Question about Xerox WorkCentre C2424DN All-In-One Laser Printer
Xerox workcentre C2424 printer
Err
or 07 010 43 11356
    President:
  • 2,072 Answers
That means your print head is not tilting back and forth properly. Or moving side to side.
The 2 most likely causes are this. 1. If you remove the side covers, behind the left cover, ( left looking from the front of the machine) about half way back, near the bottom of the machine you will see a stainless steel block, about 1 inch square. Check that for the presence of ink that has leaked into it. normally its yellow. You will have to remove that block and clean it and the shaft that runs through it thoroughly.
2. The print head wiper, That is located between the print head and the drum. You would have to remove the scanner and the ink loader to access that area. But if a machine is not turned off correctly, unplugged or you had a power failure, it may be stuck to the print head. Which you would just have to take care and dislodge it from the print head then run a couple of cleaning cycles, or power on and off a couple of times.
3. You could have a bad wipre blade clutch but thats less likely. If there is alot of ink in the block, clean all around that area, and then, be 100 percent certain the machine is LEVEL. To check. put a level on the platen glass. check for level front to back and side to side, If it isnt level, shim it until it is level. And dont move, I mean relocate the machine when its hot.
Posted on Oct 31, 2008
System error # 07,010.43:27456 on a xerox c2424 copier
The printhead is stuck in the tilt position, need to replace the process motor camshaft kit, part number WCC2424-Z2
http://www.iteminconline.com/wcc2424-z2_wcc2424-z2-xerox-workcentre-c2424-process-motor-camshaft-kit.htm
Jul 07, 2015 | Xerox Office Equipment & Supplies
System error 09,005.40:143310 Xerox workcentre c2424
You either have jammed ink sticks or a bad Ink Loader 200-4711-80
It is fairly easy to replace, if you can get the covers and Document feeder off.
Whit
Item, Inc.
May 06, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
Error code 39,003,40;61256 on a xerox workcentre
Here is the easy solution to fix the issue :
Click on the link and follow instructions to fix the issue.
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Dec 02, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox Workcentre C2424.
You likely need modify darkness or the contrast.
Please take a look at the following from the Xerox site:
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=458,E=0000000001668056207,K=4248,Sxi=0,Case=obj(6796)
Please let me know if this has been helpful or if there is anything else I can do. Thank you.
Sep 19, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox C2424 getting error message 07,010.43:50441.
Go to www.service-manual.net, do a search for the C2424 manual, and purchase it for about $12. Download the manual, but, more importantly, download the service bulletins that also come with it, one which deals with this. The information you get for the $12. is well worth the cost.
Mar 04, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox WorkCentre C2424DN All-In-One Laser Printer Logo
185 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
