Picture on 61 inch Toshiba looks three dimensional.started today for no reason
  • fooha818 Oct 31, 2008
    so what can be done to fix it?
    Genius:
  • 2,920 Answers
Sounds like the convergence board went out on the tv
Posted on Oct 30, 2008
42 inch toshiba red light blinks three times no picture or no sound
Toshiba e-studio 18 every morning frist time copy light and background
Oct 31, 2013 | Office Equipment & Supplies
Sound no picture 56h80 toshiba
This set will blank the picture for several different reasons:
No filament voltage to the three tubes it uses.
No high voltage to the three tubes it uses.
No vertical or horizontal sweep (prevents all three tubes from having the screens burnt with a line.
Some of these can be tested but most require a schematic etc.
Set has several fuses and some do not look like fuses--called pico fuses.
Jun 11, 2012 | Toshiba Televison & Video
Its a 2004 61 inch big screen projection tv and the subject on screen has three colors outlining it green red blue on the outer portion of subject on screen
Tv have a problems known as a convergence pictures problems,it is dead.Tv have R,G,B colors lines mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board must be replaced to repair it.To solved tv pictures convergence problems.The shop will cost u like $300-350 for parts and labors.
Jul 05, 2011 | RCA R61WH76 61" HDTV
My toshiba theaterview 61 inch tv's power button blinks and there is no picture.
Most of the time when this happens the power supply for the set has failed and is not getting enough voltage to operate the set. A very common problem among all the brands.It could also be overheating and not letting the set come on to protect itself. The blinking should be in a pattern like morse code, find out how many blinks your getting and which color light is blinking and check your manual for the reasons or check back here for more info if needed.
Jun 12, 2011 | Toshiba Televison & Video
Toshiba 61 inch rear projection scrambled picture for 10 minutes after power on, then clears up.
If you are seeing lines and or noise for the first several minutes and it goes away--I think I know what the problem is.
Has the period of time before it clears up been getting longer and longer?
Reply to me with the exact model number and I will tell you what is wrong and what has to be done to fix it.
A lot of these sets have problems with what is called a HYPER board----it controls all signal inside the set--confirm Toshiba and exact model number---
I am here to help people and I do this here for free.
REGARDS, SD TECH
Oct 31, 2009 | Toshiba 42H81 42" Rear Projection...
No picture is it the bulb and is this hard to change?
You DO NOT have just a bulb in your set. You have the older style Projection TV with three picture tubes. It's a good possibility that you have a convergence issue that has blanked the raster and therefore you will not see a picture until the error is corrected. Have it looked at by a qualified technician.
Sep 11, 2009 | Toshiba 61HX70 61" Rear Projection...
Picture on 36 inch toshiba tv out
I had the same problem on my 61" RCA TV... The switch for the power/channel changing buttons seems to be a faulty product... However if you are a little technical you can open up the front of the TV and disconnect the button panel from the tv and just use the remote to operate it.
Jul 02, 2009 | Toshiba Televison & Video
Where is the hard reset located
This is not a problem that a "reset" will resolve. There is a problem with the convergence circuit. It may be as simple as poor solder connections on the convergence ICs. If you can solder, you can fix this yourself. Please let me know if you wish to attempt the repair and I'll supply additional details and instructions.
Dan
Feb 05, 2009 | Toshiba 61HX70 61" Rear Projection...
BLINKING POWER LIGHT AND TV DOES NOT POWER ON
I have a toshiba 61 inch projection tv the power light flashes with no picture any easy fixes?
Jun 24, 2008 | Toshiba TP61G90 61" Rear Projection...
Toshiba 50hp66
Have it fixed now before its too late the plasma is cheep and will fail. while its under make them replace it.
Jul 13, 2007 | Toshiba 42HP66 42 in. LCD Television
Televison & Video Logo
106 people viewed this question
Top Televison & Video Experts
Electro Med Services...
