Question about D-Link AirPlus DI-524 Wireless Router
Still Can't connect
O.k I went to the http://192.168.0.1 link and accessed the router. I used the wizard to set up. Bad Idea? I changed the admin password and finished the wizard. After I clicked restart. (Not restart actual computer) Then I tried to access a web page to see if it worked and it won't get online. Now I have a cable modem.. connected to the WAN port... Then it has four ports which I assume are LAN ports. I have a cord running from port 1 to the back of the PC. With things wired this way I am unable to access the internet. I was thinking I had it but I can't connect.On the right track?
I had same problem. I ran all the steps again but this time i DIDNT clone, and it now works fine.
Posted on Nov 01, 2008
D link set up wizard dir615
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, open the browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings. (SSID, WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access). Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Mar 26, 2013 | D-Link DIR-615 Wireless Router
Easy setup wizard
Connect a LAN cable from the D-Link to your laptop/computer'sLAN port, open the browser on your laptop/computer and enter the D-Link's configurationURL..
http://192.168.0.1
The default PW = blank (just press Enter)You can now change the default admin password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jul 06, 2012 | D-Link AirPlusG DI-524UP Wireless Router
Trying to set-up d-link 615 wireless router without set up wizard disk. replacing out of date wireless router so have internet now but computer will not connect to new router when i try. need set-up...
You can also configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then click on WAN settings set it as your internet service provider settings enable DHCP Then click on wireless and enable it. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Aug 06, 2011 | D-Link DIR-615 Wireless Router
How to change the username and password
Log in to your router settings and go to advanced tab. On the left hand side, options are lsited and pick wi-fi -protected set-up. Mark the check box labeled "Lock wireless security settings and pin will be generated. Check this site to see how it looks like: http://www.support.dlink.com/emulators/dir825/Protected_Setup.html
Please rate this article.
Hope this helps. :)
-Hanna
Mar 15, 2011 | D-Link AirPlus DI-524 Wireless Router
How do I change the ssid and make secure
Securing the router:
http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=3696
Changing SSID:
http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=4037
Mar 05, 2011 | Linksys Wireless-G WRT54G Router
I want to change the channel my Linksys is using. So I went to Internet Browser and typed in my IP address. It said I need a Username and Password. Where would I find that.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . If you are not able to access router with above user and password then yo need to reset it. For that press RESET button for 10 seconds it is in back side of router.Then configure it again with above method.
Dec 05, 2010 | Linksys Wireless-G WRT54G Router
I'm trying to install a new 628 router. The wizard won't work and I have no clue what else to do. I have connected the router as per the limited instructions in the quick set up guide but it's not...
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . Let me know if you need further assistance. Thanks for using FixYa.
Dec 04, 2010 | D-Link Computers & Internet
How do I change the wireless channel on my ZyXel P660HW-T1 router? I use the NetGear smart wizard that came with it.
First connect your router to computer with ethernet cable.
Then you can access it with below defaults link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
If you are not able to access with above link then go t ostart menu ->run type in run "cmd"
then type in command prompt "ipconfig /all"
There is gateway ip is ip of your router.
YOui can access router with that gateway ip.
Then you can see configuration page .
Click on wi fi or wireless then change channel type to 4, 6 ,or 11 .These 3 gives best result.
Then save settings and restart router for take effect.
Let me know if you need further assistance.Thanks.
Nov 16, 2009 | Zyxel P660HW-D1 Router
Username /password to change
to change username and password in dlink router you have to access http://192.168.0.1 in the address bar of internet explorer
it will bring you to the configuration screen of dlink.. it will ask for the dlink usid and password, the default userid is "admin" , for the password leave it blank.
  1. The router's Web-based Setup Utility should appear. Do not run the wizard. Select the WAN button on the left-hand side of the screen.
  2. Select the PPPoE and Dynamic PPPoE options on the WAN settings screen.
Enter the your USERNAME and PASSWORD that your broadband connection provider gave you into the corresponding fields and select Apply and then Continue.
Once the screen refreshes, exit the browser.
now try to connect
Jul 18, 2008 | Computers & Internet
Problem with startup wizard
For security reasons some wireless routers will not allow access to their setup pages via wireless unless some settings are changed.
you have to connect to the router from your computer with a ethernet cable into port 1,2,3 or 4 (ports at the beck of the router)and go to the website
http://192.168.0.1
A logon pop-up screen will appear. Type "admin" for the username and leave the password field blank.
make sure you plugged the "internet" ethernet cord into the internet or WAN port at the back of the router.
Feb 24, 2008 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
