Question about Technics SL-1210 Turntable
My 1210 decks are not working - Technics SL-1210 Turntable
  • 515 Answers
Ok, so what is the problem?
- OPTiC.
Digital Analog Therapy
Posted on Nov 04, 2008
Deck buzzing
Probably a lose earth wire on a lead or cartridge.
Feb 03, 2013 | Technics SL-1210 Turntable
Who can repair my 1210 technics turntable. Power is getting to the deck, as i am an electrian. Ijust need a good repairer.
Depends where you are located. If you are willing to pay for the shipping both ways, I am in Ontario Canada.
Mar 02, 2011 | Technics SL-1210 Turntable
1210 mk5 poor sound
If the cartridge is good and your wiring is good. Then it's either got to be a fault on your amp, or there is a pre-amp in the deck itself faulty. Double check that the amp is working, amps have a pre-amp for record decks, they cause trouble a lot.
If you touch the wires that connect to the cartridge, you should get a buzz on either channel (remove them from the cartridge first). If you don't get a decent buzz, and you know that the amp is working fine, then there's something inside the deck causing the problem. In which case take the bottom off and take a look inside.
Feb 11, 2010 | Technics SL-1210MK5 Turntable
How do i free up the tononig arm on a technics 1210 deck? It is stiff and wont move across the record.
It should really be replaced but you can try adjusting the screw on the top of the arm
Dec 23, 2009 | Technics SL-1210 Turntable
No power in either turntable
maybe the power source that goes into the deck itself has dissconected, but it is strange that niether would im guessing the decks are might be your extension cable...or u have had a power surge, if that has happened...then you need to seek profesinal help...and unfortunally, your decks may have died. But check your plugs/extension should be a basic problem, and easily fixable
Aug 03, 2009 | Technics SL-1210 Turntable
Deck fades out when i bring the second deck in (records I mean)
are you running phono pre amps ? are you running pre amps to each deck or one for both decks , if you are running pre amps maybe the power supply is not sufficient to run two decks anymore [ possibly damaged ] but it sounds like a power delivery failure to me . hope this helps
May 24, 2009 | Technics SL-1210 Turntable
Modification to SL-1210 Mk5
so what does the turntable do at 0?
May 30, 2008 | Technics SL-1200MK5 Turntable
1210 mk5g pitch adjustor
switch off for a will and see.
if still bad. check the circuit board under.
with old electronic devices, capacitors are commly the ones that may go wrong/dry. which would cause oscillatory circuit to generate wrong signals or strobe or feebacks. if you know how to take out the circuit board, check it starting from capacitors.
Jan 22, 2008 | Technics SL-1210M5G Turntable
bad thrust bearing for the platter. use a penetrating oil on the spindle and let stand. then try rotating it after a while.
Sep 11, 2007 | Technics SL-1210 Turntable
Technics SL-1210 Turntable Logo
Top Technics Audio Players & Recorders Experts
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
