Question about Dryers
How to fit a belt to a creda tumble dryer - Dryers
  • 550 Answers
Open case
loop belt around bits
close case
more particularly
Unplug dryer
pull dryer away from wall
remove 1 screw each side at back of top plate
slide top plate backwards and lift off
undo 1 screw each side of front kickplate
tlit front panel up
unplug door switch
set front panel aside
careful of control panel its V.fragile
(I lay the dryer on its back)
pull out old belt and bits of belt
loop new belt round drum at wear marks
pull tensioner to end of travel against spring
loop belt round motor pulley & both tensioner wheels(most creda) 1 wheel (old)
relax tensioner
rotate drum by hand to make sure belt wont jump off
reassemble in reverse order
creda uses hotpoint parts
Posted on Oct 31, 2008
5 Suggested Answers
SOURCE: tumble dryer Creda Smplicity T320VW
I am an authorized servicer for Creda and I can explain how to remove the front panel to change the belt. Email me at starztruck4u@aol.com if you still need help.
Posted on May 19, 2008
  • 1462 Answers
SOURCE: creda tumble dryer repair
with great difficulty - these belts are so tight!there is a special tool for doing it but there are other ways
one way i have used is to make a spanish windlass from belt to bottom of machine. when belt is level with motor spindle, push belt on and release spanish windlass. could also try levering belt on with a screwdriver
another method is to get a short piece of tubing that will fit over motor spindle. put belt over tube, lever down and slip belt on. this is the best way
Posted on Jul 20, 2008
AlmostBob
  • 550 Answers
SOURCE: how to fit a belt on a tumble dryer
unplug the dryer,
220v is not fun
dryers are generic inside, regardless of maker
while you got it apart to replace the belt is a good time to clean out exhaust vent pipes and the squirrel cage fan, no lint, better air flow, less $$ to run
3cd9043.jpg the tensioner may push Up on the lower run.
  • open case, most front panels are removed including door, remember to disconnect door switch wires, set panel aside
  • pull drum out
  • check drum support rollers
  • check drum felts, bushes guides
  • locate tensioner pulley, belts have been known to pull them out of the mounting when it breaks, check , reinstall if out
  • pick up broken belt off floor of case
  • take belt to parts store and match it, despite the huge number of dryer models there are very few belts.
  • If any felts or rollers are worn,stuck,damaged take them too to the parts store, and replace in pairs, despite the huge number of dryer models there are very few rollers or felts
  • after ensuring rollers anf felts and bearings are serviceable, loop new belt around drum at the wear mark from prior installation, reinsert drum
  • loop new belt around motor pulley.
  • pull tensioner pulley against spring to end of motion
  • loop belt around tensioner pulley
  • allow tensioner to slowly move back by spring tension till the belt is taut
put front panel back on, plugging in door switch
plug in mains
dry clothes
takes longer to type than to do
Posted on Aug 29, 2008
SOURCE: creda t602cw condeser tumble dryer
how do i replace the belt? i'm having a hard time just getting the back of the dryer off!
Posted on Nov 15, 2008
How to put belt on hotpoint dryer
Dryer Belt Replacement - YouTube
? 6:23
https://www.youtube.com/watch?v=dFB4vnmADh0
Jun 20, 2011 - Uploaded by Repairs101
How to do-it-yourself instructional on changing the drive belt on an electric ... She wanted to know about replacing the drive beltin her clothes dryer. ..... How to replace tumble dryer beltHotpoint, Indesit, Ariston, Creda, Proline ...
How to replace tumble dryer belt Hotpoint, Indesit, Ariston ...
? 9:36
https://www.youtube.com/watch?v=kNJGHyEPiJA
Jan 30, 2014 - Uploaded by how-2-repair.com
How to replace tumble dryer belt Hotpoint, Indesit, Ariston, Creda, .... to get right and the grooves correspond to the drive, so really obvious..
Dryer Drive Belt (part #WE12M29) - How To Replace ...
? 5:14
https://www.youtube.com/watch?v=ZXSJlWcZPiY
Oct 25, 2013 - Uploaded by AppliancePartsPros
Buy the new Dryer Drive Belt WE12M29 ... to replace the Dryer Drive Belt WE12M29 on GE, Hotpoint, RCA, Sears, and Kenmore dryers.
Jan 01, 2016 | Hotpoint Dryers
How do i change the element in a t522vw creda dryer
http://www.ehow.com/how_2087872_replace-belt-creda-tumble-dryer.html
May 28, 2011 | Dryers
How to fit creda thermostats
It depends on which make and model of tumble dryer you have as to how easy it is to replace the relevant parts. Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious burning out or open circuit. Others though have their heating elements inside, which aren't accessible without stripping the dryer down we will try and cover as many as possible in or video tutorials section. Tumble dryer heating elements are always protected by thermal fuses and thermostats which are usually simple devices with 2 wires connected and have a bimetal strip inside them. They can be tested for continuity with a test meter.
The problem is that if a stat (thermostat) or t.o.c. (thermal overload cut-out) has gone open circuit, it may be for a reason. Overheating could have caused it by not being able to vent the air due to a blockage some ware. Blocked filters or even the machine not being allowed its ten minute cooling down period, Overloading can cause it as well. Sometimes they can go for no apparent reason. A blocked or severely kinked vent hosecan also cause overheating.
You-Tube video "ymXmpyVkxIE" placeholder (do not delete)
Jan 02, 2010 | Dryers
How do I replace the belt on my Creda T620CW tumble drier
most credas you need a stretch tool to stretch the belt from drum to motor if there is no jockey pulleys good luck.
Sep 14, 2009 | Dryers
Tumble dryer ,creda tcr 13
hello dave to do this you'll have to take the front panel off so you can pull the tumbler out so you can get to your pully and tensioner on the bottom on the dryer,loop the belt on the pully and keep tension on it while you slip the tumbler back in now loop the belt around the tumbler and after the tumber is sitting on your glides spin the tumbler till the belt is in place,if you can have somebody help you its easyer putting the tumbler back in with 2 people while keeping the belt on the pully on the bottom of the dryer. any other problems or questions let me know i've dont mine about 6 months age its a little pain in the **** but not inpossable
Apr 09, 2009 | Dryers
I need to fit a new belt to a Creda Tumble Dryer
There should be some kind of tensioner around the motor or one of the pully's. The other problem could be that the belt you bought is the wrong one for your model. If you still have the old belt, measure the new belt against the old one and the new belt should be slightly smaller. I hope this info helps.
Nov 29, 2008 | Dryers
Creda tumble dryer repair
Jul 20, 2008 | Dryers
Tumble dryer Creda Smplicity T320VW
Mar 18, 2008 | Dryers
Drum wont turn on my creda t622cw tumble dryer
my tumble dryer drum wont go round
Nov 15, 2007 | Dryers
Dryers Logo
712 people viewed this question
Top Dryers Experts
Richard Roth
Richard Roth
