Question about HP Compaq Presario V2000 Notebook
Ports-Connection I am trying to connect my printer and my PC does not offer USB as a connecting port. What can I do?
  • tramartre Oct 30, 2008
    Sorry, this is a desktop I'm working with.
  • 33 Answers
Hi
In your device list, don't you see USB ports isntalled?
If not, you need to install them first.
And if you can't have them installed or recognized by windows, you should enable them from your BIOS setup.
In your Bios Setup, search for "On Board Devices" and go to "On Board USB" then change it to Enable if it's Disable.
Save changes, restart you computer, then wait for windows to log on and wait for the USB ports to be recognized by Windows. Finally try the Printer.
If the problem presets, you may need to buy a USB Card which is not expensive.
I would be more happy to help if any drivers needed.
Posted on Nov 05, 2008
The port to which the printer is connected is not supported. Check the port
I'm assuming you are using a USB connection, not a Ethernet connection.
Try a different USB port (preferably in the REAR of the computer, not the front). It's not unusual to have 1 or 2 poorly-performing (low power) ports on a PC; some printers don't like those.
If you have a really old computer, it may have ancient USB type "1" (slow) ports instead of the newer 2.0 or 3.0 USB type. Some printers don't like old USB 1 ports, but it is not supposed to matter.
If all else fails, try another USB cord, or a shorter one. Some printers don't work well with cords longer than 4 feet, and USB cords can go bad.
Or, try the printer on another computer. If the same USB cord works fine there, YOUR computer has the problem (probably a USB port or USB driver issue).
Are you having issues with other USB devices? If so, it may be a Windows driver issue.
Good luck. If no help, post your exact printer model # here, or try contacting Lexmark.com support
Dec 02, 2013 | Lexmark All-in-One Printer with PictBridge
Tip
Options for Adding Serial Ports The serial port is prevalent on PC's ...
The serial port is prevalent on PC's as well as scores of industrial, scientific and consumer devices, making it a convenient starting point for communications. Since RS-232 itself is only suited to short connections (50 ft. max.) many applications require that it be adapted to fit requirements. RS-422, typically used for extending RS-232 communications, provides full duplex communications between two devices. It can also provide one way communications from one master to several slaves. RS-485 communications standard allows cable lengths up to 4000 feet. It also provides very high noise immunity. Multidrop connections up to 32 different nodes can be made over a single twisted pair cable along with a signal ground connection.
This article summarizes the choices a system designer has when adding a serial (RS-232, RS-422, or RS-485) communications device. There are many different ways to add additional serial ports to your Desktop PC, Palm, or Laptop PC. USB, PCMCIA, PCI and ISA are some of the methods that will be discussed.
The Universal Serial Bus (USB) provides a high data rate and Hot Swap connection for PCs, providing an easy connection to a wide variety of multimedia and network USB devices. Generally considered to be for home or office use, USB is finding its way into Industrial applications.
PCMCIA Serial Ports are yet another way to add serial ports to a PC that has PCMCIA Slots available. Most Laptops today offer only one (if any at all) DB9 type serial ports. A PCMCIA Serial Card is a good way to add a serial port (or ports) to any laptop that is low on available serial ports (RS-232, RS-422 or RS-485).
PCI Cards are becoming more popular as a way to add serial ports to desktop PC's. PCI type slots are becoming the "norm" in standard PC's today, and PCI Serial Cards are an excellent way to add serial ports. The standard Desktop PC may only come with one serial port standard (if any serial ports at all). PCI Serial Cards use Software Drivers to address the ports to the PC.
ISA Cards are yet another way to add serial ports to the older desktop PC's. ISA type slots are becoming scarce in standard PC's today, but are still an excellent way to add serial ports. The ISA Cards are typically addressed using dip switches and shunts or jumpers to set IRQ's for each port. No Software Drivers are required with ISA style serial cards.
Palm OS PDA's may be connected to RS-422 or RS-485 data circuits using Palm adapters. These adapters offer total portability for collecting data and field service chores. The Palm device and the adapter will usually slip into a shirt pocket. Some models use the PDA's connecting cable, some include a cable and some are cradles that allow the PDA to nest in place and connect directly to the Palm base socket. PalmTerm Freeware allows you to transmit and receive data from the Palm serial port.
on Sep 12, 2010 | Computers & Internet
It seems like the computer and printer are not communicating. I do all the moves on the PC but when I command "print" nothing . I've checked all the cables and even changed USB ports, still...
hi,
  • Is the printer properly installed?
  • Have you set it as your default printer?
  • On the start menu, click on printers and faxes.
  • Is the printer checked[ticked]? Right click on the printers icon and select properties.
  • Check the printers connections by clicking on ports.Had you used same ports connection?
  • If not set them right.
  • Click on print test page.
  • Restart your PC and try printing now.
Sep 16, 2011 | Lexmark Office Equipment & Supplies
Lexmark X 4550 scans ok but when i try to print, "incorrect port detected" comes up as a fault, i have it all connected ok and in a usb port. can anyone help please.
look under control panel ,printers and faxs, right mouse click on your printer displayed in the list , then from the list, select properties . Next from the tabs on top , select ports, from the ports list select the usb connection on the list or if wireless you should have a lexmark connection port showing as well. Its just you havent got the correct port selected.Dave
Jun 06, 2010 | Lexmark X4550 InkJet Printer
All USB ports on my emachines T6542 do not work
try to see the BIOS SET UP if the USB port are in enbled status..
if its not,, enabled them...
and see the connection of the USB port into your motherboard if it connect properly..
Oct 27, 2009 | E-Machines eMachines Desktop PC
Why don't the usb ports work on the side of monitor
is there an extra cable, aside from the Power Cord, and the VGA Cable? if not, look on the back of the monitor, there should be a similar plug in like a USB printer would have, its kinda square. If there is, you just need a USB printer cable to make it work.
Oct 04, 2009 | HP Pavilion (PN153AAR) PC Desktop
How to map usb ports USB1, 2, etc.
You don't map the Universal Serial Buss. You just hook all the devices to the connection points (ports). The computer find them by device, MAC address, etc., not by port number. You can hook up to 127 devices to a computer, and the computer will talk to all of them regardless the physical point of connection. That's the reason, you can buy USB hubs with 4 or more connection points that plug into an USB port (how do you map that?).
USB1 - 6 is for you to know how many devices are connected to the computer via USB at a certain time.
So if your printer is configured for USB1, what ever port you plug that printer in, will be USB1.
Oct 02, 2009 | Dell Dimension 2300 PC Desktop
USB port problems with hp printer
use 2.0 ports and not less than that.if still nothing works out,check your port connections or that of ur printer.
Jan 03, 2009 | HP DeskJet 3745 Printer
Port problem
there are many devices you can get to add usb to an existing device....ext keyboard connection.pmc slot,com ports ,printer ports even usb ports to update usb 1 to usb2 (of course that ones no good for you)
these are all plug and play devices
you could also install one to pci (easy in desktop)
Oct 30, 2008 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
66 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
