Question about Philips 14PV375 14 in. TV/VCR Combo
TV shuts itself off as soon as I press 'play' on video.
About a month ago, my TV/VCR developed a problem: It would switch itself off while it was playing certain video tapes. Whenever it would do this spontaneous shutdown, the remote and manual controls were useless, and the only way to get the video playing again was to cut the power, eject the cassette, re-insert the cassette and turn it on again. Initially, it was a rare occurance, and I put the disruption down to faulty or old video tapes. The problem persisted however, and began to get much worse. For a while I was able to resolve it by repeatedly fast-forwarding and rewinding the video for several minutes before playing. After a week though, even this solution proved fruitless. As it stands now, the screen flashes off as soon as any cassette is inserted into the video slot, and no amount of forwarding or rewinding can get it to play for more than a few seconds. At first I was sure the problem stemmed from the video portion of the machine, and that possibly the tape heads needed cleaning. But the machine is barely a year old, and the shutdowns are so persistant that I can't help but think that the problem is linked to the power supply of the entire unit. Has anyone out there experienced anything like this before, and if so, how did you remedy it? Robert
  • Anonymous Feb 08, 2008
    i have the same problem is any solution please rply at matrix291194@gmail.com
I have been having the same problem with my vcr tv combo have you found a solution yet??  would help over here if you have.
Posted on Oct 14, 2007
    Sergeant:
  • 337 Answers
The set has a problem on the mechanical section of the VCR,it might be out of aligment or a part has gone bad completely and now needs to be replaced,dirty heads will not give you these symptoms,the power supply is sensing a problem and is doing what is suppose to do when it detects a problem,it seems that you only have a use for the TV unless you get the vcr repair.
Posted on Sep 13, 2006
Why GE TV plays color DVD/VCR tapes in black and white
Some inputs on tvs won't process the color signal. Try one of the other inputs. Mine does the same. If u have already used the working ones on something else, U will need a switch to select one or the other available at Radio Shack if u can find one.
If you need further help, reach me via phone at https://www.6ya.com/expert/gary_9c859f4aa7e5ab10
Jan 22, 2018 | GE Televison & Video
I took out some 2001 9/11 taped back then. Inserting them the TV message was CLEAN VIDEO HEADS. I don't know how to do this. Are the video heads on the VCR or on the video tape? What would i use to...
You can purchase a VCR cleaning tape that will do the job. However the best way is to buy a can of Servisol Video 40 (small one will do and it will last a long time) then remove the top cover of the VCR. Spray the VCR heads. Shinny Silver things and any moving parts that the tape touches. If your not certain what to clean, with the cover off insert a tape and press play. Remove the tape and spray small amounts on the surfaces. If you can see a lot of dust you can wipe the heads etc with a cotton bud. A VCR housed in a smokers house will need extra work to get it clean. Once dry you can test a tape. If you see flecks or spots the VCR will need further cleaning.
Sep 13, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Model is Sylvania DVC 840G, DVD/CD player with VCR. Have limited space. VCR on seperate shelf in cabinet, had to put two TV converters on top of VCR (top each side) so we could watch TV and tape a...
The tape mechanism belts have stretched and the unit is not running properly. When this happens, microprocessor is programmed to eject tape and shut down unit.
Apr 11, 2017 | Sylvania Televison & Video
Iv got some old vhs tapes and when i put them in the vcr to play they jump and give a fuzzy picture can you help me please. thanx
All you can do is adjust the tracking and make certain the video head is clean. I would have a look inside each VHS tape at the tape itself, it might have got mould or damp inside it.
But if the video machine plays back it's own tapes and commercial tapes OK, it could be the tapes have gone bad.
Dec 06, 2010 | Sony Televison & Video
It was working perfectly until I hit the pause button. When I hit it, it turned off immediately. Now whenever I turn it on, it stays on for a few seconds after the display goes away and then turns off....
I believe that the tape must have fowled up and the mechanism has gone haywire and now out of sync. Every video has a mode switch. This tells the electronics what position the mechanism is in. However if the mechanism develops a fault, the mode switch will no longer be able to tell the electronics the true position and thus chaos develops, so the whole thing shuts down. You need to investigate to see if the tape is entangled or damage has occurred.
Aug 05, 2010 | Emerson EWV601 S-VHS VCR
A video tape has become stuck in my Mitsubishi VCR
Hi, Suggest call a local tv repair shop. Thanks.
Sep 22, 2009 | Televison & Video
Unable to separate VCR playback from Sat. Receiver input,both av2
try to find a multi-video selector swicth that the best you can do
Dec 19, 2008 | Dynex DXR24TV 24" TV
No picture while playing DVD or VHS tape
Your unit has it seems to have developed a video problem. it could be in the video switching IC or the video processor. Its going to need a trained technician, who knows how to use an ocilliscope to find the video problem.. Good Luck
Aug 02, 2006 | Insignia IS-DVD1001 DVD Recorder/VCR
Adapter question
There are no such adapters that would allow 8mm, Hi8 and Mini DV tapes to be played in a VHS VCR. Only the old VHS-C tapes can fit and play in an adapter. There are several reasons why 8mm (or Hi8 and miniDV tapes) cannot be physically played in a VHS VCR: 1. 8mm (Hi8, miniDV) is a different format with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with current VHS technology. 2. 8mm/Hi8 tapes are 8mm wide (miniDV is 6mm wide), while VHS tape is 1/2" wide, making it impossible for a VHS video head to read the taped information correctly. 3. 8mm/Hi8/miniDV tapes are recorded and played at different speeds than VHS, so even if the tapes could physically fit into a standard VHS VCR, the VCR still couldn't play back the tapes at their correct speeds. 4. 8mm/Hi8/minDV audio is recorded differently than VHS. 8mm/Hi8 audio is recorded in AFM HiFi mode, while miniDV audio is recording in 12-Bit or 16-Bit PCM digital audio format. So, even if the video could be played back in a VHS VCR, the audio could not be read properly. 5. 8mm/Hi8 video is of higher resolution than VHS and is recorded in a different bandwidth length (miniDV video is recorded digitally), so once again, a standard VCR still could not read the information correctly, even if the tape could fit into a VCR.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Philips 14PV375 14 in. TV/VCR Combo Logo
142 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
