Question about Epson Stylus Color 600 InkJet Printer
Printer initializes, but then all (4) lights flash continuously....
... and the printer can't be identified by the (MAC) computer. This is after many years of use with the same computer.
    Master:
    Sergeant:
  • 482 Answers
Unistall the driver restart computer then renistall driver.
Posted on Oct 30, 2008
What causes orange light to flash 4 times?
It is related to a badly installed or empty print cartridge: http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#1600
1600 - Orange light blinking 4 times Description:
The ink cartridge has run out.
Resolution:
  1. Lift the printer cover up.
  2. Identify the ink cartridge that has run out (the ink cartridge flashes quickly at around 1-second intervals).
  3. Replace the applicable ink cartridge and close the cover.
  4. Press the [Resume/Cancel] button on the device to continue printing.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
1660 - Orange light blinking 4 times Description:
The ink cartridge has not been installed correctly.
Resolution:
  2. Check that the red lights on the ink cartridges are all turned on.
  3. If no red light is activated on a particular cartridge, check that the cartridge is securely positioned and adjust if necessary.
  4. Also make sure that the orange protective cap has been removed from the bottom of the ink cartridge.
  5. Press the [Resume/Cancel] button on the device to continue printing.
Feb 11, 2016 | Canon PIXMA iP3500 Printer
Cannot connect to network. It show IP address 0.0.0.0
contact your service provide for assistance on how to set it up
Apr 28, 2015 | HP LaserJet P2015n Printer
Need to perfrom nvram init on HP 4250
To initialize NVRAM, turn the printer power off. Remove any installed accessories (for example, a stapler/stacker). Turn the printer power on, and then hold down (SELECT button) when the memory count begins. Continue holding down until all three printer control-panel lights flash once and then remain on. This might take up to 10 seconds. Press (UP ARROW button). Press the PAUSE/RESUME button (LJ 4200/4300) or the MENU button (LJ 4250/4350). The display should show SKIP DISK LOAD. Press (UP ARROW button) until NVRAM INIT is highlighted. Press (SELECT button) the printer initializes NVRAM and then continues its power-on sequence.
Nov 07, 2012 | HP Laserjet 4250dn Network Laser Printer...
I have a printer it is modle is Hp LaserJet p4015n, when i start it give me this error: (49.00FF ERROR To continue turn off then on). when I turn off then on it give me agane this error. thanks for help,...
HP 4015 NVRAM & hardrive initialization
Solution
A hard disk initialization will erase and reformat the printer's hard disk. Perform hard disk initialization only if an error code displays on the control panel indicating a disk error. Always try initializing the hard disk before replacing it.
1. Turn the printer on.
2. As the printer performs its power-on sequence, press and hold the Menu button until all three lights on the control panel are lit.
3. Press the back arrow . The message INITIALIZE DISK displays on the control panel.
4. Press OK. The printer initializes the hard disk and continues the power-on sequence.
CAUTION: Initializing NVRAM resets the serial number, the model number, the event log, the page counts, and the EIO card. Use the SERVICE menu to restore the serial number and page counts. You also need to reconfigure any computers that print to this printer to recognize the printer. Initialize NVRAM only when absolutely necessary. In most situations, use a cold reset to return printer to factory defaults but still retain the needed values in the SERVICE menu.
 NVRAM initialization
Before initializing NVRAM, print a configuration page and a supplies status page to gather the service menu values
1. Turn the printer on and watch the control panel display.
2. When the display shows the memory count, press and hold the down arrow until all three lights on the control panel are lit
3. Press the up arrow .
4. Press Menu . The message SKIP DISK LOAD displays on the control panel.
5. Press the up arrow until NVRAM INIT is highlighted, and then press OK. The printer initializes NVRAM and then continues its power-on sequence.
daca aceasta procedura nu reuseste, atunci va trebui sa inlocuiesti formatter-ul. daca nu exista hard disk
Good luck
Dec 12, 2009 | HP LaserJet P4015N Printer
49.4401 service error on start up
Solution or Workaround:
1) TRY to flash the firmware.
2) Try cold reset and disk initializations.
3) Replace firmware dimm.
If you have a hard disk:
To resolve the issue it may be necessary to perform the Disk Init procedure.
Disk Init Procedure
1. Turn the printer off, then on
2. When the memory count starts on the control Panel, press and hold the Menu button until all 3 lights on the control panel are lid
3. Press the < button. The message “INITIALIZE DISK” appears in the display
4. Press the Check button. The printer will initialize the User space on the Compact flash and will continue it’s power-on sequence.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 19, 2009 | HP LaserJet 4650dn Printer
All the lights are flashing including the blue power button light. What does it mean. I tired holding the blue power button down but that did not work. Please help.
This indicates a Service Call Error. Turn printer OFF, wait a few
seconds and then the printer ON. If the alarm continues, perform a
factory reset:
1. Turn the printer OFF.
2. Check that the front cover is closed.
3. Turn ON the power switch while holding down the GO button.
4. Check the Toner/Drum/Paper LED#s are lit.
5. Release the GO button and check that all LED#s are off.
6. Press the GO button eight times.
7. The printer settings will be reset to factory default.
8. The printer will then initialize and return to Ready status.
If the problem continues and the printer has a one year limited exchange
warranty. If the printer is in warranty, call Brother Customer Service at 1-877-Brother (1-877-276-8437) for warranty options.
If the printer is out of warranty, contact a Brother Authorized Service
Center for repair by clicking on the link below:
http://www.brother-usa.com/service/default.aspx
May 04, 2009 | Brother HL 2140 Laser Printer
All lights flashing on the epson stylus photo 870. Printer not working.
Unfortunately, the Russian software does not work on a Mac, and it crashes at launch when installed in WZ98 under Virtual PC. However, I found this on another site, and it worked immediately:
The sequence to reset the waste ink counter is as follows:
WASTE INK ROM RESET ONLY 870, 1270
1. Turn the printer off using the power button on the panel of the printer.
2. Disconnect the interface cable at the back of the printer.
3. Hold down the "LOAD/EJECT" and "CLEANING" buttons simultaneously.
4. Turn the printer on. Release all buttons as soon as paper out light flashes.
5. Quickly press (within 3 seconds while PAPER OUT light is flashing) the "CLEANING" button for 10 seconds.
6. Release the button and the printer will initialize.
7. Once initialization is complete, turn the printer off.
8. Reconnect the interface cable.
9. Turn the printer on
Works great, no muss...no fuss!
Feb 26, 2009 | Epson Stylus Photo 870 InkJet Printer
Display reads "card slot not initialized"
2 As the printer performs its power-on sequence, press and hold the PAUSE/RESUME (HP Color
LaserJet 4600 models) or MENU (HP Color LaserJet 4610n and 4650 models) button until all
3 Press . The message INITIALIZE DISK appears on the control-panel display.
4 Press The printer initializes the hard disk and continues its power-on sequence.
Feb 26, 2009 | HP LaserJet 4650n Printer
Printer takes ages to process
NV RAM and HD
To initialize NVRAM
1. Remove any installed accessories (for example, a stapler/stacker).
2. Turn the printer off.
3. Hold down the DOWN ARROW ( ) button, and then turn the printer on. Continue holding
down the DOWN ARROW ( ) button until all three printer control-panel lights flash once and
4. Press the UP ARROW ( ) button.
5. Press the PAUSE/RESUME button. The display should show SKIP DISK LOAD.
6. Press the UP ARROW ( ) button until NVRAM INIT is highlighted.
7. Press the SELECT ( ) button. The printer initializes NVRAM and then continues its poweron
sequence.
Hard-disk initialization
CAUTION A hard-disk initialization erases and reformats the printer hard disk. Perform a hard-disk
initialization only if an error code on the control panel indicates an EIO disk error. Always try
NOTE Before performing a hard-disk initialization, print a menu map and a configuration page (see
Menu map and Configuration page). Use the information on the configuration page to reset
any customer-set printer configuration values that the hard-disk initialization procedure
changes.
To initialize the hard disk
1. Turn the printer off.
2. Hold down the PAUSE/RESUME button, and then turn the printer on. Continue holding down
the PAUSE/RESUME button until all three printer control-panel lights flash once and then
3. Press the BACK ARROW ( ) button. The display should show INITIALIZE DISK.
4. Press the SELECT ( ) button. The printer initializes the hard disk and continues its power
Mar 12, 2008 | HP LaserJet 2420 Printer
All available lights on printer are flashing
More or less your printer fuser has gone bad. Replace the fuse. I suggest that when buying a printer you don't with dell 1710N these printers gives a lot a problem. I work with them every day at work.
I suggest that you go with HP.
Oct 09, 2007 | Dell 1710 Laser Printer
Epson Stylus Color 600 InkJet Printer Logo
35 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
