Question about Panasonic PT-56HX41 56" Rear Projection Television
Red convergence I'm having the same problem that was in the previous post about convergenc of the red beam. It is way off to the left and will only adjust so far to the right. I replaced one of the convergence chips that was marked red (the other one was marked blue) to no avail. Do both IC's have to be replaced to fix this, or do I have another problem?
  • Jared Wennermark Sep 15, 2006
    I replaced the other convergence IC and the problem has shifted to the right side now (red won't adjust far enough to the left), and there is some bowing of the red cross-hairs on the convergence set up screen. What do you think is happening here? I have not replaced any resistors yet.
    President:
  • 3,130 Answers
It could be the other IC as well as you are suppose to replace both at once! You see these ICs have three amps in each on X 2 =6 2 for red, 2 for green, and 2 for blue. There also might be small resistors near the IC's that are open. These are called fusable resistors. They are of a low value like around 1 to 3 ohms most of them.
Posted on Sep 13, 2006
Shows a red scream
try the auto focus if shows error then try to do it manually in convergence and make sure you align all colors. If still doesn't work, then you will have to have the convergencs chips replaced.. Approximately $250 repair cost..
Mar 07, 2010 | Toshiba 50H82 50" Rear Projection...
Zenith projection tv convergence proublems
YOU HAVE BAD CONVERGENCE IC'S AND POSSIBLY SOME LOW OHMAGE RESISTORS THAT FEED THE IC'S.
Sep 14, 2009 | Zenith R40W46 40" Rear Projection...
My red,green and blue colors are off,needs to be convergenced
HI. there is a convergence circuit board that controls the rgb stream and it also is the principal manager of the colors. if you cannot collaborate the cross hairs or, even out the rgb, this will confirm convergence board failuer. the chip set on this board is faulty. Replacing the convergence board or stk chips will fix this issue.
Jun 05, 2009 | RCA Televison & Video
I have problem with color convergence
you can go to menu, convergence adjustment. If you can not move the red or Blue hair cross. It is surely your TV Convergence chip(s) bad.
Jan 06, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Convergence problem not fixed after replacing STKs
I found the chips easy to replace, but time-comsuming due to the number of pins involved. I woudn't want to try it if I'd not had prior experience with soldering.
Still no response to the original question though. With 2 replaced STK392s, red is still not moving in horizontal alignment. What gives?
Aug 17, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Mitsubishi WS55511 Convergenc
REPLACE THE CONVERGENCE IC (OR IC'S). A FUN JOB I CHARGE ABOUT 200 FOR.
Jun 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Auto focus convergence on blue doesnt' work
this is an idication that eather the convergence ic's or convergenc ic output resistor have blown
Feb 16, 2008 | Samsung HCM422W 42" Rear Projection...
Red convergence, cannot adjust left to right
replaced convergence amp ic's
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 14, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Convergence
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Nov 23, 2007 | Toshiba 50H72 50" Rear Projection...
Panasonic PT-56HX41 56" Rear Projection Television Logo
41 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
