Question about Dell Dimension 4400 PC Desktop
Trying to restore dell 4400 and cannot get to a dell screen for f-12
After windows xp logo loads the computer goes to a black screen. If i try safe mode there is text "safe mode" in the lower corners, but the computer does not proceed
  • Anonymous Mar 22, 2014
    a little picture of a cord shows up in left corner when loading
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 18 Answers
If you boot from the XP CD and choose the first repair option it will load to a DOS prompt. From there type "chkdsk /r" and press enter. This will run checkdisk on your hard drive and repair any problems that it finds. It will take 45 minutes or more depending on the size of your drive. Once it finishes type exit to reboot and remove the CD. Your computer should boot normally.
Posted on Dec 06, 2008
Black screen right after dell logo
start tapping f8 after you boot the machine, when given the boot menu, try to load safe mode, and see if it loads. if it does, then you need to do a system restore back to before you got the black screen. more than likely windows loaded an updated driver that disagrees with your system. try that and let me know what happens :)
May 25, 2012 | Dell Studio One 19 PC Desktop
Starting problem
Immediately after seeing the Dell logo, keep tapping the 'F8' key,
until you see a "menu" (white text over a black background)
giving "startup" options for Windows XP.
Select "Safe Mode" and see if you can start in that mode.
Then, use "System Restore" to go "back" in time, to the most-recent checkpoint (date/time) where your computer _DID_ work.
Restore to that point, and restart.
Jul 17, 2010 | Dell Inspiron 1525 Notebook
I have a dell dimension 4400. when i turn it on, it runs normal, but after the windows XP is loading "logo", the screen goes blank for about 5 minutes, and then i get a blue screen with whire lettters that...
The operating system is corrupted you have reinstall you windows xp , you have insert the xp boot cd in the cd rom after that the option will be aksing to (press any key to boot from cd..) at that time you have press any key then the booting will be started.
Oct 30, 2009 | Dell Dimension 4400 PC Desktop
Dell dimension 3000. Just Black Screen no Windows XP.
From your description, you were able to boot the machine properly in Safe Mode. While in Safe Mode, change the video resolution to the lowest possible (color depth does not matter at this point). You should also check that you are configured for single monitor operation if your video card supports multiple monitors. Reboot the machine normally. If all goes well, you can readjust your video settings for a higher resolution again.
Jul 06, 2009 | Dell Dimension 3000 PC Desktop
When booting up after the logo the computer goes to black screen. There are no beeps at start up. When starting in safemode it stays with black screen with the safe mode written in the corners
In safe mode try pressing ctrl+alt+del, then go to task manager-->applications-->New task, then type: explorer.exe Now your desktop should appear. you could also try running: msconfig In the same way, and see wether explorer.exe is still in the startup. Adding it again will permanently solve your problem. I hope this helps, Yannick.
Jun 13, 2009 | Dell Dimension 4400 PC Desktop
Loads dell logo then goes to load xp then screen goes blank
Try going into safe mode if you can by pressing the F8 key when you first turn on the laptop.
If you get into safe mode then go into the system configuration utility underneath the system tools folder. Click on the startup tab and then click on the button that says disable all. This will keep programs from loading when windows boots up. Reboot the computer and see if you can get into windows normally. If you can then you know its a program thats causing the problem. If you still can't get into windows normally then you'll have to wipe out the drive and restore your computer back to factory default.
You also will have to do this if you can't get into safe mode as well.
May 04, 2009 | Computers & Internet
Inspiron B130 won't boot
plz try to boot through safe mode, if you can then log in normally.
if you cant boot from safe mode then you have to reload or repair your os.
Dec 23, 2008 | Dell Inspiron B130 Notebook
Blank monitor
To resolve the problem,do the following step,
1. Power on the system
2. At dell logo screen before windows xp starts to load tap on the F8 key slowly 5 to 8 times
3. Select safe mode
4 Hit enter on the next screen and logon using the administrator or your name
5. Do the system restore, when you have logged on, this would return your system back to the date when it was working fine
6. To system restore
click start>all programs>accessories>system tools >system restore
Thanks
proton
Oct 11, 2008 | Dell Dimension 2400 PC Desktop
Booting problem
Try putting the computer into safe mode by holding down on the F8 button and selecting safe mode during the boot process. Once you get to the safe mode screen and windows appears, restart the computer.
If that doesn't fix the problem you will have to restore Windows.
Jun 12, 2008 | Dell Latitude C640 Notebook
Dell Dimension 4400 PC Desktop Logo
916 people viewed this question
Alun Cox
