LG Flatron 915FT  19" CRT Monitor
Problem for LG Flatron 915FT (White) 19" CRT Monitor
Screen shrinks monentarily then zooms in untill screen is blank, then turns off.
By machine_mike on Sep 13, 2006
It will work fine for a while (5 minutes to 5 days) but then it will start doing the shrink/zoom thing. I turn the monitor off, wait a few seconds then turn it back on and I see vericle lines and the screen is too small then it zooms out again. After turning it off and on a few times, it has eventually started working properly.
I've changed the screen size, refresh rate, downloaded drivers from LG, even switched video cards but nothing works.
Any help would be appriciated.
Same Problem
May 15, 2008
-   Similar to what he had but one day all icons are small along with anything I look at on-line or off. Next time to large. Have tied changing settings on the monitor and in the computer no change.-   Guest
Solution #1
posted on Aug 07, 2008
Somewhat Helpful)
Wrench28
Rank: Apprentice
Rating: 70%, 1 votes
I had a similiar issue that caused all my Microsoft applications to zoom out to 500%. It also caused PDF documents to shrink and go the the last page. The issue was caused by the Intellatype software that came with my ergonomic keyboard. The issue was resolved by disabling the zoom feature of the sofware on the zoom tab.
Was this helpful?
Yes
No
Solution #2
posted on Sep 17, 2006
Somewhat Helpful)
noone
Rank: Guru
Rating: 85%, 200 votes
Your problem is likely caused by a cold solder connection in the yoke/horizontal deflection circuit. Most likely easily repaired by most service shops.
Was this helpful?
Yes
No
Solution #3
posted on Sep 04, 2007
Not Rated)
BNUTZBCRAZY
Rank: Master
Rating: 88%, 48 votes
OK PEOPLE I GOT THE SOLUTION TO THE MAG INNOVISION LT916S GOING BLACK AFTER ANY LENGTH OF TIME BEING ON!!! I JUST REPAIRED MINE TODAY! THE PROBLEM IS THE CAPACITOR BANK IN THE POWER SUPPLY PART THERE ARE 6 CAPACITORS I HAD A FEW LEAKY ONES "NOT GOOD" THE CAPACITOR SPECS ARE AS FOLLOWS 470UF 25V 105 DEGREES C MEANING 470 MICRO FARAD/25 VOLTS I HAD A VERY HARD TIME FINDING THE 25 VOLT ONES SO I WENT WITH 470UF/35V 85 DEGREES C THEY MIGHT NOT LAST AS LONG AS THE OTHERS DUE TO THE TEMP RATING HOWEVER, IM THINKING SINCE THEY CAN HANDLE UP TO 35 VOLTS IT SHOULD EVEN OUT AND HEY, ITS WORKING SO FAR SO GOOD!! THE CAPACITORS ARE FROM UNDER A DOLLAR A PIECE TO A COUPLE BUCKS EACH. THE CAPACITORS HAVE A BOLD LINE RUNNING UP ON ONE SIDE INDICATING THE POLARITY. BOLD LINE SIDE IS "-" SIDE WITHOUT BOLD LINE ITS "+" THE POWER SUPPLY BOARD HAS THE POLARITYS STAMPED ON THE BOARD ITSELF UNDER EACH CAPACITOR. EASY 30 MINUTE FIX IF YOU ARE LEARY ABOUT SOILDERING, FIND A FRIEND THAT KNOWS HOW TO. ITS REALLY NOT THAT HARD THOUGH AND YOULL HAVE SOME DECENT ROOM TO WORK WITH. I PROMISE WHEN YOU OPEN IT UP YOU WILL ALMOST CERTAINLY SEE AT LEAST 4 OF THE 6 CAPACITORS BULDGING AT THE TOPS MAYBE EVEN LEAKING BROWNISH STUFF. DO YOURSELF A FAVOR THOUGH AND REPLACE ALL OF THEM WHILE YOUR IN THERE "THE SIX BIGGER ONES ONLY" IF ANY OF YOU NEED FURTHER HELP OR ANY OTHER QUESTIONS ABOUT THIS PROJECT PLEASE FEEL FREE TO EMAIL ME AT BTLEE26@HOTMAIL I DAMN NEAR WENT CRAZY TRYING TO FIND A SOLUTION ON HOW TO FIX THIS THING SINCE I SPENT OVER 300 BUCKS FOR IT NEW. AND IM BY NO MEANS A EXPERT WHEN IT COMES TO THIS STUFF BUT I DO KNOW A FEW THINGS. AS IM SURE MOST OF YOU DO. TAKE CARE YOU ALL AND THANKS TO THE GY WHO MENTIONED SOMETHING ABOUT CAPACITORS BEING BAD IN HIS. open it up and check that 6 capacitors. mine had the lines on the screen and eventually died completly. almost certain thats whats wrong. ive had three other people tell me that thier capacitors in thier where buldging/leaking at the tops just check it out if they are your in luck cause its a easy job and cheap if you do it yourself! good luck!
Was this helpful?
Yes
No
Solution #4
posted on Mar 28, 2007
Not Rated)
railandsail
Rank: Apprentice
Rating: 88%, 2 votes
Question of noone??
In one of your posted solutions you mention a 'cold solder joint'. Do you think that is what may be wrong with all of these Zerox monitors??
I posted my problem here on the forum, and quite a few others seem to have experienced the same problem. I eventually sent my unit back to Calif while I visited Thailand for a month. Upon my return I had received the same unit back (via serial number). It has worked properly thus far for 6 months.
But they never sent one piece of paper back with the returned unit describing the repair or whatever. I have no idea of what problem and/or how likely it is it will occur again??
Was this helpful?
Yes
No
Popular Solutions for LG Flatron 915FT 19" CRT
Questions and Unsolved Problems for LG Flatron 915FT 19" CRT
Do you recommend LG Flatron 915FT (White) 19" CRT Monitor?
Answer
Answer
i need drivers for a starlogic monitor modle number 1996F
Answer
just started I turn on my XP system that seems to be working fine but my LG flat screen that is... (More)
Answer
So when i use my computer ,using internet or making 3d models with Blender 3D.or something... (More)
Answer
I"ve lost my monitor installation disk Where can I find on the NET Thanks Subi
Answer
My screen keeps having 'fuzzy lines' through it. This happens from time to time. I thought it might... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For LG Flatron 915FT 19" CRT...:
Top Monitor Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
