Question about iLO 2600 Television
My remote won't work
My remote will not turn my tv on or off, also certian channels I have to use the mts key to make the sound sound better. Where can I get a new remote for my ilo tv.
  • cfrye43915 Oct 31, 2008
    Can not see where you answered by question???
  • willo17 Nov 02, 2008
    the remote control volume won't work. Where can i replace the remote control or what can i do to fix it?
  • iLO Master
  • 520 Answers
If this is a LCD tv it may have been made by Initial Tech 800-216-5156. Good luck!
Posted on Oct 31, 2008
  • Bob Citizen Nov 01, 2008
    I gave a possible solution and it was not in the form of a question. I'm sorry it did not help you.
Turn off stereo sap in tv
buy an rca universal remore for 8.00
Oct 14, 2013 | LG Televison & Video
How do I get my rca truflat tv to get out of mono?
Hello
Press the MTS on the remote control handset to select STEREO, MONO or SAP. All the options will be available only when the current TV channel is broadcasting that option. Channels will not always carry programes, that have all MTS options. If "STEREO" appears on the screen when you select a channel means stereo sound is available with current programme. You can hear sound from both speakers. If broadcast is not strong and clear, stereo sound will not be available. Press "MTS" button to change it to "Mono". This will eliminate the noise. If "MONO" appears on the screen when you select a channel, stereo effect will not be availabe, even though you have set it to stereo. If "SAP" appears when you select a channel 'Second Audio Programe' [SAP] broadcasting is available for that programme. Press the "MTS" button to 'SAP' and you can hear that programe in different language or some other kind of audio.
Oct 28, 2010 | RCA TruFlat 27F520T 27" TV
TV no sound but pictures ok, changed channels ok
The mts/sap function on your television might be enabled. Locate the audio settings on your television and make sure you are set for either stereo or mono. You may have an audio or mts button on your remote. If not this should be in the menu.
The cable company may have made a recent change and the tv may need to be channel buffered or you may need to complete another channel scan.
Aug 18, 2010 | LG 37LH55 37 in. LCD TV
No sound on some channels, other channels fine
Your SAP/MTS function is most likely turned on. This feature has 3 modes: Stereo, Mono and SAP. Stereo and Mono are easy to understand, it's the SAP that can get you. SAP stands for Second Audio Production. It is used to provide weather, information or an additional language translation of a program. Some broadcasters simply transmit the mono audio over the SAP audio channel when the are not using it for other purposes. Other broadcasters simply do not use it, which does not give you any audio. Look on your remote for a SAP or MTS button. If you do not see one, look in your TV user menu for this feature. If you are using a cable box, look in the audio menu of the cable box. You are looking for something set to SAP... just change it to STEREO. I hope this was helpful.
Mar 26, 2010 | Televison & Video
No sound on TV
You have turned on SAP sound. Switch your MTS TV sound back to main or standard or Stereo.
OK is used to choose your selection once you 'highlight' it with the arrow keys.
If you are having menu issues, unplug the TV for ten seconds, plug it back in and try the menu again. (you may have to reset your channels)
Feb 26, 2010 | RCA 3-Device Universal Remote with...
Some of my comcast digital channels are muted, while others are not.
It sounds as if you have accidentally turned on your secondary audio settings.
Here is how to fix it....
On your original TV remote next to the "0" key there is a button marked "sound". Press this button until the TV says stereo.
This should fix your problem.
Good Luck and please rate this solution...
Jan 08, 2010 | Haier HTF20R21 20" TV
No sound on 1 channel, have cable other tv's in house works and this one works great but my channle 40.. no sound
the only setting that can cuase something like this is sap which is controlled through the setup or menu option on the remote or tv. their might be a mts button on your remote.hope i was some help
Aug 24, 2009 | iLO Televison & Video
How can I turn off SAP?
if you are using a digital TV is is possible that the frequency is slightly out or you have poor reception.
do a new channel serch first (automatic if you can
and see what happens
sap may reset also if you do this function.
May 05, 2009 | iLO Televison & Video
Can't turn off SAP/MTS without remote
Dynatron MR 110 available at various sites including Amazon.
Aug 01, 2008 | Sharp 20H-S60 TV
Some channels have no sound some are in spanish
With your remote, go into the menu, find the audio setup and click off the SAP. Thats the Second Audio Program. Some Broadcasters send a second lanquage along with the regular audio. Someone must have been looking around or playing with the remote and turned on the SAP.. Good Luck PS please do not forget to rate this thread
Oct 18, 2006 | Orion STV2763 27" TV
Televison & Video Logo
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
