My computer on start up comes up with system32\hal.dll. Need to reinstall
  • 903 Answers
Have acer aspire one, when started got screen saying file missing or corrupt window root system 32 hal.dll, nothing else cannot bring up safe mode do not have windows xp cd, in nursing home cannot afford...
I am going to start with the assumption you have already tried to reboot, then next choices from there go kinda like this...
Run windows XP restore from command prompt. (From safe ,mode type C:\windows\system32\restore\rstrui.exe and press Enter. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
Replace the boot.ini file (run msconfig) This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
Note: If repairing the boot.ini does correct the hal.dll issue but the problem reappears after a reboot and you've recently installed Internet Explorer 8 in Windows XP, uninstall IE8. In this specific situation, IE8 could be the root cause of your hal.dll problem.
Right click on c: drive, click on properties, then tools, click on the error checking button, the put a checkmark in each box, Click start and it may say it needs to run on next reboot click OK the reboot. The physical part of your hard drive that stores any part of the hal.dll file has been damaged, you're likely to see errors like this.
Run a repair install of the operating system. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
Nov 29, 2010 | Computers & Internet
When I turn my Gateway Profie 3 computer on, it will not boot up and displays the message: "WIndows could not start because the following files is missing or corrupt Windows^Root^\System32\ hal.dll....
Hi There,
Sounds like you're running XP bercause the hal.dll issue is almost always an XP issue. It's not the easiest thing to fix. Most often you need access to a floppy drive and floppy disc or you have to create a bootable CD that fools the computer into thinking it's a floppy with the replacement installer for hal.dll.
I recommend you read the info at the site below and decide whether to attempt the fix yourself or get assistance at your location.
http://www.computerhope.com/issues/ch000490.htm
Regards,
Selk
Nov 19, 2010 | Gateway Profile 3 PC Desktop
My PC wont to start .its says to reinstall windows root system 32 hall.dll
go here to download it on another computer>> http://www.dll-files.com/dllindex/dll-files.shtml?hal
unzip the file onto a USB zip drive than go plug that into your computer and install it. should be pretty simple if it doesn't work try going here and reading up for other possible solutions >> http://social.microsoft.com/forums/en-US/tabspace/thread/b82154ee-6dfd-4ed6-8450-cb22cce444f5
Nov 14, 2010 | Computers & Internet
How do you fix computer error: <windows root>\system32\hal.dll
HI,
You can use the following Link to help you troubleshoot the Hal.dll problem on your computer. If the same is not resolved , the problem could be that the hardrive on the system is going bad.
Troubleshooting link
Thanks for using fixya
proton
Sep 06, 2010 | HP Pavilion Media Center a1320n PC...
<Windows root>\system32\hal.dll
try to do a upgrade from the cd from ur system
Jul 04, 2009 | Computers & Internet
"<Winnt_root>\System32\Hal.dll missing or corrupt:
  1. Verify the boot.ini file is found on the computer by using a boot diskette or use your Windows CD to get to the MS-DOS "C:\>" prompt.
  2. From this prompt edit the boot.ini, verify that it is pointing to the correct operating system, and that no anomalies are found within the file. Below is a listing of what to verify
  • If only one operating system is on the computer verify that the boot.ini only has one operating system listed. In some situations an alternate configuration line may be added for the same operating system, leaving the improper line.
  • Verify that the "default=" line as well as the operating system line are the same and that they are pointing to the correct operating system.
Verify that the computer has the hal.dll file
From the MS-DOS "C:\>" prompt quickly determine if your computer has the "hal.dll" file by typing "dir hal.dll /s" at the prompt. If the computer returns a "File not found" message, the hal.dll has been deleted.
To recover this file boot the Windows operating system CD and choose the option to "Restore", "Repair", or "Recover." This option will prompt you for the Windows installation to use, the administrators password and will allow you to restore the proper file. At the MS-DOS prompt type the below command.
expand C:\i386\hal.dl_ D:\windows\system32\
In the above example "D" would be the letter of your CD-ROM drive and "C" the letter of the drive your operating system is installed on. For example, your disc drive may be D: and your hard drive is likely C:.
Jun 04, 2009 | Compaq Presario 5000 PC Desktop
Windows error ... \system32\hal.dll. Please re-install a copy of the above file!
Use the recovery disks that came with your computer to do a repair installation. Put the disk in your cd / and or dvd rom, restart computer and select repair installation from the prompt.
May 02, 2009 | Computers & Internet
Windows could not start because the following file is missingor corupt: <windows root>\system32\hal.dll.
Here is a link that will help you step-by-step fix the hal.dll error:
http://pcsupport.about.com/od/findbyerrormessage/a/missinghaldll.htm
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 20, 2008 | HP Computers & Internet
Missing file when computer is turned on
hi, hal.dll file to communicate with your computer hardware. if you are able to goto command prompt then do the following :
ensert your cd into the cd drive asuming that d is your cd drive then do the following :
expand d:\i386\hal.dl_ c:\windows\system32\hal.dll
and press y when prompted.
alternate you have to reinstall the os.
Jul 22, 2008 | HP Pavilion (PN153AAR) PC Desktop
\system32\hal.dll
You Need To Reinstall windows
Apr 17, 2008 | Computers & Internet
Computers & Internet Logo
23 people viewed this question
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
