Question about Vizio L32 32 in. LCD HDTV
No power -- TV will not turn on
The little orange light is on. But if you hit the power bottom or used the remote -- nothing happen. orange light should go to green and TV is on.
orange bottom
  • 3 more comments
  • holly-hammon Nov 07, 2008
    I have the exact same problem, just happened yesterday. Actually it would turn it self off over the last month and I would hit the power button and it would turn back on...not anymore. It has the orange power button on but it won't power up, so it get's power. Tech support could not help, told me to call Repair Solutions at 1-800-762-0796 or ITI at 1-800-526-1084
  • Shiloh82 Apr 01, 2009
    I have the same problem and just called the second of the two recommended telephone numbers. Were you ever able to get your issue fixed?
  • gustavoleyva Apr 03, 2009
    I have the exactly same problem! I called the support numbers given and the first one doesnt work and Im still waiting on a call back from the second number...
  • Anonymous Apr 04, 2009
    How much does this cost to repair. Can it be done by a novice?
  • donsom43 Apr 16, 2009
    I have the same problem. 32" vizio. I just recieved it, plug it in and try to turn it on nothing happen. Light in word "vizio" stays orange. Contacted Vizio and they will be sending out a tech.
  • 24 Answers
I found a post on here tonight that said to remove the smd IC chip from the main board and solder a 10K resistor on pins 2 and 3 where the chip was removed,this IC is U26.I just tried this and it works,finally my stand by led turns from amber to white,one step closer to fixing.TV still has no light on screen probably the Y sus board.Bought a new main board last week and same problem,so after I fixed my old one it tells me I bought a bad board.
Posted on Jun 18, 2013
    Sergeant:
  • 280 Answers
This could be the power supply baord / Bad Caps/ They will be puffed up..
Or if the inverter board is bad** Inverter board lights the backlights.
Posted on Nov 04, 2008
The power will not turn on, manually nor with remote. i use to be able to hit power a thousand times and it would tern on. or the red light would come on then off so then i would keep hitting power till it...
check you batteries in the remote. on the tv front panel button right lower run your hand long the bottom of tv it should turn on, then go to settings sync devices , than turn off tv try remote again should work.
if you need more help contact me
Mar 23, 2015 | LG 37LG30 37 inch LCD 720p HDTV w...
Cant turn tv on
may be your DM board is gone......
Mar 08, 2008 | LG RU-23LG10P 23 in. TV/DVD Combo
I have a blue light and an orange but my tv will not come on
If you are referring to an R15 (the big box in the picture with your post), there should be 3 blue lights on the front of the DVR: one to the far left (power), a big circle in the middle, and one on the right indicating the resolution the DVR is currently trying to send to the TV. The orange light indicates that something is being recorded; either a show or something from DTV like channel listings. The orange light has nothing to do with your TV but may indicate that the DVR is downloading setup information.
As for turning your TV on, when you first get DTV, the DVR remote does not know how to talk to your TV set, only the DVR, so you have to teach the remote to talk to your TV. To do that, turn your TV on with the remote that came with it (or the on/off switch on the TV if you're a dinosaur like me) and change the TV input to whatever input the DVR is attached to - usually HDMI or Component. If you see something (a TV show, a guide, a DirecTV logo, etc.) you're in the right place. Now hit the Menu button on the DTV remote and you'll see a menu on the left that includes "Setup". Use the arrow buttons on the DTV remote to move to Setup, press Select, and then select Program Remote. Follow those instructions carefully, step by step, and you should be all set. (Caveat: I am working from memory so the exact wording might not match and I might have missed a menu level. If so, I apologize.)
May 27, 2014 | Directv Plus DVR DTV Receiver / 100-Hours...
Philips 52pfl5704 no screen image
Sounds like main board fault. Contact the authorized service center for Philips. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 28, 2014 | Philips 42PFL3704D LCD TV
The red power light comes on but nothing else works on my hitachi 53FDX01B PROJECTION TV
silly question but have you tried turning it on with the remote. if a tv has been turned off by remote and then power goes, turning it on by the tv switch will put the tv back in stand-by mode and you need to use remote.
just a suggestion.
Dec 13, 2013 | Hitachi 53FDX01B 53" Rear Projection...
When i turn on my ispymphony 32 inch nothing comes on
The fluorescent ballast has taken the proverbial dump. Take a light and look at the screen closely from different angles. See if the menu from the remote is in the darkness of the screen. If so, your backlight went out, or at least the capacitors that fire it. Get a new unit unless you know electronic repair.
Nov 16, 2013 | iSymphony LC32IH60 TV
X322BV-HD*WXC100
Warranty is usually 1 year parts and labor. Contact mfc for warranty service. likely main board.
May 28, 2013 | Televison & Video
Wii turns on, says press A, Press A,Nothing happens
if the 4 lights flash on the bottom of the wiimote you need to sync the controller to thhe wii
Feb 03, 2009 | Nintendo Wii Console
Vizio L32 hdtv10a..
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
Dec 15, 2008 | Vizio L37 Television
Vizio L32 32 in. LCD HDTV Logo
1,170 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
