Question about Bose Lifestyle 48 System
No sound but system display appears normal
There is no sound from the system although the display on the control box is showing that the stored music is playing. The speakers work in all other rooms. I have checked connections and switched off the system at the mains, removed and re-inserted the main control cable to the system to reboot. Any ideas?
  • Anonymous Nov 02, 2008
    I have the same problem and have tried all recommended reboot and software reinstalls without success. I have now relented and am requesting a Bose Technical Rep to make a home visit to assess on site before I send it back for warranty repair. I will update when I get a response from Bose.
  • RAMSTER Dec 13, 2008
    I have the same problem everything seems to be fine on the system display, but the sound doesnt come out. Whats the deal with this 4000.00 system, did we get jerked?
I have the same problem. I'm interested in hearing how it's resolved.
Posted on Nov 14, 2008
My on screen display has gone small
What do you mean has gone small? You mean your icons are smaller?
Try changing your screen resolution. Right Click on an open space on the desktop and select Properties. When the Display Properties window opens select the Appearance tab. Look down at the bottom and you can make sure your Font Size is Normal, if not change it to Normal. Click the Settings tab and change your screen resolution. The higher the resolution, the smaller the icons. Size 1024x768 is what most people use.
You can also get to the display properties to perform the steps above by clicking Start/Control Panel or Start/Settings/Control Panel. Look for Display or Appearance and Personalization. Open it and the display properties window will open.
If you are using Windows 7 you can also just click Start and in the search box type Screen Resolution. Look up at the top for the search results and click on Screen Resolution.
If you can't get it back to the way it was you can try doing a System Restore. System Restore allows you to select a Restore Point (date and time) before you started having problems. So if you display went small yesterday, then select a restore point before yesterday.
System Restore does not delete your data, documents, music, pictures, videos or programs (unless the program was installed after the restore point you selected). To start System Restore click Start/Program/Accessories/System Tools/System Restore then select a data and time before you started having the issue.
If you are using Windows 7 you can just click Start then in the search box type System Restore and look up at the returned search results and select System Restore.
System Recovery on the other hand deletes everything and sets your system back to when your first purchased it.
May 20, 2012 | HP Computers & Internet
Text is too small and difficult for me to see
On the Start menu:
  • Select Control Panel
In Control Panel:
  • Be sure you are in Classic View (all Control Panel icons are showing).
  • If not, under Control Panel in the left pane, select Switch to Classic View.
  • Select Display.
In the Display Properties dialog box:
  • Select the Appearance tab.
  • Select a Windows and buttons style from the list.
  • Select a Color scheme from the list.
  • Select a Font size from the list.
For more customization:
Under Windows and buttons:
  • Select Windows Classic style.
Under Color scheme:
Select the color scheme you want from the expanded list of options
To change individual desktop elements such as title bars, icons, menus, and scrollbars:
  • Select the Advanced button.
In the Advanced Appearance dialog box:
To choose the screen element you want to change:
  • Select it from the Item list.
To choose available size, color and font styles:
  • Select from the attribute lists.
When you are finished with selections:
  • Select OK twice to close the dialog boxes.
To close Control Panel:
  • Select the Close button.
Control Panel: Display: Appearance tab: Advanced button
Control Panel: Display: Appearance tab: Advanced Appearance dialog box
To open the Ease of Access Center, select:
  • Start.
  • Control Panel.
  • Ease of Access.
  • Ease of Access Center.
Under Explore all settings, select:
  • Make the computer easier to see.
Under See also, select:
Personalize appearance and sound effects
In Personalize appearance and sounds, select:
  • Display Settings.
  • Under Resolution:
  • Select a resolution between Low (screen elements appear bigger) and High (screen elements appear smaller).
  • Select OK.
Apr 19, 2011 | Computers & Internet
No sound
Check the Microsoft Volume Control or the Audio Mixer Program mute options and volume sliders.Ensure the speakers are properly connected to the audio card’s output connector or Check the volume control and power connection of the speakers, if they are amplified. (Refer to the speakers documentation for detailed information).Ensure a hardware conflict does not exist between your audio card and another device in your system.PCI bus mastering devices may be interfering with the operation of the audio card. Temporarily remove non-essential PCI bus mastering devices. If the device is a display card, upgrade the display card drivers, or set the card to the default Windows VGA mode.
hope this can help,
with regards,
JABEMS
Nov 03, 2009 | Sony SDM-HX73 17" Flat Panel LCD Monitor
Creative Audigy 2 (WDM) card cuts out
Plug in ONLY the regular wired speakers and ONLY to the green port on the back.
Make sure they are powered up and the volume is about half way.
Ok now you need to call up ether the sound card application or preferably the windows volume control from the bottom toolbar.
Click Open Volume Control.
A box with sliders in should appear. make sure that volume control, wave, sw synth, aux, cd player, line in
are all about half way and that none of them have ticks in the box at the bottom.
If any of those are missing click options then properties from the top left and put a tick besides any that were missing (nothing else)
Now close the slider box.
Put a normal music cd in your cd/dvd player on the computer and set it to play with windows media player.
You should now have sound out of the speakers.
Double check that EVERYTHING is ok.
If there is still no sound check the control panle for any hardware issues and rectify those with the correct drivers
Oct 27, 2009 | Creative Labs Sound Blaster Audigy 2 Sound...
I have no sound on my computer i had sound the other day
Roll back your sound drivers (control panel, system, hardware, device manager, sound and audio devices, right click your sound hardware, properties, drivers), if this fixes the issue go to microsoft update, run the 'custom' scan...it should show you an update to your sound card/hardware, click the little "+" sign beside the update and click the little "Do not show this update again" checkbox. This will prevent automatic updates from "fixing" your drivers. Occasionally Microsoft sends out updates that are incompatible with a particular machines' setup.
Hope it helps.
Oct 13, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
The loudspeaker of my pc does not have sound the rest of options are working properly the sound valume and the icons shows without problem
Oct 06, 2009 | HP Computers & Internet
My PC doesn't produce sound from any file or program on internet, for example when I download Winamp media play it doesnt produce sound but you can see that the music is playing
First check you dont have a red line through your speaker on your toolbar. If so click it and "UN-mute it.
Open volume control.
When the box with all the sliders opens up click on OPTIONS (top left)
Click PROERTIES
Make sure that Volume controls, Wave, SW Synth, CD PLayer, Line IN, and MIC all show on there and that the volume sliders are about half way up.
Make sure noe of the sliders have ticks at the bottom, if so UNTICK them.
If any of those are missing click options then properties from the top left and put a tick besides any that were missing (nothing else unles you know you want that item)
Sep 07, 2009 | Computers & Internet
Sony V555ES Amp:
Try setting your amp to "auto format decode".
It should easily be heard in this mode.
The sub will not show up on the display when in 5.1 mode. (Blue light on)
Use this with music, and use the 5.1 with movies to get a better experience from your amp.
The sub will work in 5.1 but doesn't show up in the display. Try movies with loud sounds.
Most of the pre-set sound fields are of no use to me. I only use normal surround, and AFD and love it. I hope this works for you!
Terry
Jul 03, 2007 | Sony STR-V555ES Receiver
Bose Lifestyle 48 System Logo
153 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
