Question about Sport & Outdoor - Others
Yamaha 70etlf boat motor
Hello, and thank you.
I need to change the oil on the above motor but do not know how. Can you help me?
Thank you for your consideration.
Don Naduriak
  • 1779 Answers
SOURCE: instructional guide oil change
Check your owners manual for the following info: Engine oil requirements, which would be what engine oil weight is right for your car. It will be #'s such as 5W 30. Use the weight recommended by chevy. The manual will also tell u how much u need. Go to an auto parts store, where u will need to purchase the following: 1. engine oil (they should be able to look up the weight requirement for your car, 2. oil filter, get a quality filter. An easy way to determine that is the weight of the filter. A good filter has a valve in it to prevent oil from draining out when the engine is off. This way when u start the car, u have oil pressure right away. You can also ask for advice on what they feel is a good filter.3. Filter wrench, to remove the oil filter. You can determine the correct size by seeing if it fits on the new filter. Ok, take it all home and: the car should be at operating temperature, either jack up the car or buy a set of ramps to drive it up on so u can get under the car. Make sure the car is supported on safety stands, never go under a car w/ just a jack holding it up. Block the rear wheels front and back so the car can't roll, put the emergency brake on, leave it in gear if it's a standard trans, in park for auto trans. Go under the car to remove the oil pan drain bolt. Be careful as surfaces and oil will be hot. Have a good size plastic pan, or something similar (u can also buy a oil drain container especially made for this) under the car. Remove the drain plug, letting the oil drain for 15 minutes or so, to let it drain completely. The reason u drain it w/ engine hot is to drain the oil quickly and completely, cold oil would take a long time to drain. Remove the oil filter w/ your wrench. I assume your filter is accessed from under the car. A few (not many) allow u to remove the filter from above in the engine compartment. With a clean rag, wipe off the area where the oil filter screws on. Make sure the old gasket isn't stuck on (rare, but it does happen). Also clean the area around the drain bolt. Replace the drain bolt, do not use brute force to tighten it, you want it on good and snug, not loose or so tight you ruin the threads. Now coat the gasket on the new oil filter w/ new clean engine oil, screw on hand tight. Go by the oil filter instructions on the box, usually u tighten til it just makes contact w/ the engine, then tighten one half to one full turn more.
Add the required amount of oil, start up and let it run for a few minutes, check for any leaks. Check your level several times a month so u know how often to add oil. U shouldn't wait 'til its down a quart to add oil, if its down half a quart, top it off. Your engine will reward u with a long life w/ this care (change every 3k miles). Don't overfill ever, as too much oil is bad for the engine, it causes the oil to foam, and u loose your lubrication. Many garages, town and city recycling centers, oil change shops will accept used oil to recycle. Whoa! seems a lot more complicated than it really is! Let me know if u have any questions. countrycurt0
Posted on Oct 05, 2008
bartech9
  • 155 Answers
SOURCE: error triying adjust labels on zebra tlp 2844
Try to calibrate it: turn off your computer, press the button and turn on, release the button and let progress labels.
Posted on Mar 10, 2009
Fame_Guru
  • 483 Answers
SOURCE: Yamaha outboard motor manual
You got it :
http://www.yamaha-motor.com/outboard/service/viewmanuals/outboard_manuals.aspx
here !
Posted on Mar 20, 2009
cape cod bob
  • 292 Answers
SOURCE: Change oil in 2004 Yamaha V Star 1100 Classic, procedure?
i think the oil filter is at the front behind a round finned cover, if you find the drain plug it should be right above it, it shoud tell you how much oil it takes right next to the filler
Posted on Mar 22, 2009
SOURCE: motor not pushing boat after two thousand rpm's
The prop is cavitating. The outdrive is not trimed under enough or the prop is damaged (providing it is the correct prop.)
Posted on Jun 10, 2009
Help with my 1994 Yamaha 150Hp
Outboards have thermostats...the tattle tale can be pouring water and the engine still overheat if the thermostat is stuck or airlocked.
May 07, 2014 | Boating
I just have gotten Yamaha Royal Star 1300cc. (Year 1997) in my own. I want to change or replace all of oil but i don't have oil specification. My problems are What is a standard of oil which use...
Hi, Panjaball sorry you can't find the first and best tool you ever bought for your Yamaha despair not for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
HOW DO CHANGE MY OIL Tour Deluxe
DIY Oil Change Yamaha Roadstar
http://www.yamahaventure.nl/pdf/servicemanualxvz13tf.pdf
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/1998/Lit-11626-11-17_320.pdf
Jun 01, 2011 | 1997 Yamaha Royal Star XVZ 1300 A
My out board is a30hp yamaha 3cyl starting to oil plugs and and under load not running well have had it serviced and was told all was well i replaced spark plug s and ran well for to outings but 3 rd ...
In order to know if its bad fuel, too much oil or low compression you need to perform a compression check. You should have no more than 20% difference across all three. Compression should be above 100psi. This will show you where the problem is.
Hope this helps,Matt
Jan 02, 2011 | Light Outboard Motor Boat Bass Fishing...
Yamaha 200hp out bord wiring diagrams(for boat)
Hello. your best bet is to go to any good book store and get the repair manual for that engine. it will run you about twenty dollars but, you will use it time and time again, I know I do. Joe
Mar 22, 2010 | Cycling
Hello, I wanted to see if you knew what the symbols on the yamaha outboard digital tach are. The one I have does not have any buttons or total hour meter. The symbol I was wondering about is to the left of...
The gauge is for a Yamaha with a remote oil tank. Low oil and no oil. the manual is available at yamaha motors.com. in pdf download format .the year will be almost impossible to find out. the part number can be found at your local dealer. a good parts person can find that by just your description
Oct 24, 2009 | Boating
Sport & Outdoor - Others Logo
42 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
