Network printer - no network
I have a network only MFP printer (No Parallel, serial, or USB connection, just network plug (RJ45 I think). It used to be aon a windows 2003 network and worked great. My environment is now changed. I access the internet through a network router but am not a member of that network. I want to be able to use this printer with my PC, but am at a loss as to how to create a network environment where this is possible. any ideas as to what I can do. - Thanks
  • 345 Answers
If you are no longer on that network that the printer is on and you can' t configure the router, setting up this printer will be next to impossible. If you know the network administrator, you might be able to work something out with the IT department if you explain you need it for a work related function
Posted on Nov 07, 2008
The USB port on the printer is loose and therefore not communicating with my computer.
You can open up the printer and try to fix it, but in fact you will probably need a new part which will have to be soldered in.
An easier solution would be to use the parallel port connection, if there is one. Newer printers don't always have them, and I don't think the 3055 has one.
On the other hand, newer printers often have an ethernet connection, and you should be able to use this instead of the USB. I'm pretty sure the HP 3055 has an ethnet port. You'll need an RJ45 wire. You can get a USB to RJ45 adapter if you need to plug the other end of the cable into your PC's USB port (e.g. if your PC has only one ethernet port and you're already using it for broadband).
Hope that helps a bit. Good luck!
Oct 09, 2010 | HP LaserJet 3055 All-In-One Printer
I have an HP LaserJet printer 4050N with RJ45 and Parallel Port. The Printer is kind of far from the WireLess router and I can't connect it. Unfortunately, my PC doesn't have a parallel port. The best...
Another option is to find an old laptop, with "wireless" capabilities and a Parallel Port.
Connect the printer to the laptop.
Connect the laptop to your wireless network.
Tell the laptop to "share" the printer.
Then, any computer on your network can "find" the networked printer, and can print to it.
Jun 12, 2010 | HP LaserJet 4050 Printer
I need to add network to 2844 printer currently USB/Serial
You need to buy the zebranet PS2 print server
P/N G46692 External PrintServer II. It will plug into the parallel port. they just stoped making them but they are still for sale at zebra resellers. here is one at random from google
resize?sq=80&uid=1127727233 ZEBRA G46692 EXTERNAL PARALLEL PRINT SERVER II
more at ZDTronic.com
ZDTronic.com $160.50
  • product
ZEBRA G46692 EXTERNAL PARALLEL PRINT SERVER II ZEBRA G46692 EXTERNAL PARALLEL PRINT SERVER II $160.50 at ZDTronic.com
May 12, 2010 | Zebra TLP 2844-Z Thermal Label Printer
12 year old notebook - need to connect a printer
Yes you can use any Printer
use it through Parallel port....
you get the converter cable for USB to Parallel port
printers don't need high config....
regards
Apr 30, 2010 | Computers & Internet
Does hp laserjet 5200 have netword printer
Here is your network guide for the 5200n printer
If you do not have the 5200n printer, it is not network. You will need a 'print server' ($100 approx). Get USB or Parallel, depending on the connection it uses.
Mar 30, 2010 | HP Hewlett Packard LaserJet 5200 Printer
Show me where the printer should connect to the back of dimension 3000 tower windows xp
google for dell dimension 3000 and you find the manuall see below i found it on :
http://support.dell.com/support/edocs/SYSTEMS/dim3000/en/SM/index.htm
Connectors
External connectors:
Serial
9-pin connector; 16550C-compatible
Parallel
25-hole connector (bidirectional)
Video
15-hole connector
Network adapter
RJ45 connector
PS/2 (keyboard and mouse)
6-pin mini-DIN
USB
two front-panel and four back-panel USB 2.0–compliant connectors
Audio
three connectors for line-in, line-out, and microphone; one front-panel connector for headphones
Mar 12, 2010 | Dell Computers & Internet
Status seen as offline .HP 1400 series
If the printer status is offline it means that you are either A) not connected to the printer by USB/Serial/Parallel B) Connected to the same network as the network printer or C) The printer is not turned on with the approriate connection plugged into the printer/computer.
Oct 23, 2009 | Office Equipment & Supplies
How to get Panasonic KX-P2123 printer to work with USB port
Cables are available from a number of sources which will convert from a USB plug for your computer to a serial or parallel connector for your printer. (I don't remember for sure whether that Panasonic is serial or parallel. I think it's a parallel printer and uses a Centronics connector.) Do a search for "centronics to USB" or "serial to USB" and you will find links to a number of sources.
Mar 25, 2009 | Panasonic Computers & Internet
2WIRE wireless router/DSL from AT&T
unless this is a wireless enabled or lan RJ45 connectable printer you cannot, the pc that the printer is connected to must be on at the time of the printing.
Wireless printers have their own arial and allocated ip address, Lan RJ45 connective printers can be connected to the router.
Sep 15, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
New LJ 4200N Install
simply connect the rj45 cable and create the printer using hp network printer software. you can download it from the hp website
May 30, 2008 | HP LaserJet 4300n Printer
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
