Question about Toshiba Satellite 1105 Series 14.1" Flat Panel LCD Monitor
Toshiba Sat A100 LCD Panel looks like in matrix movie...
please advise: I have Toshiba Satellite A100 with LCD panel as black screen with some vertical lines... when I plug external monitor - it works nice. My understanding that LCD panel is faulty... any other ideas?
thank you
  • 175 Answers
SOURCE: random screen freeze
You are going to need your WINDOWS CD:
Posted on Dec 03, 2007
  • 1800 Answers
SOURCE: I am looking at a
new flex cable jim
try to purchase a new one first before taking it apart
also try to use a LCD or a normal CRt using the VGA or DVi cable!
Posted on Dec 01, 2008
  • 107 Answers
SOURCE: toshiba satellite a105 screen problem
You need a new lcd, The connectors are bad...
Posted on Dec 13, 2008
  • 43 Answers
SOURCE: black line
it could be two things, several rows of non performing pixels, or one of the boards has gone out in the television, i would recomend unplugging it for five minutes and plugging it back in to see if it continues, bring up the menu and see if the black line cuts through that as well as another source, if that all fails call toshiba and see if its under warranty, either have them repair it or return it to the store
Posted on Jan 24, 2009
SOURCE: LCD screen has black and red colrs + a green vertical line
Reset the video card, and if that doesn't work it sounds like the card is dying. How old is the card?
Posted on Apr 03, 2009
What did toschiba satelite 8100 lap top model number psaane/03j02gen transpose to
The Model Name and Model Number is Satellite A100-033.
It's one of the Satellite A100 series of Notebook PC's.
3) Free Service Manual for the Toshiba Satellite A100 series of Notebook PC's,
Go down to the line that starts with Satellite A10. Scroll across, and click on A100.
This is a PDF file.
It may take up to 30 seconds before the first page comes up. It may also take additional time to fully download
{Service Manual for your daughter's laptop. I gave a solution to another one of your posted problems}
For additional questions please post in a Comment.
Jul 17, 2011 | Toshiba Computers & Internet
Satellite L500 monitor is completely black. One can faintly see the welcome and password bars
Try to go to Toshiba Power Settings in the control panel and change the lcd brightness from there. If this won't work, this may be an LCD backlight issue and you would need to have a professional to change it for you. If it is under warranty, send it to toshiba for replacement.
Hope this helps.
May 30, 2011 | Toshiba Satellite A100-S8111TD Notebook
My satellite screen is not function on my lap top, but when connected to an external monitor the screen is visibile on the exnternal monitor but not the lap top. Does this mean I need to purchase a new...
there is a panel by the hinge look at rear of computer you will see some very small screws take out then gently pry up panel you will see some screws on the hinges just tighten the screws then replace panel and screws at rear of computer hope this helps
Jul 22, 2010 | Toshiba Satellite A100-S8111TD Notebook
Toshiba a100 screen not working
The easiest and most foolproof method for testing your LCD screen is to hook up the laptop to an external monitor. If the video output on the external monitor looks fine, this means that the problem is with the video connector, with your LCD panel itself, or with the circuitry that turns on the LCD.
What do we do? It all starts with disassembling the notebook. Find the video connector on the system board (if the video is integrated on the motherboard) or on the video card that is attached to the motherboard. Try re-connecting the cables. You may as well locate the display connector on the back of the end LCD panel. Re-seat that one too. This way you can be sure that the problem is not related to connections.
Every now and then the switch located on the system board that turns the backlight of the LCD on and off can become stuck. If this is the problem then your LCD never powers on. There's a little switch that detects whether the screen of your notebook is open or closed. That's the one we're talking about. Try to push it down and hope it gets unstuck.
Disassembling the laptop to unstick this switch is an option, but sometimes you can get away with not taking it apart. Try lightly hitting that plastic switch. But wait, this isn't the only possible cause, unfortunately. Re-seat the other connectors and cables that are present around the LCD panel and the video on board (including the inverter).
All of the aforementioned can usually be fixed, but let's not forget about the screen itself. Sometimes the screen can become defective. Here we'll enumerate a few scenarios where the screen has gone bad and must be replaced: lots of vertical lines or bands appearing on the screen; half of the screen works fine but the other half stays either black (blank) or really white; the output on the screen looks blurred and changes to different patterns; and so forth. These are almost always signs of a defective LCD panel.
However, if the output on the screen is nothing but garbage, such as incorrectly placed special characters, shadows around the characters, unknown randomly placed marks of different colors, distorted or ugly-looking geometric patterns, or tiny little white dots all over the screen, then these are almost always due to the system board or the connection between the LCD panel and the video card. Re-seat the connectors.
All in all, these are some of the most common hardware failures. Nevertheless, before we finish this part, let's name some of the others that will be covered in the second segment of this guide, along with the promised system instability troubleshooting strategies. These include clicking noises coming from the HDD, which is the well-known symptom of a dying HDD. Thus, back up your important data as soon as possible and order a replacement. Overheating is also discussed thoroughly.
Hope it may helpful for you
Aug 25, 2009 | Toshiba Satellite A100-ST3211 Notebook
Toshiba satellite 25505 screen resizing
Toshiba Laptop Mouse-pad Screen Resizing is annoying. Here is the solution. Go to: Control Panel < Mouse < Device Settings <Settings (middle of page right box) open it and look at menu on left top and select Pinch Zoom and disable it. The pinch zoom re-sizes the window bigger or smaller . This is what happens when you have you left finger on the mouse-pad while scrolling with you right, its doing the same thing as re-sizing the image like one does on a i phone using index finger and thumb.
Aug 04, 2009 | Toshiba Satellite A100-S8111TD Notebook
Toshiba splash screen freeze
sounds like a bad hard drive to me. I would suggest testing the hard drive using a bootable testing program like pc check and if it is bad replace the hard drive and restore the operating system
Jun 19, 2009 | Toshiba Satellite A100-S8111TD Notebook
Black screen on my laptop - no any pictures - laptop is starting OK
well i would say to tack up the key bored and see of the cognation is tiet if not tion it. if it is it would be the screen. sorry for the spelling i am disleksia.
May 28, 2009 | Toshiba Satellite A100-S8111TD Notebook
Apr 03, 2009 | Toshiba Satellite A100-S8111TD Notebook
If I open my Satellite A105 display too far, it goes black.
Hi, This is definitely a loose connection problem.
Does the screen go completely black or just a part ?
If its just a part, LCD is defective. You may have to change the whole LCD screen. You can get one for ~180$ from ebay
If the whole is turning off, I guess the power cable might be little loose.
You can open the LCD panel and check if you know what you are doing.
Else take it to a normal technician and ask him to open the LCD panel and see it.
Nov 17, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba satellite A100 Monitor problem
LCD issue it needs tosh if your laptop is still in warranty
Feb 01, 2008 | Toshiba Satellite A100-ST3211 Notebook
Toshiba Satellite 1105 Series 14.1" Flat Panel LCD Monitor Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
