I camera is inserted but the leapster wont respond to it. It has worked in the past. I look at the camera all looks well. What to do?
I had the same exact problem. I even tried another camera with no luck. I ended up updating the firmware/software on the Leapster Explorer and the camera started working. Here is a link to the Leapster website showing you how this is done:
http://leapfrog.custhelp.com/app/answers/detail/a_id/2090/~/error-52%3A-update-software
If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
1) Ensure that a game cartridge is not inserted in the Leapster2
2) Hold down the Hint (?) button while
turning the unit on. Continue to hold the Hint button down until the
LEAPSTER2 menu appears. Remember that you need to hold the "Hint" button
down the whole time while you are pressing the power button, and
releasing it.
3) The LEAPSTER2 menu will show the
options Base Info, Cart1 Info, Cart2 Info, Cart3 Info, and Touch Calib.
If you do not see this menu after powering on the Leapster2, turn the
Leapster2 off and repeat steps 1 & 2 until you see the menu.
4) When the LEAPSTER2 menu screen appears, press the A button on your handheld.
5) Using the stylus pen, touch each of the crosshairs that appear
6) Restart unit
