Question about Philips 32PW6006 32" TV
Error codes Hi I have the 32inch widescreen model 32pw6006/25. The set keeps switching itself off into standby mode. By doing a bit of research on the internet I have managed to enter the service mode and the set is coming up with the error code of 5 and 11. I also managed to get a copy of the service manual and these error codes are as follows: 5 = device- TDA95xx, error description - POR 3V3 / +8v protection 11 = device - TDA6107/8, error description - current black loop protection I have no idea how to go about fixing these. Any help would be great!! Thanks
Replace IC TDA95xx and TDA 6107/8. obtain IC's from a electronic supplier/seller
Posted on Jul 09, 2007
  • 3 Answers
Same CRT problem have a look at a more detailed post on this forum
Posted on Jun 05, 2007
How do i reset a medion 80cm, led lcd t.v model number 41104
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked above. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Oct 26, 2014 | Televison & Video
I have a panasonic 32inch LCD TV. It will not turn on with the remote or the power button on the tv. The red light of the set is flashing 4 times. what is the problem?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Oct 08, 2014 | Televison & Video
I have a sanyo 32inch tv an it wont tyrn on it has the blue light but when I turn it on it just keeps flashing but flashing like the light is loosing power?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Jul 31, 2014 | Televison & Video
My Sony 32inch is blinking in standby mode and won't turn on
Sorry to tell you this i have the same TV.I have just checked the manual it says TO count how many times the light flashes in 3 second intervals.Then turn the tv off and un plug it from the mains.Sorrry then you will have to ring the Sony service centre and explain the problem.
Aug 17, 2012 | Sony Bravia XBR KDL-32XBR4 32inch LCD HDTV
Tv wont turn on
well first of all if anything happens when you push the button then the button works! I think you should leave this one to a professional technician. There is a circuit problem that will require advanced knowledge.
Jan 04, 2010 | Televison & Video
I have a Funai HDR-B2735 dvd/video cassette recorder with HDD. When turning the machine on, it automatically switches off with the screen displaying the message "System error 02/56" before going...
Exact same symptom as above, little flashing "W" on standby, error code 02-56 on switching the unit on, promptly turns itself off. It would help no end if Funai would publish a little bit more info about these error codes on their site, or have a forum somewhere. Gona try a factory reset and a replacement HDD, dont know if i could replace it with a new one or not. any ideas or experience with these errors would be greatly appreciated!
Aug 18, 2008 | Televison & Video
Standby-7 blink code
First,
If you have the back off, make sure the lamp safety switch is engauged ( you might not have a model that you don't need to do this with). If your set powers up normally make sure the your fans are running. If anyone of them should lag your set will shut down.
Second: How many hour do you think you have on your lamp? Some sets require the lamp hrs to be reset. It's sad because your your lamp is still operating. Let me know what you come up with.
Mar 10, 2008 | Televison & Video
Duraband 32inch, FTV7601
the problem is the power supply, check and replace regulator ic or even check the zener diode that trigger the regulator it maybe open or shorted......
Feb 16, 2008 | Durabrand DWT1905 TV
Turning itself off and snowy picture
problem is build up on the cathodes and when the reach maximum temperature they cause a short between heater and cathodes .also possible g2 and cathodes short circuit.One way is to separate the heater circuit H1,H2 and use a transformer or build a coil on the line output transformer (3 times not shore read up for it) and u will get 6v for the heater.Read this http://www.penders.cwc.net/otcolour.html it will help even if is for other problems. Good luck
Sep 04, 2006 | Philips 32PW6006 32" TV
Philips 32PW6006 32" TV Logo
380 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
