Replaced the distributor,,an the battery. it started 2times an now turning over but wont start.. I unhooked battery- hoping to reset the computer but it didnt work either. any suggestions?? thanks
Sound like you have a bad alternator, poss bad battery too.If you can jump start it with a volt meter check voltage at battery should have above 13.5 volts, do this after you unhook jumper cables and engine running.If bad voltage reading replace alternator make sure you charge battery before starting engine with new alternator or it could damage alternator.If good voltage have battery check.Hope this helped.
Might need to replace your transmission control module located under your pass side floor carpet. Remove the plastic kick panel to the right of the passenger's foot, carefully pull back as much carpet as you can. There you'll see the cage for the ECU and your trans control unit. The trans computer is the smaller one. Good luck.
i have a 92' honda accord lx, it has a problem of the D4 light flashing and the car wouldnt start, but i could wait a few minutes and try again and it would start.
You may have got water into the distributor cap and or the spark plug wires where they go onto the plugs.
Take the dizzy cap off and blow it out making sure there is no moisture in it when you replace it, do the same to the spark plug leads on both ends.
hope this helps
My 92 does the same thing. I beleive its in the ignition. I had to replace the distributor twice. Honda thru 95 had weak distributors also the fuel pump and injectors are getting weak.
Chad
