MX SE
Choose Your OS (Operating System)
http://support.asus.com/download/download.aspx?SLanguage=en-us
Nov 23, 2008 | ASUS P4S800-MX Motherboard
I have a intel celeron dual-core microsoft windows vista home premium laptop with a sis mirage graphics card but i need a graphics card that has a t least 4mb of video ram can you tell me what card is...
  • CM9880/8CH Azalia Audio CODEC onboard (found on ASUS boards) - basic microsoft UAA function driver installed by Vista works but misses soundinput. Install latest ASUS/C-Media software (set compatibility mode to XP for the installer) > reboot > set multiple streams enabled > switch input from microphone to wave and back > reboot
  • Creative Audigy (standard) -- No built-in support, but it works with beta drivers from Creative's site.
  • Creative Audigy 2 ZS Platinum / Pro -- [http://us.creative.com/support/downloads/download.asp?sOSName=Windows+Vista+32-bit&region=1&Product_Name=Audigy+2+ZS+Platinum&Product_ID=9107&modelnumber=&driverlang=1033&OS=26&drivertype=0&Image4.x=38&Image4.y=15 * Creative SoundBlaster Live! Series. Works with special drivers found here http://www.ngohq.com/home.php?page=Files&go=cat&dwn_cat_id=20 (32 Bit)
  • Creative SounBlaster 2 Platinum Vista beta drivers found on www.creative.com
  • ECHO AUDIO - INDIGO DJ - OK but with strange routing in virtual outputs
  • Intel 8x0 AC97 (32 bit)
  • MSI Neo4 SLI Onboard Sound (CL 7.1) - Version: 5.12.1.506, (32 Bit)
  • nForce4 sound card - Version: 4.64, (32 Bit)
  • nForce3 (Realtek ALC850) - drivers obtained from windows update. (32 Bit)
  • Terratec 5.1 Fun PCI - sound works, controlpanel doesn´t work (32bit)
  • Terratec DMX 6Fire
  • SoundMAX Integrated Digital Audio (Tested with ASUS P4S800 Motherboard) - Needs latest drivers available to work correctly, otherwise install chipset drivers for AGP and IDE. Sound may skip and studder if not using the latest driver
  • anonymoose
    Oct 11, 2008 | Computers & Internet
    Asus motherboard with built in video
    Go directly to Asus & down load their driver software for you're onboard video card. Here.... http://support.asus.com/download/download.aspx?modelname=P4S800-MX&SLanguage=en-us
    SiS661 FX (chipset), Both are fore Asus P4S800-MX
    Sis963L (chipset
    SiS Real256E integrated garphics as per your manual.
    If you must have SiS's drivers you may not find them there.
    http://www.sis.com/download/agreement.php?url=/download/
    Mike
    Apr 12, 2008 | ASUS P4S800-MX Motherboard
    Computers & Internet Logo
    187 people viewed this question
    David Payne
    David Payne
