Error c1300 THIS CODE APEARS AS SOON AS THE MACHINE IS SWITCHED ON.
  • JOSE ALVES
    JOSE ALVES Nov 01, 2008
    This code hapens in the MINOLTA DI-181 and is caused by the poligon motor of the laser sistem which ceases. Open it and lubricate its shaft.
    GOOD LUCK.
  • 145 Answers
C1301 errors after setting up the Di181.
Solution:
Replace PWB-A, part number 1177-0106-03 for C1301.
could it be this code.
Posted on Nov 01, 2008
Solution to bizhub 210 error code c1300
Problem
Polygon Motor malfunction
-Startup failure
- Lock signal fault: Unstable after the first Lock signal has been detected
- Lock signal fault: Lock signal out-of-timing
Solution
1 Turn OFF and ON the Power Switch. 2 Check for proper connection between the PH Unit and Master Board and correct as necessary. 3 Change the PH Unit. 4 Change PWB-A.
Aug 15, 2017 | Konica Minolta Office Equipment & Supplies
Error code c1800
Did you mean C1300 no such number 1800 in the service manual. If so that code means something wrong with Print Head the Assy. that has the LASER in it along with the polygon motor. Power off to reset. Mite also be the image control board. so check connections between the print head and the image control board.
Jan 20, 2014 | Minolta - DI200F Printer
C1300
C1300 indicates a laser mirror motor failure. Given the age of the machine this is going to be expensive to repair as parts are becoming harder to find. The part that has failed is your machine is a spinning mirror that the laser bouces off of and is responsible for "writing" the image onto the drum. The motors freeze up over time and when the motor does not rotate at all or at the proper speed the C1300 code is generated. I would estimate you are looking at something in the area of $400 to $500 to repair the machine. It may be time to look at a replacement machine.
Sorry for the bad news.
Good Luck and Thank You for using Fixya.
WheatlandServices
Oct 19, 2010 | Minolta DiALTA Di250 All-In-One Laser...
Konica Minolta Di250 copier - Malfunction code c1300.
WheatlandServices
Oct 14, 2010 | Konica Minolta Office Equipment & Supplies
Code c1300
C1300 Code polygon motor inside the print head the LASER that places the image on the drum then paper. Turn off then on if it comes back replace the printhead. expensive sorry!
Mar 02, 2010 | Minolta Office Equipment & Supplies
Pas op machine fout (c1300)
This code is the polygon motor error.Reset the malfunction and turn OFF and ON the power switch.If the same malfunction persist check connectors ofpolygon motor and master board.If connections OK change PH unit,Master board and power supply board.
Aug 10, 2009 | Minolta Office Equipment & Supplies
Di181 Code C1300 What does this mean? How do I
The PRINT HEAD has failed that is the LASER UNIT in the machine, need a new one
Aug 03, 2009 | Konica Minolta Office Equipment & Supplies
DI181 ERROR C1300
The motor in side the print head error the print head houses a motor which scans the LASER across the drum, can't get just a motor you get the entire print head try this site if they still have them you have a legacy Minolta machine now Konica Minolta. Open close the front door to reset.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
May 25, 2009 | Minolta DiALTA Di181 Printer
I have error code c1300 on konika 7415, ...help me.
C1300,
C13F0
1. Reset the malfunction.
2. If the malfunction is detected again, check the harness between, and PJ connections
on, the PH Unit and Master Board.
3. If connections are okay, change the PH Unit and Master Board.
Apr 05, 2009 | Konica Minolta Office Equipment & Supplies
240 people viewed this question
k24674
jasbo
jasbo
