Question about Leupold ® Rifleman® 3-9x50 mm Scope
Remounting a rifle scope, Luepold 3X9 with Luepold rings
How much torque do I apply to the ring screws when remounting the scope?
Jerry Ervin
bar_30_auto@yahoo.com
  • Anonymous Jan 23, 2009
    Where can I find the torque specifications for the proper mounting of Leupold base and rings?
    Problem Solver:
  • 5 Answers
Hey jerry when ya renount a scope ya just want to tighten all the screws evenly when ya do this ya want to start with right front then left rear then left front right rear you do this till its as tight as you can make them without striping screws when your done you should have even space at all the rings good luck and i hope this helped ya
Posted on Mar 02, 2009
Need an on line owners manual for an springfield 1903 30 cal rifle
squeeze the trigger as you slide it in .
Feb 21, 2016 | Optics
After sighting in the scope,I take a few more shots and have to readjust the scope.
This symptom is typically caused by slippage of the scope in the rings, you should tighten the ring screws to 15 inch pounds or so. Many ring sets are slightly misaligned or poorly machined.
If you continue to have problems, you may need to use a ring lapping/alignment tool (available from midwayusa, (http://www.midwayusa.com/Search/#wheeler%20scope____-_1-2-4_8-16-32). This will increase the surface of the ring that actually contacts the scope, thus increasing the clamping force and friction to keep the scope in place during recoil.
Don't know what type of rings you have, but Leupold makes excellent rings. I have not found it necessary to lap these rings to date, even on my 45/70.
Other issues may include loose mount screws or loose ring to base mounts.
Mount your base screws using 15 to 20 inch pounds of torque and blue locktite. Torque your ring to base screws to 30 inch pounds or so.
If the scope is slipping in the rings, a quick temporary fix that might help is to apply rosin to the inside of the scope rings to increase friction. I have also used a dab of rubber cement as a temporary fix.
Oct 12, 2010 | Bushnell ® Elite® 3200 3 - 9x40 mm...
I have 2 scopes that wont hold zero both are6-25x56 #1 -no3301 #2 0n03317
A better description will get you a better answer.
Many of these problems are caused the the mounting system. if you have the same problem with 2 different scopes on the same rifle, check there first:
Tighten mount screws - 20 inch pounds torque, use blue locktite
Tighten ring to mount screws - 30 inch pounds torque
Tighten ring screws - 15-20 inch pounds torque
If all is tight, you may need to lap your rings to get better ring to scope contact and increased clamping friction. Go here for an appropriate tool.
Hope this helps
Oct 07, 2010 | Millett Optics
How many ft lb of torque for scope rings
A typical torque setting for scope bases (on a steel reciever) is 30 in/lbs. The rings (steel) need 15-20 in/lbs.
For a aluminum receiver and/or rings, 15-20 in lbs is about max. I use 10 in/lbs with blue Locktite for aluminum receivers and rings.
Apr 20, 2010 | Redfield Ring and Base Sets for Knight...
Point of impact shifting 3-4 inch groups at 100 yds rifle shot exc. prior to this. tried a good tip hump, tried free floating, and problem still exists.
Basic things to check:
Scope base screws - make sure they are tight. 30 in/lbs or so.
Scope rings - make sure they are tight and grip the scope securely. 15 - 20 in/lbs for steel rings.
Scope attachment screws - tighten securely.
Change in ammunition?
Change in rifle rest technique? you should be resting the stock on your rest, not the barrel.
started using a sling? this can change POI.
Is your bore clean? Use a copper remover after your normal cleaning process.
Check the barrel crown for damage.
Check the action mounting screws for proper torque.
Hope some of this helps!
Mar 30, 2010 | Nikon Optics
I have a Redfield 'LO-PRO' rifle scope, 3X9 variable, on my 300 Win Mag. It is about 20 to 25 years old and the cross hairs must be loose. They are not straight up and down anymore. Will this affect the...
It doesn't sound like anything's broken, it sounds like the scope has shifted in the rings, as you said "they are not straight up and down anymore", which won't effect your accuracy at short ranges, but if there's long ranges (more than 100 yards) you're going to be off some.
You can loosen the ring screws until the scope will turn, either 2 or 4 screws that hold the two halves of the ring together. There are numerous tools to help you align the crosshairs, but when I do this job I just square-up the reticle (crosshairs) by looking at the center of the reticles and let your eye follow the bottom crosshair down and make sure it is centered on the back of the bolt or receiver. If you need help doing this job, take it to your local gunsmith, he'll be able to square these up for you and boresight it.
Hope this helps, Mark the Gunsmith
Dec 09, 2009 | Optics
My banner scope in 4 to 12 wii not hold zero
I'd start by looking at the mounting bases.
First tighten the scope ring screws to 25 inch pounds, then loosen and remove the rings from the base(s) while still attached to the scope.
Back out the base screws one at a time, apply low strength thread locking compound and tighten each to 25 inch pounds.
Remount the rings/scope to the bases tightening till snug but not overly tight and sight-in the rifle.
Nov 14, 2009 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
I have a redfield 3x9 rifle scope and looking for tips on sightin
Yes thats about all there is to it, adjust in small steps and tap on the barrel of the scope with a screw driver handle (light taps) after each adjustment before firing the gun.
Nov 14, 2009 | Redfield See Thru Rifle Scope Mount Base...
Bushnell Trophy scope on BLR .308 -- was fine when last used but now shoots 4 ft high at 100 yards and elevation screw is maxed out -- doesn't seem to have moved in rings and no visible sign of damage --
Rap it on its nose. Us a good screw driver and just give it a tap, not so hard to dent it but a good smack. with the handle. If this does not work remove it smack it, then remount, putting the rings is a small bit different location.
Oct 13, 2009 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
I'm missing five (5) Nikon rifle scope ring screws.
i would contact cabelas they have a full line of nikon rifle scopes or look up on line a company called brownells it is a gunsmith supply company they will have what ya need hope this helps ya and good luck
Jan 19, 2009 | Optics
Leupold ® Rifleman® 3-9x50 mm Scope Logo
320 people viewed this question
Top Leupold Optics Experts
George Merkley
George Merkley
ray gallant
Are you a Leupold Optic Expert? Answer questions, earn points and help others
