No power, will not switch on
SOURCE: "Paper Output Slot Jammed" Canon Pixma iP4300
These printers are FULL of very sensitive sensors, and chances are that one of them may have a small piece of paper blocking them. If you can get the covers off by finding the "Triangle" arrow markers, you can inspect all these sensors.
Good luck!!!
SOURCE: Canon Pixma IP4300 Red Light Blinks 5 Times
Hi there
I have put 2 files on my website for you 2 try out, they are the tools program that you use for resetting the waste ink pads and resetting inks ands so on for your printer.
You may have to try the 2 see what one will work for you,
Most IP-Tools will some times work for lots of printers.
Click Link = http://www.4all2sell.com/reset-tools/iPTool.exe
Click Link 2= http://www.4all2sell.com/reset-tools/iPTool.zip
Ones you have downloaded just double click on it to run it.
One of the files is in a WinZip format so if you not got WinZip on your PC you can download free from this Link = http://www.winzip.com/trialpay.htm
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time.
SOURCE: I am having problems locating the front
There are two tabs on the front. They are nothing like the other four and there are no arrows to indicate where they are.
Turn the computer up on its back so you can access the front tabs from underneath.
Get a good flashlight and look up the deep, rectangular recesses so you can see which two have the little plastic piece holding the case down. With a normal screwdriver, push the little tabs toward the sides. If the other four tabs have already been popped, the whole case will pull away easily.
SOURCE: orange light flashes 5 times continuously on canon
Orange light flashes if there is any issue with the printer. Please check all the hardware is functioning properly. Check if there is any paper jam. If printer cartridge is installed properly. Printing head is ok.
