Question about Kenmore 24032\24036 Top Load Washer
Agitater not agitating too!
I want to thank you for your postings. I was able to pop 4 dogs in and continue with the laundry. You saved me a service call and some cash to boot. Thank you for the time you spend on this site, I wanted you to know I greatly appeciate it! Ron, Bethpage Tennessee
  • 324 Answers
Ya this is a great site
Posted on Nov 03, 2008
The agitatae doesn't seem to be cycling the
The agitator is made in two parts. Upper and lower. The bottom part does the actual agitating.
The upper part is supposed to be loosely fitted. It just screws down the clothes to contact
the bottom agitator slowly.
The top part turns one way, and slips the other way. By the action of what is called "Dogs" inside
the top part. These dogs are probably worn and need to be replaced
Take the top off the agitator and there is one bolt in the middle of the agitator. use a long extension
to reach the bolt and remove it.
Pull off top agitator (keep it straight up so you don't lose the dogs_
Go to local Appliance store and ask for Agitator Dogs.
Replace Dogs exactly as they came out
When you re-assemble the top it will be loose. This is normal.
Good Luck!
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 24, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
After top load washer fills with water you can hear the agitator but the agitator does not move
Apr 03, 2010 | Washing Machines
Series 70 washer model 110 26712690 agitator does not move, is this difficult to fix, how much is the cost
it is a .99 cent fix,pop the top off the agitater,remove the 7/16 bolt,pull the top half of agitater off,there are 4 small gears in there called dogs,they need to be replaced,you can get them from your local appliance parts store,put it all back together and your done-mike
Feb 10, 2010 | Kenmore Washing Machines
Top of agitator does not agitate with lower agitator.(dual agitation) whirlpool model LA3860XW00
You will need to replace the Dogs. Take cap off of the center of the agitater, take bolt out of center and pull agitater up and off. Pull two pieces apart. There are four dogs that catch on gear teeth inside your agitater. The four dogs come in a hit, sometimes with a couple other pieces. Has to do with which model you have) replace these four and any other pieces that come in the kit you order. This will fix your problem.
Please rate solution
Aug 31, 2009 | Whirlpool Washing Machines
Kenmore top loader. agitater won't turn unless you
sounds like the agitator cams are worn out. Pop out the top fabric sofner dome where you would put the downy into. (If your moddel has the green looking snapping ring just below the dome, you would have to snap it upwards and the dome comes off then theres a top cover you jus pop off) . . now you will see the agitator cam. I dont think theres a bolt that holds it down. You have to use a rachet extention that fits into that middle squar shaped hole and unscrew, then take out the agitator cam and replace the 4 little teeth. (make sure you put them in the same way and they slip in there slots ) hopefully this helps...
go to this this link. what you would need is the 3rd picture down. it says "Dog agitator/agitator cams" its the 4 little yellowish looking pieces.
Jul 31, 2009 | Washing Machines
Single agitater but top part don't work
Hi, You need to change the dog kit inside the agitator. Remove the 7/16" bolt holding the agitator in and lift it off the shaft. The agitator will pull apart and then you can see the dog kit.
Please let me know if this helps you at all or if I can assist you further,
Jul 23, 2009 | Washing Machines
Kenmore 90 series washer 110.28902790
if you remove the agitater cap and the inside cap,you will see what they call dogs(4 of them)they wear out and the agitater will not wotk,if you remove the 7/16 bolt and pull the agitater off you can replace them and all will be fine,you can get them at your local appliance part store,please leave me a fixya-mike
Mar 12, 2009 | Kenmore 15864/15862 Top Load Washer
Estate top load washer
it you pop the top on the agitater you will see 4 gears called dogs, remove the 7/16 bolt upll the top half of agitater out and replace the dogs,you can get them at your local appliance part store,let me know how you do-mike
Oct 27, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
No agitation
I have a Whirlpool Utlimate Care II LSQ8520JQ0. For those having a problem separating the upper and lower agitator halves, here's how I solved it after about 2 hrs of aggravation.
Called Sears and Whirlpool with no help (didn't have tech manual...go figure).
I saw the same post with the problem with melted hooks (I called them tabs) ontop of the dog housing being melted. You can differentiate the melted tabs from the dog housing as the dog housing is usually clear plastic (after wiping all the crud off) and the tabs are white as they are part of the agitator. There will be four white tabs on top of the dog housing. They look both smashed and melted. I took a flat head screw driver and and hammer and chipped off the white melted tabs visible on top. I inevitably also chipped some of the dog housing but only marginally. Once chipped off you'll see the tabs are actually rectangular in shape. At this point I EASILY pulled the top and lower halves apart. Those retangular tabs are the molded part of the agitator housing extending down past the dog housing. You're home free at this point.
It's the melted tabs on top of the dog housing that keeps you from separating the halves. What a pain but finally figured it out.
Oct 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 24032\24036 Top Load Washer Logo
24 people viewed this question
Sal De
 Brian Main
Brian Main
