Question about JNI FCX2-6562-E Network Adapter
System not detecting the disk array.
Hi, in a Sun Blade 2000 we are trying to install a SGI TP9300 through Brocade 4100. The HBA is from Sun, P/N: 375-3157 which is JNI-FCX2-6562-L. In the "OK" prompt the system is detecting the drives but not in the OS Solaris 8. We tried doing all the available commands like, devfsadm, sd.conf, etc. All the patches are installed. Plesase help. regards Pinaki pinakikar@hotmail.com
    Problem Solver:
  • 6 Answers
Hi there, You apparently don't have downloaded all drivers and software needed. I'd go to: http://www.sun.com/products-n-solutions/ hardware/docs/Network_Storage_Solutions/Adapters/index.html. Install the software in the following sequence: 1. Download and install Sun StorEdge SAN Foundation software 4.2 packages and patches. See Sun StorEdge SAN Foundation Software 4.2 Installation Guide, 817-1244. 2. Download and install the appropriate JNI 2 Gb PCI Single and Dual Port HBAs packages and patches. See JNI 2 Gb PCI Single and Dual Port Fibre Channel Host Bus Adapters Release Notes, 817-2260. Good luck!
Posted on Aug 11, 2007
A disk read error has occurred when booting a Dell PowerEdge 2950. Passes all diagnostics. Will run chkdsk from CD. Raid battery was degraded at last reboot but all disks showed to be fine. Raid 1
what OS?
what disk?
no raid card stated, no array stated, no type of array stated.
One can put 100s of RAID cards in this server.
both raid cards or HBA cards,(forJBOD)
i can fix any server, but first need to know what is in the box first
you meant the boot disk has errors, right,? boot.
that would tell me the disk IS BAD.
but if and ARRAY , that means you must run SMART tests
on the disks, 1 by 1 to find the bad disk.
if smart shows its bad, or weak its for sure BAD.
on real servers. the server sends you email, (set up right)
telling you disk 3 in a RAID 6 is bad, replace it now.
are you running hardware or software raid, or HBA or
fake raid cards, (4 classes there.!)
the base system new has.
4 port SAS 5/i integrated SAS controller (no RAID_
and optional, from DELL , news.
Optional PERC 5/i integrated SAS/SATA daughtercard controller with 256MB cache,
PERC 4e/DC, PERC 5/e adapter
or any of 1000s of other aftermarket cards there.
I run LSI 9361s (with MSM appl loaded)
this card will tell you what disk failed every time no kidding.
so will the PERCs setup correctly
the PERCs and my LSI and my HP raids
all have installed monitors for the RAID ,a program that runs full time all the time, and reports errors , many ways,
did you load that first and use it? seems not.
as no mention of SMART at all.
good luck.
Im not sure the names on DELL , MSM like software.
ah its OSA
never run a PERC lacking this APP. or you can not keep the server on line,.
http://www.dell.com/support/search/us/en/04#q=Dell%20OpenManage%20Server%20Administrator&sort=relevancy&f:langFacet=[en]
Mar 05, 2018 | Dell Computers & Internet
Hard disk drive not detected during installing windows server 2003
It depends on what type of drive you are using. Plus, you may have to specify the array controller drivers if your are using the SAS (Serial Attached SCSI) drives.
May 22, 2013 | Dell POWEREDGE R610 (4640223) Server
An error code jfb0 Bus Eror - Data Parity Error Detected Parity Error The system is a Sun Blade 2000 What can I do to fix this
replace or remove whatever ram chip is faulty, that error refers to a crc check on ecc memory. Or you could just turn off ecc parity checking in the bios. But that simply defeats the object of having ecc memory in the first place
Feb 24, 2011 | SunBlade 150 (A41UPA19C256MBA) Server
SilkWorm 3800 password recovery
I hope that some of the info there is helpful: http://forums.sun.com/thread.jspa?threadID=5093675 Good luck
Nov 08, 2009 | Sun Brocade SilkWorm 3800 Networking...
New install scsi hard disk no detect in ibm x3400 server
you will need to add the new drive to your array bbfore it will how up to be formated do this throught the array configuration util
Regards Al "alstech"
May 26, 2009 | IBM x3400 Server
Need to find out to what Qlogic model is this SUN OEM HBA =2
I don't know what kind of OS you used
but you can find the driver from here
http://driverdownloads.qlogic.com/QLogicDriverDownloads_UI/SunOEM.aspx?oemid=124
just download what you need
search "x6767a"
Jan 28, 2009 | Sun 2GB PCI Single FC-AL Host Adapter (p/n...
Upgrade Sgi 320 To Windows XP
I got this from wiki
The 320 and 540 Visual Workstations shipped originally with Microsoft Windows NT 4.0. Due to the ARCloader PROM, a custom Hardware Abstraction Layer (HAL) for Windows was necessary. Windows 2000was the last release which included the required SGI-specific HAL.Because of that, and because SGI ceased supporting the VisualWorkstation series, installation of future Windows versions such as XPis unsupported.
So it doesnt support xp. if u use windows 2000 it might just work. Its hardware design makes it not xp compatible.
Dec 31, 2008 | SGI Silicon Graphics Silicon Graphics...
Hard disk can be repear?
did you try to check your cd or dvd rom if its detected too? does the disc you put is readable and bootable? what OS are you installing? ask me again if anything happen.
CHARCOIS
Aug 21, 2008 | Sun FIRE 28 (Refurbished) (SUNFIRE280R)...
Run Compaq Array Configuration Utility
Hi Foambob,
Try all means to get a smartstart CD.
Normally new version will be able to use on older hardware , but no guarantees.
I have always found it easier to use smartstart CD auto mode.
You can also do the install and then run ntssd to update all the drivers etc., but I don't recommend it for novices. Use the auto mode , it takes longer but safely and surely.
Good luck
May 21, 2008 | Compaq ProLiant 5500 Server
Driver for Fibre Channel HBA A5158A
Can you share the firmware version of HBA & server 7400 BIOS version
Dec 18, 2007 | HP A6795A#0D1 Network Adapter
JNI FCX2-6562-E Network Adapter Logo
186 people viewed this question
Top JNI Computers & Internet Experts
Alun Cox
k24674
Are you a JNI Computer and Internet Expert? Answer questions, earn points and help others
