Question about Toshiba Satellite M30 Notebook
Charging I forgot to take my charger when I flew to Adelaide but my mum has a universal charger.Why won't it work on my laptop? we put in the right ends for my laptop.
  • hannarack Oct 31, 2008
    That's exactly what I don't seemable to find out.What is the correct voltage for the machine?
  • 36 Answers
Check to make sure it's the correct voltage for the machine.
Posted on Oct 31, 2008
  • Anrev Oct 31, 2008
    Input AC 100-240V 2A 50/60hz
    Output DC 15V 5A
I have purchased 3 weeks ago queensland Aldi Bath live Adelaide now Ph will not charge properly light flickers on off and nothing charger Ok tested taken battery out etc ASP 5000 Model No Please help I...
Gee
I hope someone understands your text writing with no punctuation because I had to read it 5 times just to try and make any sense of it.
You purchased an Aldi Bath in Queensland and now you live in Adelaide and your Ph is not charging.
I live in Perth & my iPhone charges OK
Good Luck.... if you can get anyone to figure this out!
Aug 06, 2014 | Computers & Internet
Telecom r100 battery
It could be one of these three things.
1. Bad port. Often in laptops these ports become loose.
2. Bad battery.
3. Bad charger.
Borrowing either a universal power charger, or the charger from someone with a similar laptop, can eliminate some of the possibilities unless it is indeed your charging port.
If after plugging it in, the battery charges you know you had a bad charger. If the battery fails to charge, you know its time for a new battery. Again this only if the port itself is not bad.
Universal chargers can be expensive. You can find batteries and chargers on Ebay for a decent price.
Mar 01, 2014 | Dell Computers & Internet
My laptop not charging
When you say it won't charge, does it charge at all?
1. It indicates that it is charging, but as soon as you unplug the charger the battery quickly or immediately indicates it is dead. If the laptop is off, the LED on the laptop shows it is charging but the battery is always dead,
Or: 2. It is as if you didn't have the charger plugged in. No light on the laptop at all when the charger is plugged in.
Possible solutions:
1. The battery has died and is no longer capable of taking a charge. An alternate explanation if you can't even get the laptop to turn on even though the laptop charge LED is on, is that the internal power supply that converts the incoming and battery voltage to all the voltages required has died.
Or: 2. The power connector inside the laptop is a common failure point. The solder joints break from various minor shocks over time. This is going to become more common with lead-free solder as it is more brittle. Less likely is that the charging circuit inside the laptop has failed.
http://www.chargerbuy.com/laptop-ac-adapter/universal-ac-adapters.html
Oct 28, 2012 | Computers & Internet
My htc incredible s won't charge, I've tried
It sounds like the charging port on your phone is broken. This could have happened a number of ways. Either by dropping your phone, putting the charger in wrong, or taking it out wrong. If you call HTC(866-449-8358) and it is still under warranty they will probably fix it for free as long as it doesn't have any water damage(http://www.ehow.com/how_4479971_check-cell-phone-water-damage.html). Otherwise you could also get a new phone.
Oct 19, 2012 | Cell Phones
Laptop won't charge. Replaced battery and charger and still does not work.
Please check the connector / port where u plug-in the charger. Does it happen with all other compatible chargers or only with the one you have. Also try charging some other compatible laptop with the same charger. If that works, it means there is some problem with the port. Its not making the connections well.
Aug 12, 2012 | Toshiba Satellite L655-S5103 Laptop
My dell inspiron won't charge if the OS is awake/on but DOES charge when it's off/asleep. this is a new problem.
This appears to be a common problem. Sounds like the current is not being shared while in use. If you know the battery to be good, I'd check the output voltage of the charger 1st and see it is putting out the right voltage. The chargers for the Mini series are weird, so may be worthwhile borrowing another charger to eliminate it from the problems.
After that... you may need to get the laptop checked by Dell
Jun 15, 2011 | Dell Inspiron Mini 10 Notebook
My sony vaio charger is got pulled out one day by kids running around, and when I went to plug it back in it would only work if i have it a certain way. I went out and bought a universal charger that said...
You mentioned that when you plugged in back the charger, it worked if you try moving it right? chances are, the problem could be with the charging pin itself of the laptop. there might be a loosening due to the sudden pulling out of the charger..
Apr 09, 2011 | Sony Vaio PCG 7Z1M Laptop Universal AC...
Computer wont charge with universal charger
Please check the technical specifications of your computer charger and see that your universal charger fulfills the same. Generally it is found that the universal charge may supply the required voltage but may not provide the required amperage. That is the reason most of the electronic companies insist on their chargers. If your charger is not working please get one from the company rather than using the universal charger and the spoiling your computer. Universal chargers are OK for some of the electronic devices which do not require higher currents.
Dec 27, 2010 | Dell Inspiron 1525 Laptop
The laptop wont charge
Just because the light comes on does not mean the charger is charging. You will have to use a meter and check the actual output of the charger. The problem could be the charger , charger plug, cables or battery. Start the checks with the plugs and cables and go from there. The light can come on but no power going out to the battery.
Oct 12, 2009 | Toshiba Satellite A55-S1063 Notebook
Toshiba Satellite M30 Notebook Logo
59 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
